Waxiboy Posted November 8, 2017 Share Posted November 8, 2017 Waxiboy, which paint shop did you select? JC Auto here in LoCo....I pass by it on the way home from work so it is convenient...great price too! Great opportunity to delete the license plate mounts, if a front plate isn’t required in your state. Unfortunately VA isn't one one of them Link to comment Share on other sites More sharing options...
WRX USA Posted November 8, 2017 Share Posted November 8, 2017 Guys, I can't remember.... I have a rear jdm outback bumper that I have yet to paint and install . I understand that my rear usdm bumper beam will not work. I also recall that if I plan to keep that beam, I need to remove the foam part. Now, what modification do I need to do to that beam in order for the bumper to fit? Is it a matter of cutting the ends or something so that the exhaust cut outs fit? I went with the USDM LGT sedan beam which fit underneath the skin with no problems but I haven’t been able to fit the foam, although I didn’t spend a lot of time on it after I got it on without the foam. The problem with the OBXT beam is the height, since it is not designed for exhaust cut outs. Link to comment Share on other sites More sharing options...
xt2005bonbon Posted November 8, 2017 Share Posted November 8, 2017 thanks for the info. so sedan beam right, not legacy wagon beam. Link to comment Share on other sites More sharing options...
WRX USA Posted November 8, 2017 Share Posted November 8, 2017 thanks for the info. so sedan beam right, not legacy wagon beam. I’m not sure about Legacy wagon beam. Link to comment Share on other sites More sharing options...
savethewagons Posted November 8, 2017 Share Posted November 8, 2017 Great opportunity to delete the license plate mounts, if a front plate isn’t required in your state. Or even if it is required [emoji56] Sent from my iPhone using Tapatalk Link to comment Share on other sites More sharing options...
Infosecdad Posted November 8, 2017 Share Posted November 8, 2017 thanks for the info. so sedan beam right, not legacy wagon beam. According to this thread legacy wagon and sedan beams are the same. http://legacygt.com/forums/showthread.php/jdm-rear-bumper-bp-wagon-260797.html?p=5609448 Link to comment Share on other sites More sharing options...
xt2005bonbon Posted November 9, 2017 Share Posted November 9, 2017 (edited) Did not think of checking opposedforces... Here is the link. Click 'Usage information' on that page and you will see the complete list of cars that use this beam. It confirms what you are saying Infosecdad. Let me quote this from Scooby2.5: 2. Order the Aluminum back beam, brackets and Energy Absorber foam for a 2008 LegacyGT Sedan Part # 57712AG08A Beam Part # 57705AG26A Energy Absorber Foam (YOU CANNOT USE THIS SO DO NOT ORDER IT. STILL TOO THICK FOR THE JDM BUMPER SKIN) JUST PUT SKIN ON OVER THE BEAM AND IT WILL FIT PERFECT! UPDATED 9-14-2007 Part # 57714AG02A9P Right Hand Beam Bracket Part # 57714AG03A9P Left Hand Beam Bracket WRX USA, just to confirm, you did not need these L/R Beam brackets correct? Edited November 9, 2017 by xt2005bonbon Link to comment Share on other sites More sharing options...
WRX USA Posted November 9, 2017 Share Posted November 9, 2017 (edited) Mine came with the brackets and I think you need them because they are designed to work with the shorter (height wise, not length wise) beam. I bought it used on eBay. Edited November 9, 2017 by WRX USA Link to comment Share on other sites More sharing options...
xt2005bonbon Posted November 9, 2017 Share Posted November 9, 2017 I see. thank you. Link to comment Share on other sites More sharing options...
Infosecdad Posted November 9, 2017 Share Posted November 9, 2017 I installing my JDM LGT rear wagon bumper on this weekend, let me know if you need any specific pictures or measurements. Link to comment Share on other sites More sharing options...
Waxiboy Posted November 9, 2017 Share Posted November 9, 2017 I installing my JDM LGT rear wagon bumper on this weekend, let me know if you need any specific pictures or measurements. are you gutting your beam to make it work or taking it out completely? Link to comment Share on other sites More sharing options...
Infosecdad Posted November 9, 2017 Share Posted November 9, 2017 Good question, I've read conflicting accounts and haven't actually found a walkthrough for it. I'll start with the beam (no foam) and see what happens. If the beam only needs a bit of work, then I'll probably do that, if it needs to get mostly tore up, then I'll probably just remove it so I have the option of putting it back. The front only required the foam removed and corners shaved by a sabersaw, we'll see what happens for the rear. Link to comment Share on other sites More sharing options...
famaya26 Posted November 9, 2017 Share Posted November 9, 2017 You will need an EDM beam if you want to run one. http://legacygt.com/forums/showthread.php/05-legacy-bp5-gt-limited-07-jdm-bp5-legacy-tuned-259525p21.html?t=259525&page=21 Link to comment Share on other sites More sharing options...
WRX USA Posted November 9, 2017 Share Posted November 9, 2017 http://legacygt.com/forums/showpost.php?p=5670775&postcount=280 There is definitely a difference in the JDM Outback Bumper and the JDM legacy Wagon one. The JDM outback is similar to the EDM/AUS so it can use the EDM rear beam or the USDM sedan one. But the JDM Legacy Wagon bumper cannot. So as I mentioned, I will cut the EDM beam and use it. Link to comment Share on other sites More sharing options...
Infosecdad Posted November 9, 2017 Share Posted November 9, 2017 Yeah, he said he could only use the EDM if he cut it. I might be completely removing mine or cutting the USDM bumper. Link to comment Share on other sites More sharing options...
magnusonsubie Posted November 11, 2017 Share Posted November 11, 2017 You'd have to cut the USDM one almost completely for it to work. I looked into it when I did mine. Then I just decided no crash beam and I'll be fine. 2005 Vader Wagon Material Tests on Ringland Failure Piston I should have held off and purchased a wagon instead of the spec.B Link to comment Share on other sites More sharing options...
Infosecdad Posted November 12, 2017 Share Posted November 12, 2017 Got the JDM bumper installed today. As mentioned before, I just removed my crash beam for now. I'll build/cut a thin one at a later date/time. I love the lines now, the rear is nicely tucked. This is the way they should always have been. The HKS Silent Hi-Power fit perfectly now, with reduced cabin noise (and smell). It's almost too quiet, might have to consider the HKS (or other) mid-pipe some day. Pull the taillights and the two plastic pins on each corner. On each side, pull the plug and remove the small bolt, there is a second on the inside, underneath behind the wheel well cover (you have to peel the cover back from the rear of the well and feel in there for a 10mm bolt.) Bumper cover off and bumper beam removed. Dry fitting the new bumper Replacement bumper didn't have the two metal braces, so I drilled out the rivets on me USDM bumper and re-riveted to the JDM bumper. All done and installed. Love the look and difference all around. (yes, it's a slightly different white and will be for a while) Now I can really see the 120mm Hi-Power and they aren't hidden under the bumper. Also got a custom plate delete for the front. Link to comment Share on other sites More sharing options...
Waxiboy Posted November 13, 2017 Share Posted November 13, 2017 Got the JDM bumper installed today. As mentioned before, I just removed my crash beam for now. I'll build/cut a thin one at a later date/time. Would a simple aluminum bar attached to the bumper beam mounts work? Kinda like a poor man's version of the Beatrush brace. Link to comment Share on other sites More sharing options...
Blackbeard Posted November 14, 2017 Share Posted November 14, 2017 Hey guys would I be able to swap just the Jdm hid headlights into my 07 LGT or would I also need to replace the entire front end for proper fitment? (Outside of modifying the projector for LHD roadz) I've been reading for definitive answer for a few days and it's a bit confusing to find a solid answer. Link to comment Share on other sites More sharing options...
famaya26 Posted November 14, 2017 Share Posted November 14, 2017 If facelift, no, prefacelift yes. Link to comment Share on other sites More sharing options...
Infosecdad Posted November 14, 2017 Share Posted November 14, 2017 Would a simple aluminum bar attached to the bumper beam mounts work? Kinda like a poor man's version of the Beatrush brace. Yeah, I'm probably going to use some level of bar. It does need to be curved though to follow the contours, I'll get to it at a later time :-) Link to comment Share on other sites More sharing options...
BL5BO Posted November 21, 2017 Share Posted November 21, 2017 So i have an 06 with Rev a-c jdm Spec B front end (bumper bar/headlight brackets). However the rev d-f is really growing on me. Will this bolt up to my 06? My "Alpine White" 06 LGT: The Kabigon [sIGPIC][/sIGPIC] Link to comment Share on other sites More sharing options...
famaya26 Posted November 21, 2017 Share Posted November 21, 2017 So i have an 06 with Rev a-c jdm Spec B front end (bumper bar/headlight brackets). However the rev d-f is really growing on me. Will this bolt up to my 06? You will need the JDM Fenders, JDM lights and brackets, as well as the fender liners. Link to comment Share on other sites More sharing options...
Waxiboy Posted November 21, 2017 Share Posted November 21, 2017 Color match fail, rest of car looks yellow-er/darker than bumper. That being said, my car hasn't seen any paint care product in over 3 years . I will need to clay, compound, polish and wax to be able to judge how far off the color is. Side question: Is there a way to make the headlight motors move without the leveling switch? My right side is higher than the left. Link to comment Share on other sites More sharing options...
famaya26 Posted November 22, 2017 Share Posted November 22, 2017 Color match fail, rest of car looks yellow-er/darker than bumper. That being said, my car hasn't seen any paint care product in over 3 years . I will need to clay, compound, polish and wax to be able to judge how far off the color is. Side question: Is there a way to make the headlight motors move without the leveling switch? My right side is higher than the left. They have manual bolts you can use to adjust them. Link to comment Share on other sites More sharing options...
