06scoobs Posted February 4, 2010 Share Posted February 4, 2010 Okay so here is the deal. I just had my right ankle fused and I cannot walk and or drive:(. I have my 06 2.5i leggy sitting in the driveway for the past 2 months. My fiance has been starting it every once in a while just to make sure it starts and that the battery keeps charged. Well the other day I went out there to check on all of the fluids to only find the oil dipstick bone dry:eek: Where is my oil? Should I add more? DO I have a big problem? Link to comment Share on other sites More sharing options...
naimouasta Posted February 4, 2010 Share Posted February 4, 2010 if you let it idle and warm up by itself, it takes longer to warm up vs. driving and taking it easy. this takes longer for the rings to seal up against the walls. so thats where the engine oil goes. this also causes cylinder wash. thats my guess. Link to comment Share on other sites More sharing options...
tbssubaru Posted February 4, 2010 Share Posted February 4, 2010 Okay so here is the deal. I just had my right ankle fused and I cannot walk and or drive:(. I have my 06 2.5i leggy sitting in the driveway for the past 2 months. My fiance has been starting it every once in a while just to make sure it starts and that the battery keeps charged. Well the other day I went out there to check on all of the fluids to only find the oil dipstick bone dry:eek: Where is my oil? Should I add more? DO I have a big problem? sounds like you should add some oil Link to comment Share on other sites More sharing options...
legacyCT Posted February 4, 2010 Share Posted February 4, 2010 This is one thing ive found really hard is to get a proper oil level reading on our cars. Be sure its on level ground, Try removing oil cap to relieve some pressure in the system and give it about 20 min and check the oil level again. If still no oil add some start it and let it sit and try checking again in about 4 hrs.. Link to comment Share on other sites More sharing options...
NORULZleggy Posted February 4, 2010 Share Posted February 4, 2010 I would def add oil ASAP. I carry 2 bottles, the big one's with me all the time, and if I take a 1000 mile trip I check it many times, and add a half a bottle. You just have to keep an eye on it. Link to comment Share on other sites More sharing options...
06scoobs Posted February 4, 2010 Author Share Posted February 4, 2010 Thanks for all of the replies. I have oil on hand and will add it, I just didnt want to overfill, but thanks again. I will try all of the little tricks some point this weekend. Thanks again Link to comment Share on other sites More sharing options...
NORULZleggy Posted February 5, 2010 Share Posted February 5, 2010 I would add a half a bottle and then let it run for about 5-10 mins and check it. Keep an eye on the oil temp and engine temp just to make sure. Link to comment Share on other sites More sharing options...
D_J Posted February 7, 2010 Share Posted February 7, 2010 Are you running synthetic or dino? I previously used full synthetic and seemed to use a lot of oil. Switched to regular dinosaur oil and barely use a drop now. Link to comment Share on other sites More sharing options...
06scoobs Posted February 7, 2010 Author Share Posted February 7, 2010 I am running full synthetic. Started that after the first oil change. I havent had a problem what so ever with oil up untill this point. I guess that I will add a little at a time and let it really warm up. Link to comment Share on other sites More sharing options...
CDN 2.5i Posted February 8, 2010 Share Posted February 8, 2010 When's the last time it was checked prior? These engines are known to consume oil, depending on how they're driven etc, and you really do need to stay on top of it. I check mine usually every other fillup to be on the safe side. Link to comment Share on other sites More sharing options...
