guisar Posted November 11, 2011 Share Posted November 11, 2011 I'd like to find extended PID for oil temperature, pressure etc to use in the Torque application. Anyone know where these can be found- my google skills are evidently not up to the task. I have a 2005 LGT but I assume these are relatively generic to subarus. Link to comment Share on other sites More sharing options...
Max Capacity Posted November 11, 2011 Share Posted November 11, 2011 OK I'll bite, http://www.ncbi.nlm.nih.gov/pubmedhealth/PMH0001890/ Is that what your asking about ? Sounds like you want to monitor oil temp and pressure. I don't understand your reference to a Torque application ? I'm old school and like direct reading gages better then some new fangled electronic gages. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
shutterbc Posted November 11, 2011 Share Posted November 11, 2011 I believe he means: Torque Android application: http://www.appbrain.com/app/torque-pro-(obd2-car)/org.prowl.torque In OBD speak, PID stands for Parameter ID: http://en.wikipedia.org/wiki/OBD-II_PIDs And good luck, I haven't tried that because I'm lazy and just use my Tactrix cable instead. Though I have toyed with the idea of getting a Bluetooth OBD reader and datalogging on my smartphone. That would be a bit easier than using my netbook. Link to comment Share on other sites More sharing options...
shutterbc Posted November 11, 2011 Share Posted November 11, 2011 Darn it, I forgot a point. The caveat there is that apps like Romraider use SSM protocol and don't use OBD to poll the data. So you may be running into a roadblock there. Might be worth reading through the Romraider forums or striking up a conversation over there. Link to comment Share on other sites More sharing options...
Max Capacity Posted November 12, 2011 Share Posted November 12, 2011 Thanks for the links, I understand now. Wow if you can really get all that info from the OBDII port, why hasn't someone come out with a gauge set that uses that ? 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
RabidWombat Posted November 12, 2011 Share Posted November 12, 2011 Thanks for the links, I understand now. Wow if you can really get all that info from the OBDII port, why hasn't someone come out with a gauge set that uses that ? Not all cars support all parameters. As for a gauge, Garmin EcoRoute HD, [ame=http://www.amazon.com/gp/product/B003CLYMSU/ref=pd_lpo_k2_dp_sr_1?pf_rd_p=486539851&pf_rd_s=lpo-top-stripe-1&pf_rd_t=201&pf_rd_i=B00313JWSO&pf_rd_m=ATVPDKIKX0DER&pf_rd_r=06DKD98JP8X6SVMVX6JP]Amazon.com: Garmin ecoRoute HD Vehicle Diagnostics Communicator HD: GPS & Navigation[/ame] Link to comment Share on other sites More sharing options...
xt2005bonbon Posted November 12, 2011 Share Posted November 12, 2011 subscribed Link to comment Share on other sites More sharing options...
shutterbc Posted November 12, 2011 Share Posted November 12, 2011 There are tools that use the OBDII data and display it. One of the more popular models is the ScanGauge. There is also the UltraGauge. The Torque application for Android works in a similar way and is gaining traction (no pun intended). I think it's awesome that they have a wiki: http://torque-bhp.com/wiki/Main_Page According to the changelog there is SSM support (though I don't know if that is used since the readers would have to support it) and the iwsti folks have used it succesfully. Cool stuff. Link to comment Share on other sites More sharing options...
Mega Users seabass07 Posted November 12, 2011 Mega Users Share Posted November 12, 2011 Your only options are to use a drain plug oil temp sensor and gauge or a computer running a program that uses ssm to get info from the ecu. As far as i know there is no way to access that through a typical obd2 reader. What we need to do is get someone with a bit of linux experience to port freessm or romraider to android. They are already working in linux. Link to comment Share on other sites More sharing options...
Mega Users seabass07 Posted November 12, 2011 Mega Users Share Posted November 12, 2011 Apparently dashdaq has the pid you need. Im sure you have to buy their shit though. http://www.dashdaq.com/specs/datalists/subaru.htm Edit...nvm. it looks like its just a generic pid. Probably wont work. Link to comment Share on other sites More sharing options...
shutterbc Posted November 12, 2011 Share Posted November 12, 2011 Linux experience? At that level it's all Java as far as I can tell. Link to comment Share on other sites More sharing options...
ehsnils Posted November 12, 2011 Share Posted November 12, 2011 You may also find some useful info over here: http://subdiesel.wordpress.com/ It's for the diesel, but it has some interesting general stuff too. Link to comment Share on other sites More sharing options...
guisar Posted November 12, 2011 Author Share Posted November 12, 2011 Apparently dashdaq has the pid you need. Im sure you have to buy their shit though. http://www.dashdaq.com/specs/datalists/subaru.htm Edit...nvm. it looks like its just a generic pid. Probably wont work. If you go to the brand specific page (http://www.dashdaq.com/specs/datalists/subaru.htm) there is a TON more info including oil temp and pressure) which is available. I already use Torque on a tablet for the basic stuff and it allows you to add new data if you know the extended PID info. I am still figuring someone here must know these or where to get them. Link to comment Share on other sites More sharing options...
Mega Users seabass07 Posted November 12, 2011 Mega Users Share Posted November 12, 2011 Linux experience? At that level it's all Java as far as I can tell. My point is to get the linux version of romraider or freessm working in android. I figure the linux version would be easier since android is linux. Link to comment Share on other sites More sharing options...
shutterbc Posted November 13, 2011 Share Posted November 13, 2011 I was just checking through vacation pix for something else, and decided to check for the existence of an oil pressure sensor. Looks like our LGTs just have oil pressure switches. That might explain why we don't have a PID for oil pressure. Link to comment Share on other sites More sharing options...
Metal2You Posted March 8, 2012 Share Posted March 8, 2012 Bump/Sub. I also want a list of the OBD PID's. I just got a bluetooth OBDII reader and the Torque app. It is working fine, but I need to program in some extended PID's for things like : Knock Correction Dynamic Advance Dynamic Advance Multiplier A/F Trim Current A/F Trim Learned WGDC Thanks. Link to comment Share on other sites More sharing options...
NutBucket Posted March 9, 2012 Share Posted March 9, 2012 I was just checking through vacation pix for something else, and decided to check for the existence of an oil pressure sensor. Looks like our LGTs just have oil pressure switches. That might explain why we don't have a PID for oil pressure. Sounds about right. You have to add you own oil pres/temp senders if you want to monitor those parameters. Link to comment Share on other sites More sharing options...
xt2005bonbon Posted June 20, 2012 Share Posted June 20, 2012 Did you get the PID info you were looking for? I'd like to do the same. Link to comment Share on other sites More sharing options...
lilbrudder Posted July 20, 2012 Share Posted July 20, 2012 Looking for the same, any progress? Link to comment Share on other sites More sharing options...
xt2005bonbon Posted July 20, 2012 Share Posted July 20, 2012 Bump/Sub. I also want a list of the OBD PID's. I just got a bluetooth OBDII reader and the Torque app. It is working fine, but I need to program in some extended PID's for things like : Knock Correction Dynamic Advance Dynamic Advance Multiplier A/F Trim Current A/F Trim Learned WGDC Thanks. Link to comment Share on other sites More sharing options...
