Refuge Posted December 7, 2012 Share Posted December 7, 2012 Question: Is anyone certain that a 2005 Subaru Legacy GT (VIN undisclosed) will be able to take a 2007 Spec B legacy (VIN undisclosed) Rack and Pinion? Used part swap Link to comment Share on other sites More sharing options...
Max Capacity Posted December 7, 2012 Share Posted December 7, 2012 Same chassis, so yes all 4th gen's are the same. Be careful which aftermarket one you buy. When I told my trusted mechanic mine was leaking, he told me he would only install one of the rebuilt racks. The others were all junk. But sounds like your going for a used one. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
Underdog Posted December 7, 2012 Share Posted December 7, 2012 My catalog shows slight differences between model years and 2.5i/GT/Spec.B models. Three different P/Ns: 34110AG05A, 34110AG06A, 34110AG07A There is no notification that the *05A should be replaced with the *06A or *07A, as there usually is if it's just a revised assembly. The Crimson Dynamo Link to comment Share on other sites More sharing options...
TheBlackPearl Posted December 7, 2012 Share Posted December 7, 2012 That's cool, all they all the same ratio too? Self proclaimed PNW Craiglist find of the day Champion, April 2014. Link to comment Share on other sites More sharing options...
frank_ster Posted December 8, 2012 Share Posted December 8, 2012 the gt has a faster ratio than the 2.5i .. Now that's thinking out of the boxer! fyi all 05 + legacy's have built in code reader Link to comment Share on other sites More sharing options...
Refuge Posted December 9, 2012 Author Share Posted December 9, 2012 My catalog shows slight differences between model years and 2.5i/GT/Spec.B models. Three different P/Ns: 34110AG05A, 34110AG06A, 34110AG07A There is no notification that the *05A should be replaced with the *06A or *07A, as there usually is if it's just a revised assembly. PN? So wait does that mean they completely are not compatible? Or are you saying the transplant of a spec b 07 may be successful to a 05 lgt Link to comment Share on other sites More sharing options...
