Custom Trendz Inc. Posted March 29, 2014 Share Posted March 29, 2014 Recently picked up a BNR16G from bryan to replace my vf40 with a stuck wastegate. Well after doing a pull for cryo to tune the turbo we found out i have boost creep. With the wastegate actuator hooked up directly to the compressor housing on the turbo, I am getting upto 19psi of boost(on a 13psi wastegate actuator!) My injectors are maxing out(stock, thats why I got the 16g vs 18 or 20g) and its very unsafe to go over 15psi of boost. Now, my question is, has anyone had any issues like this??? I would hate to spend the money on a EWG setup, because that is exactly why I got the new turbo instead of welding my vf40 wastegate shut. Should I waste my time porting the wastegate, or try to add more restriction in my exhaust? My parts list: Full 3" catless turboback bnr16g infamous oil lines cryotune perrin inlet innovate mtxl afr innovate boost gauge Link to comment Share on other sites More sharing options...
lingling1337 Posted March 29, 2014 Share Posted March 29, 2014 I never had that kind of problem with my bnr 16g. I had a similar setup to you but with an ebcs. I think you have problems other than the turbo. Link to comment Share on other sites More sharing options...
Custom Trendz Inc. Posted March 29, 2014 Author Share Posted March 29, 2014 what other problems could i possibly have to make a turbo boost like that? Bryan says wastegate is fine(sent him a video.) He did say something about some newer casings having smaller wastegates. Here is the quote: "That looks like normal actuation. The wastegate may need a port job. I did a batch at this time period that had smaller ports. I started porting them a couple months back. 15 psi isn't too much boost but if you want less boost, porting is the solution. If you can tune it rich at 15, it should be okay like that in my opinion. An lower psi actuator will not help." Here are the videos i sent him: pump to 20psi close from 20psi Link to comment Share on other sites More sharing options...
Nightmaresmk Posted March 29, 2014 Share Posted March 29, 2014 The STI guys have this issue with catless and vf42's swap in a catted downpipe and see if that changes Link to comment Share on other sites More sharing options...
Custom Trendz Inc. Posted March 29, 2014 Author Share Posted March 29, 2014 Yeah I've read numerous wrx and sti boost creep issues, but barely any with a lgt under 400hp. Kind of hesitant to buy a catted 5eat dp for just a possibility of it stopping. Link to comment Share on other sites More sharing options...
lingling1337 Posted March 29, 2014 Share Posted March 29, 2014 It really seems like you shouldn't have to throw more hardware at the issue. What does your tuner say about the issue? Link to comment Share on other sites More sharing options...
cryo Posted March 29, 2014 Share Posted March 29, 2014 It appears some of the bnr16gs with the new castings were designed with a smaller wastegate port thus causing boost creep at 0% wgdc. This is a mechanical limitation that's not something that can be tuned around unfortunately. There are only a couple options unfortunately. 1. Port the waste gate as Bryan recommends 2. Install new bigger than stock injectors so a proper amount of fuel can be supplied but still have creep and control issues *stock injectors are at 100+ IDC* 3. Install an ewg and have proper control via correct spring pressure 4.try a more restrictive exhaust but no guarantees. Dave [sIGPIC][/sIGPIC] Providing unmatched customer service and a Premium level of Dyno/E-tuning to the Community cryotuneperformance@yahoo.com facebook.com/cryotuneperformance. Link to comment Share on other sites More sharing options...
Custom Trendz Inc. Posted March 29, 2014 Author Share Posted March 29, 2014 But what guarantee would porting the Wastegate have? Link to comment Share on other sites More sharing options...
Custom Trendz Inc. Posted March 29, 2014 Author Share Posted March 29, 2014 Did a pull for Bryan from bnr with completely disconnected Wastegate. Hit 18psi. Now I'm billowing white/blue smoke. Hoping this piece of shit turbo blew up and not my rings or headgasket. Link to comment Share on other sites More sharing options...
rob-2 Posted March 30, 2014 Share Posted March 30, 2014 I am fairly certain you can hit 17-18 psi on stock injectors. I am... Link to comment Share on other sites More sharing options...
Moderators BarManBean Posted March 30, 2014 Moderators Share Posted March 30, 2014 This is interesting. Been thinking of sending my BNR 16g off for porting and polishing anyway, guess this will seal the deal. "Bullet-proof" your OEM TMIC! <<Buy your kit here>> Not currently in stock Link to comment Share on other sites More sharing options...
Custom Trendz Inc. Posted March 30, 2014 Author Share Posted March 30, 2014 If your turbo had the bnr compressor housing send it in. My injectors max out at 15psi at 5k+rpm. 107% injector duty cycle at that point. leak down testing and compression testing tomorrow then pulling turbo to save time vs just pulling turbo and seeing the inevitable. Link to comment Share on other sites More sharing options...
Moderators BarManBean Posted March 30, 2014 Moderators Share Posted March 30, 2014 If your turbo had the bnr compressor housing send it in. My injectors max out at 15psi at 5k+rpm. 107% injector duty cycle at that point. leak down testing and compression testing tomorrow then pulling turbo to save time vs just pulling turbo and seeing the inevitable. Yeah, it has the new housing. Not so concerned about IDC since I'll have aftermarket fueling, but I still don't want my tuner (Cryo, same as you) to have to deal with boost creep. "Bullet-proof" your OEM TMIC! <<Buy your kit here>> Not currently in stock Link to comment Share on other sites More sharing options...
Custom Trendz Inc. Posted March 30, 2014 Author Share Posted March 30, 2014 Might be going built like you did before if its the rings. Link to comment Share on other sites More sharing options...
Moderators BarManBean Posted March 30, 2014 Moderators Share Posted March 30, 2014 Might be going built like you did before if its the rings. Just to be clear, I don't have a built motor. In the next few months I should have a 16g with just about every bolt-on possible, but now rebuild of the motor. At that point I'll hopefully stick with what I have for a good while (although that's doubtful ). However, if something breaks I'll probably build the motor and then go bigger--at that point the *only* thing I'll need to do is build the motor and swap a bigger turbo. "Bullet-proof" your OEM TMIC! <<Buy your kit here>> Not currently in stock Link to comment Share on other sites More sharing options...
Custom Trendz Inc. Posted March 30, 2014 Author Share Posted March 30, 2014 i was thinking of someone else, my bad. But ill be dropping in new pistons after honing if its the rings. Just hoping its the turbo seals that went and not the piston rings. I pulled the intercooler and it was not filled with oil. Will pull downpipe tomorrow. Link to comment Share on other sites More sharing options...
Custom Trendz Inc. Posted March 30, 2014 Author Share Posted March 30, 2014 Did a compression test on the engine pretty much cold and got 90,90,90,91. That was with throttle plate open AND closed, so its probably the shitty harbor freight gauge. After finding out everything was alright, no oil on plugs, no burnt plugs i went ahead and pulled the downpipe. Well pictures will show you the ammount of oil in there AFTER i stuck my hand in there to check it out. Turbo has NO play, but quiet obviously lost a seal. Going to pull it tomorrow, sucks working in the driveway when its raining(been raining since i blew it up, today, and tomorow yay!) Link to comment Share on other sites More sharing options...
rob-2 Posted March 30, 2014 Share Posted March 30, 2014 Your comp numbers are low but even. Link to comment Share on other sites More sharing options...
Custom Trendz Inc. Posted March 30, 2014 Author Share Posted March 30, 2014 could be low thanks to a cheap gauge and being tested pretty much cold(didnt want to run it with this much oil burning.) Link to comment Share on other sites More sharing options...
Custom Trendz Inc. Posted March 31, 2014 Author Share Posted March 31, 2014 talked to bryan and he says it might be too much oil going through the turbo possibly. But either way im sending it in so he can check it out and port the wastegate for me. Meanwhile ill try and run my oem vf40 after i find some way to either keep wastegate open, or to align it back again. Link to comment Share on other sites More sharing options...
Custom Trendz Inc. Posted March 31, 2014 Author Share Posted March 31, 2014 on the way to bryan as we speak, should know thursday whether it was something with the turbo(oil leak) or my car/oil starvation. Link to comment Share on other sites More sharing options...
Custom Trendz Inc. Posted April 4, 2014 Author Share Posted April 4, 2014 So sent the turbo out monday, and bryan got it on wednesday. He said somehow the oil "seal" ring ceased. He ported the wastegate, installed new CHRA, and shipped it overnight free of charge for me. Great service! Installing it on Saturday. Link to comment Share on other sites More sharing options...
