Grimmrican Posted January 20, 2013 Share Posted January 20, 2013 Sup guys and girls. Today I decided to test my battery at work and ran to a small issue/bafflement. In the illustrations below you will see how it went. Battery was okay. Not at it's best but okay... http://img.tapatalk.com/d/13/01/20/u7y3adur.jpg Starter... Low amps but voltage is good??... Well that would explain why she starts a little rough during cold starts (i.e.in the morning) http://img.tapatalk.com/d/13/01/20/7ady8abu.jpg Alternator was good but amps wasn't registered?? No clue as to why. Might also be on the verge of pulling too much of a load when acc is on... http://img.tapatalk.com/d/13/01/20/pegyhuhu.jpg And lastly the drain test... Passed no problems there. http://img.tapatalk.com/d/13/01/20/9e3a6e8a.jpg So in conclusion I'm a little confused about the starter and alternator as to salvage the parts or buy new ones Link to comment Share on other sites More sharing options...
Grimmrican Posted January 22, 2013 Author Share Posted January 22, 2013 Bump Link to comment Share on other sites More sharing options...
NickTej22 Posted January 22, 2013 Share Posted January 22, 2013 Probably voltage regulator in the alternator. I'd rather have it rebuilt, than buy a new one. Sent from my HTC One V using Tapatalk 2 Link to comment Share on other sites More sharing options...
ehsnils Posted January 22, 2013 Share Posted January 22, 2013 Cranking current is also depending on the shape of the connectors and wires. Link to comment Share on other sites More sharing options...
Grimmrican Posted January 22, 2013 Author Share Posted January 22, 2013 I'd have to get under there and take a look :/ Link to comment Share on other sites More sharing options...
spooln30 Posted January 23, 2013 Share Posted January 23, 2013 It's weird that you didn't get any amp readout for both the battery or the starter. Is that tester set up correctly? Usually while cranking you should have 150+ amps on our cars. Having a low amp draw while starting in some cases means a bad starter well bad or worn internal parts. Link to comment Share on other sites More sharing options...
Grimmrican Posted January 23, 2013 Author Share Posted January 23, 2013 Yea it was on correctly. And the machine runs prime. If I would've tested it again after I had already turned on the car I'm almost certain it would've tested ok. Te reason for the testing is because I thought I had a bad cell battery during cold starts. But the starter would explain why the cars idles rough then stabilizes. If I could take a video of it I would but not sure how to post it up on here Link to comment Share on other sites More sharing options...
