magnoon Posted January 12, 2012 Share Posted January 12, 2012 Coming around a maybe 10-20 degree ish turn at 40 mph (the posted speed limit) yesterday and out of nowhere the tail snaps out on me... in a Subaru... anyways, tried to recoup control but it just slid back the other side then spun me off the rode, hit a metal support cable for a telephone pole. I have michelin pilot sport a/s tires with only 10k miles on them... wth?? So what do you guys think? on to the pics: Link to comment Share on other sites More sharing options...
whitetiger Posted January 12, 2012 Share Posted January 12, 2012 ill say it before someone else does. you cant drive. sorry bout the crash. Link to comment Share on other sites More sharing options...
Max Capacity Posted January 12, 2012 Share Posted January 12, 2012 Have you ever heard of "black ice" ? may be the front tires missed the spot but the rears didn't. You may want to have the alignment checked out by a good shop to see if something broke or is not in great shape in the rear suspension, before you drive it very far after the body shop finishes. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
whitetiger Posted January 12, 2012 Share Posted January 12, 2012 he probably slammed on the brake while trying to counter-steer. doing that will just exacerbate the situation. Link to comment Share on other sites More sharing options...
ShadowImg Posted January 12, 2012 Share Posted January 12, 2012 my vote? lift-off oversteer, followed by exactly what whitetiger said. Link to comment Share on other sites More sharing options...
Max Capacity Posted January 12, 2012 Share Posted January 12, 2012 my vote? lift-off oversteer, followed by exactly what whitetiger said. That's a very good possibility. While driving the spec in the 3/4" of slush this AM while going around curves, I kept thinking, do not lift, maintain a little loading on the suspension, keep all 4 digging for traction. Of course I was going under 30mph too. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
ShadowImg Posted January 12, 2012 Share Posted January 12, 2012 Also, thinking more about 40mph in dry, you either hit something, or you did something excessively weird that you aren't telling us. 20 degrees isn't enough even if you completely lifted and snapped it from 0 to 20 to get the rear end out I don't think. Link to comment Share on other sites More sharing options...
BAC5.2 Posted January 12, 2012 Share Posted January 12, 2012 Pretty sure the car didn't screw you over... Without seeing under the hood, it's tough to say. I'd venture to say that it is not totaled, but it's hard to tell. [URL="http://legacygt.com/forums/showthread.php/proper-flip-key-interesti-159894.html"]Flip Key Development Thread[/URL] "Genius may have its limitations, but stupidity is not thus handicapped." - E. Hubbard Link to comment Share on other sites More sharing options...
Magic Marker Posted January 12, 2012 Share Posted January 12, 2012 Gotta keep the foot on the pedal for the car to do it's job. 2011 Volvo S60T6 & 2013 Volvo XC60T6 Polestar Link to comment Share on other sites More sharing options...
whitetiger Posted January 12, 2012 Share Posted January 12, 2012 FWIW, the LGT does not snap oversteer. the rear usually steps out in a progressive manner. either there was something slippery, or bad driving to start with. Furthermore, the fact that he had a moment where driver input caused the rear to come back the other direction shows that more bad driver input caused the fish-tailing to get worse. conclusion - Bad driving. Link to comment Share on other sites More sharing options...
Moderators BarManBean Posted January 12, 2012 Moderators Share Posted January 12, 2012 I call BS...certain details are being omitted here me thinks. Also, don't think it was cold enough in MD last couple days to form black ice so I think that's out. Maybe nicked a bump in the road that caused the back end to 'hop' a bit (happens to me on the same off ramp every single day) and then panic/snap reactions led to ^^^ Hopefully you can get it fixed, doesn't look totaled...radiator maybe though, never good. "Bullet-proof" your OEM TMIC! <<Buy your kit here>> Not currently in stock Link to comment Share on other sites More sharing options...
magnoon Posted January 12, 2012 Author Share Posted January 12, 2012 it was a drizzly day here in MD. All i wanted was some input on the condition of the car. I already know that the mistake was mine, I don't need people emphasizing the fact. The situation is rough enough as it is. Thanks, Chris Link to comment Share on other sites More sharing options...
cypher0117 Posted January 12, 2012 Share Posted January 12, 2012 Glad you are ok. I don't think it's totaled, but it's hard to tell without looking in the engine bay. A similar thing happened to me about 2 years ago. It was freezing rain and high winds. I crested a hill and hit black ice. Car went sideways and kept sliding until I hit the gas. The car pulled through and fishtailed a bit but I somehow stayed on the road. If I would have hit the brakes I would have slide drivers side right into a wall of trees at ~35mph (speed limit was 50). As crappy as the situation is...you should feel lucky that cable wasn't near your door. Those high tension cable can slice through almost anything Link to comment Share on other sites More sharing options...
AShoe Posted January 12, 2012 Share Posted January 12, 2012 You suck at driving. AWD doesn't help if you're going too fast for icy conditions. When the back end started to slide you hit the brakes. That was the wrong reaction and caused you to spin. Link to comment Share on other sites More sharing options...
magnoon Posted January 12, 2012 Author Share Posted January 12, 2012 You suck at driving. AWD doesn't help if you're going too fast for icy conditions. When the back end started to slide you hit the brakes. That was the wrong reaction and caused you to spin. This was already covered. Thank you very much for the kind comment. Also, I found this video by consumer reports. I am in no way to cover up my driver fault, I'm just sharing what I came across. http://www.consumerreports.org/cro/video-hub/cars/sedans--hatchbacks/subaru-legacy-2008-review/14684540001/1352465487/ Chris Link to comment Share on other sites More sharing options...
ShrinerMonkey Posted January 12, 2012 Share Posted January 12, 2012 All Season tires + driving too fast + Subaru lift off oversteer = crash AWD does not = safety, it just helps you go. Get some winter tires and learn to drive in slippery conditions or just stay home. Link to comment Share on other sites More sharing options...
sheps58 Posted January 12, 2012 Share Posted January 12, 2012 The best and most experienced drivers can get into accidents. Even veteran airline pilots get into situations they did not expect and can not handle. Look at flight 587 in which an American Airline pilot snaped off the planes vertical stabilizer. Link to comment Share on other sites More sharing options...
magnoon Posted January 12, 2012 Author Share Posted January 12, 2012 another question is that is it possible that the insurance wont cover me since i have an fmic w/ an aftermarket bumper beam?? Link to comment Share on other sites More sharing options...
PearlBlueGT Posted January 12, 2012 Share Posted January 12, 2012 I wouldn't say your car is totalled. I still think every tire should be siped to achieve maximum grip, especially in black ice. Link to comment Share on other sites More sharing options...
ShrinerMonkey Posted January 12, 2012 Share Posted January 12, 2012 another question is that is it possible that the insurance wont cover me since i have an fmic w/ an aftermarket bumper beam?? Doubt it. They won't cover the cost to replace your aftermarket parts, they will quote you the price to replace with OEM parts. Link to comment Share on other sites More sharing options...
magnoon Posted January 12, 2012 Author Share Posted January 12, 2012 none of my aftermarket parts were damaged, i was just wondering if they wouldn't cover me because the car is modified... Link to comment Share on other sites More sharing options...
planelazy Posted January 12, 2012 Share Posted January 12, 2012 You're confusing insurance with a warranty. Link to comment Share on other sites More sharing options...
Max Capacity Posted January 12, 2012 Share Posted January 12, 2012 I still think every tire should be siped to achieve maximum grip, especially in black ice. Is that even possible, unless you have studded tires ? This is when you need to know how to drive in unsafe conditions. Slow down. Use your head. I told my son before he got his license. In bad conditions, It's about getting there, not getting there first. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
compsurge Posted January 12, 2012 Share Posted January 12, 2012 Had a similiar incident in the rain turning into the suicide lane in a 4 lane highway. Kept the foot planted on the gas until it sorted out. Insurance will cover what you have claimed with them (if you added insurance to cover mods, then yes). Your rate will reflect those parts in your policy. Link to comment Share on other sites More sharing options...
Polo08816 Posted January 12, 2012 Share Posted January 12, 2012 You suck at driving. AWD doesn't help if you're going too fast for icy conditions. When the back end started to slide you hit the brakes. That was the wrong reaction and caused you to spin. Dude, if the poster has already admitted that may have contributed to the incident then there's no reason to harp on it. The poster is in touch with reality. Give him a chance to come up with a solution for himself. Link to comment Share on other sites More sharing options...
