LegGtBK97 Posted May 11, 2014 Share Posted May 11, 2014 So I just put in the raceland coilovers ultimos. . And it was a pretty straight forward install. But when i go to do the alignment. The rear has to much positive camber. Is there something I did wrong during the install? Has anyone else encountered this issue before? And I dont seem to see a camber adjustment on the rear coilovers or stock suspension in the rear . Any help would be a appreciated..thanks guys Sent from my SAMSUNG-SGH-I747 using Tapatalk Link to comment Share on other sites More sharing options...
spooln30 Posted May 12, 2014 Share Posted May 12, 2014 So the rear coil over pillow mount is non adjustable? Are you doing the alignment by eye or on a alignment rack? Link to comment Share on other sites More sharing options...
LegGtBK97 Posted May 12, 2014 Author Share Posted May 12, 2014 I didnt see a camber plate on it like the ones in the front... i used an alignment rack... Sent from my SAMSUNG-SGH-I747 using Tapatalk Link to comment Share on other sites More sharing options...
LegGtBK97 Posted May 12, 2014 Author Share Posted May 12, 2014 Can anyone tell me or post a pic of there rear camber bolts( want to see where i would be installing them) i might just opt out and get some if i can't adjust the rear camber from the top of the coils Sent from my SAMSUNG-SGH-I747 using Tapatalk Link to comment Share on other sites More sharing options...
cal71919 Posted May 12, 2014 Share Posted May 12, 2014 The top bolt that mounts the strut to the knuckle is camber bolt. The top hole where the bolt passes through on the strut and knuckle is elongated. Link to comment Share on other sites More sharing options...
LegGtBK97 Posted May 13, 2014 Author Share Posted May 13, 2014 And thats for the rear yes? Sent from my SAMSUNG-SGH-I747 using Tapatalk Link to comment Share on other sites More sharing options...
LegGtBK97 Posted May 13, 2014 Author Share Posted May 13, 2014 So I emailed the guys over at raceland. And the told me that the higher the car is the more positive camber ill have.. but im lower then stock height... so why am I getting this issue. And no the rear coils are not camber adjustable. Sent from my SAMSUNG-SGH-I747 using Tapatalk Link to comment Share on other sites More sharing options...
DJBRANDER Posted May 13, 2014 Share Posted May 13, 2014 Loosen the two bolts holding the rear coils onto the knuckles, push the top of the coilover towards the inside of the car, tighten, go back to whatever alignment shop you took it to. Slap them across the face for not being able to figure it out. Also, I ended up hating my racelands. GREASE THE THREADS ON THE COILS or it will seize, despite what the companies website says "powder coated threads to resist rusting" yeah... bullshit. 2 of my coils seized and they refused to replace it under the 2 year warranty, and mine were on the car just for a year. Link to comment Share on other sites More sharing options...
legacydh Posted May 13, 2014 Share Posted May 13, 2014 Absolutely grease them. It tells you to right on the packaging but definitely heed their warning. Link to comment Share on other sites More sharing options...
LegGtBK97 Posted May 14, 2014 Author Share Posted May 14, 2014 Well thank you Djbrander but i did it at the shop i work at. But i appreciate the input.. well definitely make the change this weekend... i should've done that from the start... i was working on limited time so it must've slipped my mind.. Sent from my SAMSUNG-SGH-I747 using Tapatalk Link to comment Share on other sites More sharing options...
twisty Posted May 14, 2014 Share Posted May 14, 2014 Absolutely grease them. It tells you to right on the packaging but definitely heed their warning. i didnt see anything on the packaging about that. but, i also dont really worry about it, living in the desert. Link to comment Share on other sites More sharing options...
legacydh Posted May 15, 2014 Share Posted May 15, 2014 Yeah. There was a little piece of paper in with the boxes that gave you a web address and a 3 pointers, one of them being grease the threads or it voids the warranty. Living in the North East, I need the grease. lol Link to comment Share on other sites More sharing options...
twisty Posted May 15, 2014 Share Posted May 15, 2014 my little piece of paper must have fallen out at their factory, i still have the box in my living room. except for their "instruction sheet" i saw no other papers. the instructions did explain the preload and how to adjust, but nothing else. not even an explanation for all the stuff they include in the package, or a parts list. Link to comment Share on other sites More sharing options...
DJBRANDER Posted May 15, 2014 Share Posted May 15, 2014 Same here. Never said to grease them. But on their website it states: "The Ultimo shock body is powder coated for an extra level of surface corrosion resistance. The coil springs are epoxy powder coated to increase the life of the springs." All my springs are rusted to shit, and everything is frozen. http://www.racelandus.com/coilovers/subaru-coilover-kits/subaru-impreza-wrx-gd-ultimo-coilovers.html Link to comment Share on other sites More sharing options...
LegGtBK97 Posted May 18, 2014 Author Share Posted May 18, 2014 Just wanted to give an update after go back to the shop and looking at the strut bolts as djbrander mentioned I then proceeded to adjust them accordingly. Thanks for help guys Im still going to get the camber bolts though. Just to dial in the alignment right Sent from my SAMSUNG-SGH-I747 using Tapatalk Link to comment Share on other sites More sharing options...
DJBRANDER Posted May 19, 2014 Share Posted May 19, 2014 no problem! Glad it worked! Link to comment Share on other sites More sharing options...
