440cc injectors
I've got a p303 & 304 code. Plugs, wires & coil all look fine. Dumped some injector cleaner in the tank a couple weeks ago and still no change.I read about moving the injectors around to see if the misfire moves with them & I'd like to know if the wrx 440cc injectors will drop right in to my ej25. I found some locally for $50 but I want to know they'll work before buying.
it's your coil or the igniter. the 3 & 4 cylinders share the same side of the coil, the rear. i would check to make sure the igniter is doing its job but i'm betting on the coil.
i don't know how to test it.
get a used one.
