joelenriquez Posted January 10, 2012 Share Posted January 10, 2012 Is there a way to hide a 4 gauge wire that I have through the firewall of the vehicle? Right now its just wired along the left side of the driver seat going through the left fender. Link to comment Share on other sites More sharing options...
angeltalin Posted January 10, 2012 Share Posted January 10, 2012 Are you talking about sending it through the firewall? Sent from my Droid Incredible 2 using Tapatalk StageIII Cryotune-Kinugawa STS TD06H-20GTX 9 blade turbine, ID1000, DW65c, 73mm MegaMAF , GS EWG up-pipe, Downpipe and EBCS, FMS FMIC, TGV Delete, Brembo swap Link to comment Share on other sites More sharing options...
xt2005bonbon Posted January 10, 2012 Share Posted January 10, 2012 there's supposed to be a grommet close to the master cylinder on the driver side. There's also another one on the passenger side as well. I currently have a 1/0 gauge wire going through the driver's fender as well though. Do a search on the forum about grommets. There are a couple of threads showing where they are. If you're talking about hiding the cable underneath the carpet, then I had to pull the garniture all along the driver side so that i could pull the carpet a bit and tuck the fat cable underneath. Link to comment Share on other sites More sharing options...
angeltalin Posted January 10, 2012 Share Posted January 10, 2012 The grommet is beneath the intercooler search boost gauge help someone posted a pic of it where he ran the vac line Sent from my Droid Incredible 2 using Tapatalk StageIII Cryotune-Kinugawa STS TD06H-20GTX 9 blade turbine, ID1000, DW65c, 73mm MegaMAF , GS EWG up-pipe, Downpipe and EBCS, FMS FMIC, TGV Delete, Brembo swap Link to comment Share on other sites More sharing options...
Heedz Posted January 10, 2012 Share Posted January 10, 2012 I sliced the grommet on the passenger side then electrical taped it. No signs of moist. Link to comment Share on other sites More sharing options...
joelenriquez Posted January 12, 2012 Author Share Posted January 12, 2012 Any way you can post pics of how this was done? Link to comment Share on other sites More sharing options...
