shocker Posted March 18, 2007 Share Posted March 18, 2007 First time I've had her break, I'm heartbroken and pissed. It is driving, but I'm not sure how far I should drive it without knowing what's wrong, the symptoms: CEL is on. CRUISE light in flashing. AUTO tranny won't shift into "5th" gear (it'll claim it's in 5th in sport mode, but it's not according to revs). I figured this out because normally, 3k rpm = 80mph, tonight 3k rpm was about 72mph, and 80mph was closer to 3500 rpm. This issue happened once before, but just went away on it's one (maybe a month ago). The CEL and CRUISE light though? Wtf! I can't turn the cruise control on or off, the light just sits and flashes. Can't hear anything really odd, though. Meh, I'm pissed, car is covered under warranty, but that does me no good for tomorrow, since the dealer isn't opened til monday. I'm in the greater Manchester, NH area. Link to comment Share on other sites More sharing options...
EyeFlyIsTheEye Posted March 18, 2007 Share Posted March 18, 2007 Have them take a look at the O2 sensor or one of the tranmission solenoids. First time I've had her break, I'm heartbroken and pissed. It is driving, but I'm not sure how far I should drive it without knowing what's wrong, the symptoms: CEL is on. CRUISE light in flashing. AUTO tranny won't shift into "5th" gear (it'll claim it's in 5th in sport mode, but it's not according to revs). I figured this out because normally, 3k rpm = 80mph, tonight 3k rpm was about 72mph, and 80mph was closer to 3500 rpm. This issue happened once before, but just went away on it's one (maybe a month ago). The CEL and CRUISE light though? Wtf! I can't turn the cruise control on or off, the light just sits and flashes. Can't hear anything really odd, though. Meh, I'm pissed, car is covered under warranty, but that does me no good for tomorrow, since the dealer isn't opened til monday. I'm in the greater Manchester, NH area. Link to comment Share on other sites More sharing options...
one69chev Posted March 18, 2007 Share Posted March 18, 2007 reset the code and see if it comes back. if you don't have access to a scan tool, pull the neg battery cable for a few minutes. btw, have you checked you trans fluid level?? i'm not sure about subbies, but others makes low on fluid will set a code.... Link to comment Share on other sites More sharing options...
wukindada Posted March 18, 2007 Share Posted March 18, 2007 Are you stock??? Just take the car into the dealer on monday. I assume you do not have a Accessport, If you did you'd be up and running now...... What were you doing when the cel first went off? Toyota 6EATS .........SUCK!!!!!! Link to comment Share on other sites More sharing options...
one69chev Posted March 18, 2007 Share Posted March 18, 2007 Have them take a look at the O2 sensor or one of the tranmission solenoids. an o2 sensor doesn't generally affect shift points tho.... Link to comment Share on other sites More sharing options...
shocker Posted March 18, 2007 Author Share Posted March 18, 2007 I was pulling into a parking spot in snow, backed up and noticed the light had gone on. Parked, came out later, and it was still on (after I started the car again). I don't think the tranny shifting and the CEL issue are related, just because I've had the tranny issue before, without the CEL. I don't have an accessport so I've gotta go to the dealer on monday. What does the flashing CRUISE light mean? Thanks for all the help/suggestions, guys. Link to comment Share on other sites More sharing options...
wukindada Posted March 18, 2007 Share Posted March 18, 2007 Standard cel nothing to worry about. My guess is you will be in & out of the dealer pretty quick;) Toyota 6EATS .........SUCK!!!!!! Link to comment Share on other sites More sharing options...
shocker Posted March 18, 2007 Author Share Posted March 18, 2007 Ah, didn't realize the CRUISE flashes along with the CEL. I looked through the manual and couldn't find anything about that. Link to comment Share on other sites More sharing options...
wukindada Posted March 18, 2007 Share Posted March 18, 2007 you'll be alright, normal funtion of the cel Now if the engine light is flasing you need to get to the dealer Toyota 6EATS .........SUCK!!!!!! Link to comment Share on other sites More sharing options...
shocker Posted March 18, 2007 Author Share Posted March 18, 2007 I'm goin skiing tomorrow, 180miles round trip, can I drive, or am I better off riding with my friend? Link to comment Share on other sites More sharing options...
mickeyd2005 Posted March 18, 2007 Share Posted March 18, 2007 You have an 05. Pull the code using the onboard reader and post it up here. We'll tell you if it's okay or not. Link to comment Share on other sites More sharing options...
mwiener2 Posted March 18, 2007 Share Posted March 18, 2007 Someone correct me if I'm wrong, But I do believe that 5EAT doesn't like when some wheels spin and others don't. So driving in the snow could throw a CEL. The shifting problem sounds more like the torque converter not locking up rather than 5th not engaging. Search the forum.... there is a way to read the CEL code using the odometer readout. My Mods List (Updated 8/22/17) 2005 Outback FMT Running on Electrons Link to comment Share on other sites More sharing options...
shocker Posted March 18, 2007 Author Share Posted March 18, 2007 05s have an onboard code reader? Anyone care to explain *HOW* I can do this? And yes, i had some wheel spin today before it went, with all the snow I'd been driving through. Link to comment Share on other sites More sharing options...
mwiener2 Posted March 18, 2007 Share Posted March 18, 2007 1. click on search 2. type "built in code reader" 3. hit enter 4. read through search results My Mods List (Updated 8/22/17) 2005 Outback FMT Running on Electrons Link to comment Share on other sites More sharing options...
shocker Posted March 18, 2007 Author Share Posted March 18, 2007 Found the directions, just went out to the car, opened fuse box. Can't find any white plugs that they're talking about. Link to comment Share on other sites More sharing options...
mwiener2 Posted March 18, 2007 Share Posted March 18, 2007 look more around the fuse box rather than right in your face. They should be stuffed off to the side somewhere Some autozone are open till midnight....duno what timezone you;re in My Mods List (Updated 8/22/17) 2005 Outback FMT Running on Electrons Link to comment Share on other sites More sharing options...
MangoGT Posted March 18, 2007 Share Posted March 18, 2007 It's limp mode. As someone else mentioned, 5EAT doesn't like it when some wheels spin and others are stopped. I was out of town a few weeks ago and my girlfriend decided to drive through a blizzard with my LGT (instead of her WRX wagon) and she called me to tell me that she "broke my car". She drove into 8 inches of untouched snow and hit the brake. Next thing she knew, the car wouldn't move, the CEL was on, and the cruise light was flashing. She called a tow truck driver--he got in the car, put it in reverse, and backed up for $75. She learned her lesson. I came home the next day and drove through all sorts of snow without any problems. The CEL was still on for a little while but it went away within a day. Drive for your trip. You shouldn't have any problems. Just stop driving like a girl in the snow. Link to comment Share on other sites More sharing options...
GBY Posted March 18, 2007 Share Posted March 18, 2007 thread moved to warranty issues and problems. Link to comment Share on other sites More sharing options...
laz Posted March 18, 2007 Share Posted March 18, 2007 It happens, it'll go away on its on in a couple of days, if you want it to go away sooner, disconnect the battery. X --- Link to comment Share on other sites More sharing options...
VTGT Posted March 18, 2007 Share Posted March 18, 2007 when you said your automatic broke, I was like not another one. Your problem doesn't sound serious. Link to comment Share on other sites More sharing options...
EyeFlyIsTheEye Posted March 19, 2007 Share Posted March 19, 2007 My car once did something similar, the O2 sensor was busted... perhaps the computer put the tranny in limp mode or something similar.. an o2 sensor doesn't generally affect shift points tho.... Link to comment Share on other sites More sharing options...
