rob-2 Posted January 9, 2012 Share Posted January 9, 2012 We occasionally smell gas in the car, my wife says for the last week or so. A tech friend suggested to us that the fuel lines on these cars are known to crack in cold weather. Is this true? Anyone had this problem? Estimated cost? Update 1/25. Lines were leaking. $500 job. Parts replaced 442121 MFI FUEL INJECTOR DELIVERY PIPE R&R 0951BG110 HOSE FUEL 807707131 HOSE 14 0 7 5AA210 GSKT INT COLLECTOR 805913050 HOSE CLAMP 13.5 99071AC010 hose vacuum 99071AC020 HOSE VACUUM 16272AA0 01 INSULATOR AND GASKET KIT 442121 MFI FUEL INJECTOR DELIVERY PIPE R&R Link to comment Share on other sites More sharing options...
whitetiger Posted January 9, 2012 Share Posted January 9, 2012 quit eating take-out burritos in the car. Link to comment Share on other sites More sharing options...
bmx045 Posted January 10, 2012 Share Posted January 10, 2012 fuel lines that run under the intake manifold sometimes seep in the cold weather- however I heard it was a recall on bugeye wrx's...not sure about lgt Link to comment Share on other sites More sharing options...
quick4dr Posted January 10, 2012 Share Posted January 10, 2012 Drivers side fuel lines tighten all of the clamps, the rubber shrink in the cold and the clamps need to be tightened down. just fixed this issue myself. I plan on replaceing one line because it just looks like age has taken its toll, the one under the intake runner drivers front corner. Link to comment Share on other sites More sharing options...
Max Capacity Posted January 10, 2012 Share Posted January 10, 2012 Been talked about here a lot, I used lock wire around that hose on either side of the clamp to stop the leak. It has been working for 2 or 3 years now. I have posted pictures on here about it in these threads. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
rob-2 Posted January 10, 2012 Author Share Posted January 10, 2012 We checked with the subi dealer they aren't covering it on the Legacy's. Thanks for the info guys. Looks like we're going to pay to get it fixed. Link to comment Share on other sites More sharing options...
Max Capacity Posted January 10, 2012 Share Posted January 10, 2012 Just for spite I would not pay them to do it, Tell them your taking the car somewhere else. It's a obvious problem that Subaru doesn't want to cover. I guess they need to have of the car catch on fire before they will, may be admit, there may be, a possible, sometimes not to often, issue... 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
rob-2 Posted January 10, 2012 Author Share Posted January 10, 2012 Just for spite I would not pay them to do it, Tell them your taking the car somewhere else. It's a obvious problem that Subaru doesn't want to cover. I guess they need to have of the car catch on fire before they will, may be admit, there may be, a possible, sometimes not to often, issue... We are taking it somewhere else. I won't pay dealer rates anymore. It doesn't say 'stupid' on my forehead. Link to comment Share on other sites More sharing options...
Berzerklo Posted January 10, 2012 Share Posted January 10, 2012 fuel lines that run under the intake manifold sometimes seep in the cold weather- however I heard it was a recall on bugeye wrx's...not sure about lgt I had a bugeye before my Legacy, and even the recall for the WRX's only covered cars in 'extreme cold climates'... Alaska, Montana, ect. so don't feel too bad about paying to fix it. Link to comment Share on other sites More sharing options...
rob-2 Posted January 10, 2012 Author Share Posted January 10, 2012 It's $500 in work, 3 hoses plus 6 hours labor. Link to comment Share on other sites More sharing options...
Max Capacity Posted January 10, 2012 Share Posted January 10, 2012 No, tell your guy to wrap the hose with .041" lockwire and lockwire the hose tighter. That's all I did, I did not replace any parts. I'll send you the pictures when I get home. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
rob-2 Posted January 10, 2012 Author Share Posted January 10, 2012 No, tell your guy to wrap the hose with .041" lockwire and lockwire the hose tighter. That's all I did, I did not replace any parts. I'll send you the pictures when I get home. It's not just the connections, the actual hoses are cracked. What a shitty design. Link to comment Share on other sites More sharing options...
Max Capacity Posted January 10, 2012 Share Posted January 10, 2012 Oh that sucks. Well they remove the intake manifold to replace the hose ? If so replace the o-rings with the new bigger ones. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
rob-2 Posted January 10, 2012 Author Share Posted January 10, 2012 Oh that sucks. Well they remove the intake manifold to replace the hose ? If so replace the o-rings with the new bigger ones. We'll see what they can do. I guess I'm spoiled. In the last 15 years I've had nothing but regular service on the honda's we've owned. Always sucks to get an unexpected bill like this. Link to comment Share on other sites More sharing options...
rob-2 Posted January 11, 2012 Author Share Posted January 11, 2012 Are there upgraded lines we can run? Maybe a stainless steel line? Link to comment Share on other sites More sharing options...
Max Capacity Posted January 11, 2012 Share Posted January 11, 2012 I don't believe so. I also believe you arethe first I've heard about with the hoses that have cracked. I wonder if someone has ever sprayed some type of cleaner on the engine that wasn't designed for automotive use ? 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
rob-2 Posted January 11, 2012 Author Share Posted January 11, 2012 I don't believe so. I also believe you arethe first I've heard about with the hoses that have cracked. I wonder if someone has ever sprayed some type of cleaner on the engine that wasn't designed for automotive use ? Maybe but in all my years I've never had a fuel lines crack, never mind the fact it appears to be a known issue with Subi. Last thing I had crack with the radiator on a 92 Accord, 2 years into it's life because the part was made thinner than spec. Honda fixed it, and not a problem since - on future cars. This appears to be an ongoing issue. Link to comment Share on other sites More sharing options...
rob-2 Posted January 11, 2012 Author Share Posted January 11, 2012 I'm emailing subaru to cover this. I think this known issue should have a nation wide recall. If it completely failed we could have had a fire. Link to comment Share on other sites More sharing options...
rob-2 Posted January 11, 2012 Author Share Posted January 11, 2012 More on this topic. The new lines you'd replace the lines in our gen are improved. So it's clear subaru knew that this was an issue, put us all at risk and now has fixed the problem. However our local dealer says there is no recall and nothing they can do. If you've had this problem, could you please PM your name/city/state/email? I am considering putting together a massive claim where we all get paid for our problems. Link to comment Share on other sites More sharing options...
pillboy Posted January 11, 2012 Share Posted January 11, 2012 Our Outback stinks when it is REALLY cold out. I keep waiting for the phucker to go up in flames. No such luck yet. It is still ugly. Link to comment Share on other sites More sharing options...
rob-2 Posted January 11, 2012 Author Share Posted January 11, 2012 Our Outback stinks when it is REALLY cold out. I keep waiting for the phucker to go up in flames. No such luck yet. This kind of problem is close to putting in bad brake lines. Companies who have this problem should be held accountable. Link to comment Share on other sites More sharing options...
rob-2 Posted January 12, 2012 Author Share Posted January 12, 2012 Everyone with this problem should be reporting it to Subaru. They are under the impression it only affected 02 and 03 WRX's however as based on the replies here it's clearly more than that. They wont issue a recall until there are enough complaints. Link to comment Share on other sites More sharing options...
Max Capacity Posted January 12, 2012 Share Posted January 12, 2012 I'll have to send them my pictures of my lock wire job. Should we send them to a certain address/email ? 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
rob-2 Posted January 12, 2012 Author Share Posted January 12, 2012 I'll have to send them my pictures of my lock wire job. Should we send them to a certain address/email ? Yes by email - CustDlrServices@subaru.com by fax - (856)488-3299 by mail - Subaru of America, Inc. P.O. Box 6000, Cherry Hill, NJ 08034-6000 Link to comment Share on other sites More sharing options...
Max Capacity Posted January 12, 2012 Share Posted January 12, 2012 That's the info I was looking for. Thanks, 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
