108 legacy Posted May 4, 2013 Share Posted May 4, 2013 Are there any pros / cons on removing that big engine cover on top of the 3.6R engine and driving without it. It's probably more for show and may keep down engine noise and keep it cleaner etc. Will it run hotter/cooler ? Just curious... Link to comment Share on other sites More sharing options...
sschmelcke Posted May 4, 2013 Share Posted May 4, 2013 It's just for looks. I've kept mine on Link to comment Share on other sites More sharing options...
GTEASER Posted May 4, 2013 Share Posted May 4, 2013 I removed mine on my GT the first week I had the car. It hangs on the wall in my garage. No issues. GTEASER's 2012 Legacy GT - Sold GTEASER's 2009 XTeaser - Sold GTEASER's 1992 Legacy SS - Sold Link to comment Share on other sites More sharing options...
108 legacy Posted May 5, 2013 Author Share Posted May 5, 2013 Thanks guys. I guess I'll keep it on for the time being. Link to comment Share on other sites More sharing options...
GhiaAddict Posted December 27, 2016 Share Posted December 27, 2016 How does the cover come off? Do you just unsnap it or are there clips that need to be removed? Have to replace serpentine belt. Link to comment Share on other sites More sharing options...
Humble Rumble Posted December 27, 2016 Share Posted December 27, 2016 Edit: Disregard my description, just follow this lol. http://i.imgur.com/9ya6Ulx.png 2012 Legacy 3.6R Build Thread 5th Gen Legacy BM/BR Body Kit Compendium Thread Link to comment Share on other sites More sharing options...
GhiaAddict Posted December 27, 2016 Share Posted December 27, 2016 When you speak of the front pop-in points, what do you mean by loosen? Or is it just lift up until it pops out? Or do I have to loosen with a tool, my hand, etc? Link to comment Share on other sites More sharing options...
Humble Rumble Posted December 27, 2016 Share Posted December 27, 2016 I edited my post with instructions I found. From what I recall, they're all just pop connections. If I recall correctly, the front ones are vertical and pull up and the back ones and horizontal and slide forward/backward, or maybe the other way around (it's been a while since I took mine off). I can check my cover when I get home if you want. Edit: I had it completely backwards when I originally posted. Pull up on the back, and pull up on the front while sliding it towards the front of the car, like the picture says. Brain is mush today haha. 2012 Legacy 3.6R Build Thread 5th Gen Legacy BM/BR Body Kit Compendium Thread Link to comment Share on other sites More sharing options...
Qship Posted December 27, 2016 Share Posted December 27, 2016 You might find the diagram confusing I did. Pull the back straight up to disengage the prong things. If you look at post http://legacygt.com/forums/showthread.php/snapped-engine-cover-supporti-258749.html you can see where I broke it off. Once you disengage the back slide the cover toward the front of the car a bit as you pull up. At least the plastic won't be cold and brittle when you do this. Just today I asked AZP if it serves any function and the said it's just cosmetic. Good luck. Link to comment Share on other sites More sharing options...
GhiaAddict Posted December 27, 2016 Share Posted December 27, 2016 About to give it a go. Thanks for the diagram. Driving with no power steering is definitely not fun. Link to comment Share on other sites More sharing options...
GhiaAddict Posted December 27, 2016 Share Posted December 27, 2016 Man that was super easy to remove lol Link to comment Share on other sites More sharing options...
Humble Rumble Posted December 27, 2016 Share Posted December 27, 2016 Haha yeah it is. I couldn't figure it out initially either, and felt like such a doofus once I got it off. 2012 Legacy 3.6R Build Thread 5th Gen Legacy BM/BR Body Kit Compendium Thread Link to comment Share on other sites More sharing options...
