psapitch13 Posted March 3, 2013 Share Posted March 3, 2013 I am going to post this on this section because it seems to get more activity... I just picked up an accessport and I am trying to load a stage 2 map onto my car. The AP recognized the ECU on my car, a 2005.5 LGT, and I saved the current ECU info. I then reset the ECU and got the big green "checkmark," that said reset was a success. My problem occurs when I pick which map I want to install and it goes to the next screen. The AP has a screen of "TEST MODE" and tells me to connect the green plugs, which I already have connected. http://i1102.photobucket.com/albums/g453/qsmgto13/2005%20Legacy%20GT/20130304_063846_zps7f42cf2e.jpg What the heck is going on with this thing? Thanks! Link to comment Share on other sites More sharing options...
I Donated Too sigmafour Posted March 4, 2013 I Donated Too Share Posted March 4, 2013 Tuning forum may be a better place to ask and search... http://legacygt.com/forums/forumdisplay.php/tuning-84.html Link to comment Share on other sites More sharing options...
psapitch13 Posted March 4, 2013 Author Share Posted March 4, 2013 I have posted and searched. maybe not the right keywords? There has to be a simple solution for this. Link to comment Share on other sites More sharing options...
psapitch13 Posted March 4, 2013 Author Share Posted March 4, 2013 This button can't be stock, right? http://i1102.photobucket.com/albums/g453/qsmgto13/2005%20Legacy%20GT/20130304_140041_resized1_zps2b3429b0.jpg Link to comment Share on other sites More sharing options...
mwiener2 Posted March 4, 2013 Share Posted March 4, 2013 Un hack car, try again My Mods List (Updated 8/22/17) 2005 Outback FMT Running on Electrons Link to comment Share on other sites More sharing options...
Flipapotimus Posted March 4, 2013 Share Posted March 4, 2013 I would assume that switch is an on/off switch for the test mode connectors since they have been spliced. Link to comment Share on other sites More sharing options...
Max Capacity Posted March 4, 2013 Share Posted March 4, 2013 Un hack car, try again Yea, un-do everything and start again. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
psapitch13 Posted March 4, 2013 Author Share Posted March 4, 2013 Undo everything? I'm trying to sit in the car now to get this mode to work. No luck thus far. I guess I need to take it to a tuning place and get the ecu reset. I that is what Cobb reccomended. Link to comment Share on other sites More sharing options...
Max Capacity Posted March 4, 2013 Share Posted March 4, 2013 Can you cut the two yellow wires then try again. Then after the reflash unplug the green connectors like all of us do. Looks like some one hacked the system to be able to change maps ? I'm not good with that type stuff. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
mwiener2 Posted March 4, 2013 Share Posted March 4, 2013 Cut the yellow wires and either splice them together, or repair the original wires. My Mods List (Updated 8/22/17) 2005 Outback FMT Running on Electrons Link to comment Share on other sites More sharing options...
Max Capacity Posted March 4, 2013 Share Posted March 4, 2013 I'm assuming the yellow wires come one, from each connector, if he connects them its the same as plugging in the two green connectors. right ? 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
mwiener2 Posted March 5, 2013 Share Posted March 5, 2013 the red wire looks split into the two yellow wires probably to a switch.. maybe the one he found. some nice hackage My Mods List (Updated 8/22/17) 2005 Outback FMT Running on Electrons Link to comment Share on other sites More sharing options...
I Donated Too sigmafour Posted March 5, 2013 I Donated Too Share Posted March 5, 2013 oh boy - didn't see the pictures on TT - bloody hell. Hacked indeed! Link to comment Share on other sites More sharing options...
I Donated thefultonhow Posted March 5, 2013 I Donated Share Posted March 5, 2013 This button can't be stock, right? http://i1102.photobucket.com/albums/g453/qsmgto13/2005%20Legacy%20GT/20130304_140041_resized1_zps2b3429b0.jpg That looks like the button and status LED from an Innovate LC-1 wideband O2. Link to comment Share on other sites More sharing options...
psapitch13 Posted March 5, 2013 Author Share Posted March 5, 2013 The car does have a Innovate wide O2 sensor gauge. I am going to see if I can have a tuner reflash the ecu to stock. Link to comment Share on other sites More sharing options...
psapitch13 Posted March 5, 2013 Author Share Posted March 5, 2013 Cut the yellow wires and either splice them together, or repair the original wires. I am going to try this tonight. Thanks! Link to comment Share on other sites More sharing options...
psapitch13 Posted March 5, 2013 Author Share Posted March 5, 2013 I am trying to locate a picture of exactly what wire are supposed to be connected so I can rewire it to what it is supposed to be. Link to comment Share on other sites More sharing options...
psapitch13 Posted March 5, 2013 Author Share Posted March 5, 2013 Took the tape off of the wires. You think If I connect the red on again and plug the connectors in it should work correct? http://i1102.photobucket.com/albums/g453/qsmgto13/2005%20Legacy%20GT/20130305_100436_resized_zpsfa164d3b.jpg Link to comment Share on other sites More sharing options...
Flipapotimus Posted March 5, 2013 Share Posted March 5, 2013 Should yes, I would use something better than black tape to put them together though. Link to comment Share on other sites More sharing options...
psapitch13 Posted March 5, 2013 Author Share Posted March 5, 2013 do the other wires (the black one) look as they should? Link to comment Share on other sites More sharing options...
Max Capacity Posted March 5, 2013 Share Posted March 5, 2013 I can't view the photos here at work. I think you need to remove the 2 yellow wires from either end of the green connector wires. In other words put it back like stock. Have you been to Invatives site to see if you can get the wireing set up ? 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
I Donated thefultonhow Posted March 5, 2013 I Donated Share Posted March 5, 2013 Have you been to Invatives site to see if you can get the wireing set up ? The Innovate WBO2 looks like it is probably properly set up. Link to comment Share on other sites More sharing options...
psapitch13 Posted March 5, 2013 Author Share Posted March 5, 2013 I can't view the photos here at work. I think you need to remove the 2 yellow wires from either end of the green connector wires. In other words put it back like stock. Have you been to Invatives site to see if you can get the wireing set up ? I will disconnect the yellows and connect the red pieces when I get home. Link to comment Share on other sites More sharing options...
I Donated thefultonhow Posted March 5, 2013 I Donated Share Posted March 5, 2013 I will disconnect the yellows and connect the red pieces when I get home. You can also just cut the yellow wires and connect the ends together if they're soldered onto the reds. Link to comment Share on other sites More sharing options...
Indiglow Posted March 5, 2013 Share Posted March 5, 2013 you'll know if you're in test mode when the radiator fans cycle on/off on their own with the key in the on position.... someone sexually molested your wiring. Link to comment Share on other sites More sharing options...
