MissJapaneseSubaru Posted November 25, 2012 Share Posted November 25, 2012 So im doing my belt and waterpump and so on. I had a massive oil leak. So i lined everything up the person who did it before me the timing marks were off and i didnt see any other marks but the circle on the crank pulley. Then i took the belt off cleaned everything up. And now i see a little notch on the side of it. If thats the notch im supposed to use how do i now fix the timing with the cams? There was no clinking are anything with the cams just dont want to twist the cams if im supposed to do something else. Thanks! Link to comment Share on other sites More sharing options...
MissJapaneseSubaru Posted November 25, 2012 Author Share Posted November 25, 2012 Sorry i have a 97 lgt ej25d Link to comment Share on other sites More sharing options...
subikid90 Posted November 25, 2012 Share Posted November 25, 2012 http://www.sl-i.net/FORUM/viewtopic.php?f=57&t=13265 4th picture down -Subikid90 1997 Legacy GT 5spd & EJ251 w/EJ25D heads ~10.5CR 1998 Legacy GT Limited waiting for EJ22T hybrid swap Link to comment Share on other sites More sharing options...
MissJapaneseSubaru Posted November 25, 2012 Author Share Posted November 25, 2012 Thanks subiekid Link to comment Share on other sites More sharing options...
MissJapaneseSubaru Posted November 25, 2012 Author Share Posted November 25, 2012 Ok so i put everything back together aligned everything. So when i started it it ran then cut off. Now i did disconnect my o2 sensor because i bought a new one but wasnt able to install it yet. Is this why it starts then cuts off? I installed a new waterpump New oil pump o-ring New belt New crankshaft seal Please help thanks!!!! Link to comment Share on other sites More sharing options...
DOHCEJ22E1 Posted November 26, 2012 Share Posted November 26, 2012 Reconnect your O2 sensor & check your vacuum lines. Also, check your wiring harness to see if everything is plugged in correctly. Link to comment Share on other sites More sharing options...
MissJapaneseSubaru Posted November 26, 2012 Author Share Posted November 26, 2012 Thanks guys the iac hose was off. It runs smooth now i was putting it back together last night for work in the morning. Thanks again!!! Link to comment Share on other sites More sharing options...
