2006 SpecB Posted May 20, 2013 Share Posted May 20, 2013 I am original owner of my babied 2006 Spec B and I think the struts are shot. Any bump I hit seems to be harsh. What are the options for replacing these? I looked online and to replace with stock OEM parts is like $1600 before labor. Anywhere to purchase cheaper? Any aftermarket ones work better and give the same ride height? I have seen the Bilstein HDs on some Legacys and they just dont sit right. I want this to be as identical to stock as possible. Or is it time for me to sell the Spec B? Link to comment Share on other sites More sharing options...
idiot4hire Posted May 20, 2013 Share Posted May 20, 2013 Lol at selling a car over struts. Get koni's they are a better option and they are adjustable. Do a little searching I know you will need a few more parts then a non spec b, but still much cheaper then new bilsteins. Link to comment Share on other sites More sharing options...
idiot4hire Posted May 20, 2013 Share Posted May 20, 2013 Get in touch with a vender like azp installs they can get you all the parts you would need Link to comment Share on other sites More sharing options...
robitrice Posted May 20, 2013 Share Posted May 20, 2013 ill buy the spec b for what it would cost to fix ur suspension issues Link to comment Share on other sites More sharing options...
S402 Posted May 20, 2013 Share Posted May 20, 2013 You could get themrebuilt by bilstein but you would need to park the car or get temporary springs and struts to use while they are getting rebuilt. Link to comment Share on other sites More sharing options...
2006 SpecB Posted May 21, 2013 Author Share Posted May 21, 2013 I hope no one took me seriously on selling it, unless you wanted to offer $13k. Anyways, I am torn between a rebuild or an all new buy. For Koni I am nervous the car wont ride the same or sit at a funny height like I have seen with Bilstein HDs. Let me do some research, thanks for the suggestions. Link to comment Share on other sites More sharing options...
whitetiger Posted May 21, 2013 Share Posted May 21, 2013 FWIW, struts are easy to replace in the driveway, so you could eliminate your labor costs that way. As for the car sitting different on HD's, that wont happen. HD's are the same, dimension wise, compared to the stock bils and since you arent changing springs, it should not be an issue. the cars you see not sitting right with HD's are mostly people who put non-spec b springs with them. Aftermarket springs designed to the LGT shock will not sit the same on HD's. Link to comment Share on other sites More sharing options...
2006 SpecB Posted May 21, 2013 Author Share Posted May 21, 2013 Is there a need to replace the springs too? Or normally are they ok? Link to comment Share on other sites More sharing options...
scoobyscoodle Posted May 21, 2013 Share Posted May 21, 2013 Springs are fine unless you want to lower the car a bit. If not, the ride quality is pretty awesome on oem springs and Koni's. Link to comment Share on other sites More sharing options...
2006 SpecB Posted May 21, 2013 Author Share Posted May 21, 2013 Which koni's? Link to comment Share on other sites More sharing options...
idiot4hire Posted May 21, 2013 Share Posted May 21, 2013 Do a little research tirerack.com or fredbeansparts.com or go to get-primitive.com and email them. Primitive quoted me 500 for koni's Link to comment Share on other sites More sharing options...
whitetiger Posted May 22, 2013 Share Posted May 22, 2013 Springs are fine unless you want to lower the car a bit. If not, the ride quality is pretty awesome on oem springs and Koni's. this^ Link to comment Share on other sites More sharing options...
