legacyman1657615403 Posted September 3, 2011 Share Posted September 3, 2011 i constantly stop at my my 1998 legacy l wagon just dies. but starts right back up. thinking it might be my fuel pump.. checked my alternater and its running 14 amps, battery is fine. how do i go about replacing my fuel pump. Theres access under the rear seat right? also should i replace the fuel filters while im at it? Link to comment Share on other sites More sharing options...
Jab83 Posted September 3, 2011 Share Posted September 3, 2011 I think you gotta drop the tank... BUt idk i've never done a fuel pump on a subie before. Link to comment Share on other sites More sharing options...
I Donated broknindarkagain Posted September 3, 2011 I Donated Share Posted September 3, 2011 There is an access panel under the rear seat. However, before you go replacing your fuel pump, have you checked your idle air control valve? Actually, read the Engine FAQ at the top of the forum. In there you will see a part about gas mileage.....do everything on that list before you condem your fuel pump -broknindarkagain My Current Project - Click Here COME AND TAKE IT "The only thing necessary for the triumph of evil is for good men to do nothing." Link to comment Share on other sites More sharing options...
worknlikeadog Posted September 4, 2011 Share Posted September 4, 2011 I have a question. Is there any benefit in switching to a different pump. I know you can run a dodge neon coil pack for a better spark, just wondering if you would get better flow. Link to comment Share on other sites More sharing options...
I Donated broknindarkagain Posted September 4, 2011 I Donated Share Posted September 4, 2011 The Neon coil pack is if you want to use MSD. A stock Neon coilpack I don't think will give you any kind of upgrade. A stronger fuel pump won't give you any kind of benefit...because you're still limited by the size of the fuel lines, the fuel filter, injector size, pressure regulator, etc -broknindarkagain My Current Project - Click Here COME AND TAKE IT "The only thing necessary for the triumph of evil is for good men to do nothing." Link to comment Share on other sites More sharing options...
legacyman1657615403 Posted September 7, 2011 Author Share Posted September 7, 2011 well its dead in the water now and almost didnt make it home from Sacramento. im hoping its the fuel pump since now under any load it just cuts out. I have good mechanic skills is there any tricks i should know before replacing it? or should i brake the bank and pay someone to. Link to comment Share on other sites More sharing options...
SpecBamf41 Posted September 7, 2011 Share Posted September 7, 2011 tear it down to the pump. and try and get a better hear on it while its running? BNR18g on 93oct Link to comment Share on other sites More sharing options...
Baddog Posted September 7, 2011 Share Posted September 7, 2011 There is access to the fuel pump. Easy as pie to replace on these cars. Link to comment Share on other sites More sharing options...
SpecBamf41 Posted September 7, 2011 Share Posted September 7, 2011 got a spare already for when my goes out. BNR18g on 93oct Link to comment Share on other sites More sharing options...
legacyman1657615403 Posted September 8, 2011 Author Share Posted September 8, 2011 well fuel pump is fine. looks like its the mas air flow sensor going out. the car will run like crap and then if i tap the air flow sensor it runs ok. Link to comment Share on other sites More sharing options...
jamesm113 Posted September 8, 2011 Share Posted September 8, 2011 well fuel pump is fine. looks like its the mas air flow sensor going out. the car will run like crap and then if i tap the air flow sensor it runs ok. is it dirty? you can try cleaning it with MAF cleaner (or even electrical contact cleaner) Link to comment Share on other sites More sharing options...
legacyman1657615403 Posted September 8, 2011 Author Share Posted September 8, 2011 cleaned it with brakeclean. seems to be running good now. ill wait to see it it acts up again and replace it then. Link to comment Share on other sites More sharing options...
worknlikeadog Posted September 8, 2011 Share Posted September 8, 2011 Do yourself a favor go to the junkyard buy two Japan made maf cause the amercian made ones SUCK keep one in your trunk just in case. The new ones aren't worth the money they want Link to comment Share on other sites More sharing options...
legacyman1657615403 Posted September 9, 2011 Author Share Posted September 9, 2011 alright thanks. can anyone chime in on if i can only use one from a 2.2l motor. Link to comment Share on other sites More sharing options...
I Donated broknindarkagain Posted September 9, 2011 I Donated Share Posted September 9, 2011 you can use any 95-99 legacy / outback / impreza fuel pump -broknindarkagain My Current Project - Click Here COME AND TAKE IT "The only thing necessary for the triumph of evil is for good men to do nothing." Link to comment Share on other sites More sharing options...
worknlikeadog Posted September 9, 2011 Share Posted September 9, 2011 You can use alot of different mafs including some nissans read the number on the Maf and match Link to comment Share on other sites More sharing options...
Rideredmx38 Posted August 16, 2015 Share Posted August 16, 2015 Try resetting your ecu Link to comment Share on other sites More sharing options...
zangado1 Posted August 16, 2015 Share Posted August 16, 2015 you can use any 95-99 legacy / outback / impreza fuel pump That's true. I have a 95 BK and bought a used MAF out of a 99 Outback that was wrecked with 86.000 miles on it for $30. My car is like brand new with idle and no more hesitatation at low RPM's Link to comment Share on other sites More sharing options...
