SubiNADubi Posted September 12, 2013 Share Posted September 12, 2013 I have a 98 legacy 2.5 gt. I had been driving close to empty for a while on the gas but today I filled the tank. I did not over fill it. when the pump shut off I stopped. I started the car and drove aabout a block away and it died. now it starts but as soon as it goes to idle it chugs out and dies. I thought it might be the fuel filter from running it so low for so long so I changed it. no ddifference. so then I changed the fuel pump and still nothing. but when you do start it and blow some break cleaner into the air intake it revs up and runs great. as soon as you stop spraying it dies. please post any ideas. all fuses are good as well. Link to comment Share on other sites More sharing options...
AZP Installs Posted September 16, 2013 Share Posted September 16, 2013 Sounds like you have some kind of Vacuum leak in there. -Mike Paisan http://www.pbase.com/paisan/image/91072632.jpg http://www.pbase.com/paisan/image/145749898/original.jpg http://www.pbase.com/paisan/image/133406601.jpg http://www.whiteline.com.au/images/logos/perf1.jpg 11+ Years Maintaining, Modifying and Educating TriState Subaru Enthusiasts. Now we have an Online Catalog where you can purchase Parts! AZPParts.com Like us on Facebook! | E-mail: sales@azpinstalls.com | 725 Fairfield Ave | Kenilworth, NJ 07033 | 908.248.AZP1 (2971) |AIM: AZP Installs "Race Tested, Enthusiast Approved!" Link to comment Share on other sites More sharing options...
Max Capacity Posted September 16, 2013 Share Posted September 16, 2013 Could be as simple as a vacuum hose fell off. Look around or find a way to put a short blast of air in the vacuum system, or have a garage do a smoke test to find the leak. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
heiche Posted September 18, 2013 Share Posted September 18, 2013 is it possible that u filled with diesel by mistake? BtSsm - Android app/Bluetooth adapter. LV, logging, gauges and more. For 05-14 Legacy (GT, 2.5, 3.0, 3.6), 02-14 WRX, 04-14 STi, 04-14 FXT, 05-09 OBXT Link to comment Share on other sites More sharing options...
