Sponge Posted March 10, 2008 Share Posted March 10, 2008 My wife got me a TOM TOM GPS for my birthday over the weekend. I can't stand the stick stuff on the windsheild, clip it on the vent look of aftermarket electronics...drives me nuts. Has anyone ever installed one of these in the cubby? Will I get reception or does it need to be on the windshield? I used the suction cup thing on the left side of the dash/windsheild tucked into the corner and it doesn't look too bad...it will run on battery for 2 hours but for longer trips I figured I can run power down the side of the dash to the fuse panel or over to the center console outlet pretty easily just need a longer power cord... I refuse to do the stuck in the middle of the windsheild thing. Any pics or placement advise? My vB Gallery Link to comment Share on other sites More sharing options...
hmoob_gt Posted March 20, 2008 Share Posted March 20, 2008 i know you didnt like the window location.. but here is mine anyways. i thought its a decent place. =) something to share if you dont like any other ideas... http://i38.photobucket.com/albums/e141/ssjgotou/navi_small.jpg Link to comment Share on other sites More sharing options...
Sponge Posted March 20, 2008 Author Share Posted March 20, 2008 That's where mine resides right now too. Nice wire tuck did you try the vent closer to the windshield? My vB Gallery Link to comment Share on other sites More sharing options...
gfxdave99 Posted March 20, 2008 Share Posted March 20, 2008 If you install it in a way with the cubby that its inside the cubby it wont work, however if you install it where the top of the unit is exposed you should have enough to get signal. The other alternative is if you did want to install it physically inside the cubby you can get an external GPS antenna which will get you better reception then the stock one anyway. If everything seems under control, you're just not going fast enough. - Mario Andretti Link to comment Share on other sites More sharing options...
hmoob_gt Posted March 24, 2008 Share Posted March 24, 2008 That's where mine resides right now too. Nice wire tuck did you try the vent closer to the windshield? i did, but it took a little bit more time. so i just stuck it through there. and also the line wasnt too flexible so i tried to avoid the bending of the wire. so i thought coming from the vent there was best. Link to comment Share on other sites More sharing options...
leftride Posted March 24, 2008 Share Posted March 24, 2008 TomTom and other GPS should work without a problem in the cubby without an external antenna. A pretty good example: http://legacygt.com/forums/showthread.php?t=83143 I have had no issues with signal and get full bars. I even get a signal in the garage. *vb gallery* Link to comment Share on other sites More sharing options...
Sponge Posted March 24, 2008 Author Share Posted March 24, 2008 Yeah I get a signal inside of my house! My vB Gallery Link to comment Share on other sites More sharing options...
Sponge Posted March 25, 2008 Author Share Posted March 25, 2008 ^x2 I really want to do a cubby install...its just a matter of time to do it. My vB Gallery Link to comment Share on other sites More sharing options...
