firehawk618 Posted June 6, 2014 Share Posted June 6, 2014 I posted some of this when I first got my car but sat down and played with it a bunch today. With the right scantool you can make a bunch of adjustments and thought I'd share the most relevant ones. What made my play with it today was that I had noticed my alarm didn't work. I'd arm the car, wait a few mins, reach in and open the door and nothing happened. After booting up the tool and selecting the right car here's the first screen I am greeted with. This is after it "auto scans" the car for various modules. It only lists modules that respond to the meter's *ping* via the obdii port. http://i80.photobucket.com/albums/j193/firehawk618/Cars/2006%20Legacy%20GT%20Wagon/IMG_20140606_154113_zps0lz3oxs5.jpg After selecting "integ unit mode" which is the BCM this is what I get: http://i80.photobucket.com/albums/j193/firehawk618/Cars/2006%20Legacy%20GT%20Wagon/IMG_20140606_154130_zpskfnxxnng.jpg Next I select "ECU Customizing" as this is where you can change variables: http://i80.photobucket.com/albums/j193/firehawk618/Cars/2006%20Legacy%20GT%20Wagon/IMG_20140606_154139_zpsmapqz81z.jpg Now I have 3 pages of things that can be changed. As you can see damned near every feature can be turned on, off or adjusted. http://i80.photobucket.com/albums/j193/firehawk618/Cars/2006%20Legacy%20GT%20Wagon/IMG_20140606_154139_zpsmapqz81z.jpg http://i80.photobucket.com/albums/j193/firehawk618/Cars/2006%20Legacy%20GT%20Wagon/IMG_20140606_154143_zpsob4nmoqy.jpg http://i80.photobucket.com/albums/j193/firehawk618/Cars/2006%20Legacy%20GT%20Wagon/IMG_20140606_154148_zps65b8cdoy.jpg I discovered on the last page when I selected "security setup" mine was disabled for some reason. I enabled it then tested and now my security system alarms when the door is opened and stuff like that. Though I'd share. 10' CTS-V, A6, Airraid, 2.4 upper, ID850's, self tuned. SOLD:06' LGT Wagon. BNR16G, Catless UP, DOWN, Hexmods VB, Hexmods diff bushings, BIG TMIC. Best 0-60: 4.651 by AP 1/4= 13.678@100.73 mph, 1.945 60', Automatic transmission. Link to comment Share on other sites More sharing options...
theflystyle Posted June 6, 2014 Share Posted June 6, 2014 I remember having to go to the dealer to use the Subaru Select Monitor for the alarm shock sensor I installed. It seems like it would have some potential but that thing is like $800+ Link to comment Share on other sites More sharing options...
Max Capacity Posted June 6, 2014 Share Posted June 6, 2014 Nice but can it fix the stupid seat belt chime ? That's all that really matters...LOL 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
ssbtech Posted June 6, 2014 Share Posted June 6, 2014 All the things Subaru should have made available on the NAV screen. I'm surprised we don't have some open source Windows software we can use. God knows there's enough ECU tuning applications available. Link to comment Share on other sites More sharing options...
firehawk618 Posted June 7, 2014 Author Share Posted June 7, 2014 Nice but can it fix the stupid seat belt chime ? That's all that really matters...LOL LOL now that I did not see in there. I was able to turn off the auto lock, change my front/rear defrost to always one vs timed, program a spare fob *EASILY vs the morse code* and a few other annoying things though. 10' CTS-V, A6, Airraid, 2.4 upper, ID850's, self tuned. SOLD:06' LGT Wagon. BNR16G, Catless UP, DOWN, Hexmods VB, Hexmods diff bushings, BIG TMIC. Best 0-60: 4.651 by AP 1/4= 13.678@100.73 mph, 1.945 60', Automatic transmission. Link to comment Share on other sites More sharing options...
MrTris Posted June 7, 2014 Share Posted June 7, 2014 What's the device/download? Link to comment Share on other sites More sharing options...
BMG905 Posted June 8, 2014 Share Posted June 8, 2014 Really, what scanner is that? And what other makes/models does it work with? And of course, $? Link to comment Share on other sites More sharing options...
firehawk618 Posted June 8, 2014 Author Share Posted June 8, 2014 Launch x431. Does all makes and models. Thing is some makes it does more than others. Was about 2300. Not a clone. 10' CTS-V, A6, Airraid, 2.4 upper, ID850's, self tuned. SOLD:06' LGT Wagon. BNR16G, Catless UP, DOWN, Hexmods VB, Hexmods diff bushings, BIG TMIC. Best 0-60: 4.651 by AP 1/4= 13.678@100.73 mph, 1.945 60', Automatic transmission. Link to comment Share on other sites More sharing options...
Max Capacity Posted June 9, 2014 Share Posted June 9, 2014 LOL now that I did not see in there. I was able to turn off the auto lock, change my front/rear defrost to always one vs timed, program a spare fob *EASILY vs the morse code* and a few other annoying things though. What about turning off the tpms ? The other thing some of us would like to turn off. I will confuess, the Spec B's tpms did let me know I hada issue, I have a slow leak it one tire, I just had to find which one it was. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
theflystyle Posted June 11, 2014 Share Posted June 11, 2014 ^ I think I read that is a different computer all together and may not be able to be modified through the OBDII ?? Link to comment Share on other sites More sharing options...
firehawk618 Posted June 12, 2014 Author Share Posted June 12, 2014 What about turning off the tpms ? The other thing some of us would like to turn off. I will confuess, the Spec B's tmps did let me know I hada issue, I have a slow leak it one tire, I just had to find which one it was. It does list TPMS in the list of modules BUT my car doesn't have it so I cannot say what you can or can't do. I have a feeling that if the dealer can disable it via scantool then this can also. 10' CTS-V, A6, Airraid, 2.4 upper, ID850's, self tuned. SOLD:06' LGT Wagon. BNR16G, Catless UP, DOWN, Hexmods VB, Hexmods diff bushings, BIG TMIC. Best 0-60: 4.651 by AP 1/4= 13.678@100.73 mph, 1.945 60', Automatic transmission. Link to comment Share on other sites More sharing options...
Drift Motion Posted June 12, 2014 Share Posted June 12, 2014 hmm interesting...someone I know started this company "Launch" for these scan tools Link to comment Share on other sites More sharing options...
jabz Posted June 15, 2014 Share Posted June 15, 2014 Launch x431. Does all makes and models. Thing is some makes it does more than others. Was about 2300. Not a clone. $2300? Where did you get it from? This site has it for $399? Link to comment Share on other sites More sharing options...
