sgeorge Posted August 24, 2007 Share Posted August 24, 2007 I recently installed swift springs on my lgt wagon. i let them settle for about a week and then took off on vacation. I took it to get realigned when i got back from vacation(last monday) and everything was fine for a few days. However 2 nights ago i noticed the driver side rear looked lower then that passenger side. Sure enough i have a finger gap on the driver side and 2 finger gap on the passenger side. A friend and i did the install, this is not the first spring swap we have done. Any insight as to why this would happen or what could be wrong? Link to comment Share on other sites More sharing options...
HansGT Posted August 24, 2007 Share Posted August 24, 2007 could be the shock. are you on the stock ones...how many miles? Link to comment Share on other sites More sharing options...
badfish11 Posted August 24, 2007 Share Posted August 24, 2007 Was all the vacation suff packed on one side of the car? Could the driver side have settled quickly than the other? Link to comment Share on other sites More sharing options...
sgeorge Posted August 24, 2007 Author Share Posted August 24, 2007 the car didnt go on vacation. 29k miles. Link to comment Share on other sites More sharing options...
ebpda9 Posted August 24, 2007 Share Posted August 24, 2007 mine did the same thing on all the springs that i had installed, including stock ones Link to comment Share on other sites More sharing options...
PhilT Posted August 24, 2007 Share Posted August 24, 2007 If it wasn't your first install I would question whether the spring mounts were correctly orientated. Double Award Winning Legacy GT Wagon Link to comment Share on other sites More sharing options...
sgeorge Posted August 24, 2007 Author Share Posted August 24, 2007 It is possible that the spring mount is incorrect as my friend did both driver's side swaps and i did the passenger side swaps now that i think about it. Anything other possibilities? Link to comment Share on other sites More sharing options...
sgeorge Posted August 24, 2007 Author Share Posted August 24, 2007 Obviously it is something with the spring as it is not allowed uncompress all the way. Anybody else with swifts have a similar problem? Link to comment Share on other sites More sharing options...
HansGT Posted August 24, 2007 Share Posted August 24, 2007 Does it look like this? (Bilsteins, but KYB's should be the same) Link to comment Share on other sites More sharing options...
sgeorge Posted August 24, 2007 Author Share Posted August 24, 2007 Yes it looks like that as far as i can tell with the wheel on. I will take the wheel off tomorrow and make sure the spring is seated correctly. Is it possible that my friend tightened the strut bolt down too far? Link to comment Share on other sites More sharing options...
musclecpa Posted August 24, 2007 Share Posted August 24, 2007 I have Swift sway bars and springs with stock shocks too, but the drop is even at all 4 corners. Link to comment Share on other sites More sharing options...
VXCL Posted August 25, 2007 Share Posted August 25, 2007 are you sure its not where you are parked? in my drive way my gap is uneven l to r 1 finger one side 2 on the other, but in a normal parking lot its dead even 1 finger all around MAYHEM #122/22 STS NNJR SCCA AUTOX4U.COM XENON RETRO GUIDE Link to comment Share on other sites More sharing options...
ebpda9 Posted August 25, 2007 Share Posted August 25, 2007 looking at my front bilsteins it seems that the distance between the top of the wheel and lower spring perch are off by .25" front to right, so it makes me think something must be tweaked below the strut Link to comment Share on other sites More sharing options...
sgeorge Posted August 26, 2007 Author Share Posted August 26, 2007 It wasn't just where i parked. I haven't had a chance to mess with yet like i hoped. But it makes sense that either the strut is damaged or something else is tweaked. Hopefully ill get a chance this week. Link to comment Share on other sites More sharing options...
