09LegacySE Posted August 2, 2009 Share Posted August 2, 2009 I have an 09 Legacy SE and when i take turns to the left or right and i hit a bump in the road it makes a noise from front end. it seems to be just one those normal things cause i dont hear it driving down the road its more when i am pulling in my parking deck for work or taking hard right hand turns. the thing is its driving me crazy not knowing what it is. any ideas what it could be or how to check what it is Link to comment Share on other sites More sharing options...
ehsnils Posted August 2, 2009 Share Posted August 2, 2009 What type of noise? Squeaking, bumping, scratching? It can be just about anything from what you describe. Since it's a fairly new car I would certainly check if it's a warranty issue. Link to comment Share on other sites More sharing options...
09LegacySE Posted August 2, 2009 Author Share Posted August 2, 2009 more like a bumping noise. to me sounds metal to metal in the suspension. but i dont hear it any other time. its only when turning. Link to comment Share on other sites More sharing options...
katalyst Posted August 2, 2009 Share Posted August 2, 2009 lower control arm? Link to comment Share on other sites More sharing options...
ehsnils Posted August 2, 2009 Share Posted August 2, 2009 That or a shock absorber that has started to leak. Link to comment Share on other sites More sharing options...
Power4 Posted August 2, 2009 Share Posted August 2, 2009 more like a bumping noise. to me sounds metal to metal in the suspension. but i dont hear it any other time. its only when turning. I hear that same noise under the same conditions in my 09 LGT. I think it's probably normal if we're both hearing it. It did startle me a little the first time I heard it however upon hearing it a few more times it doesn't sound like anything is broken or needs replacing. Link to comment Share on other sites More sharing options...
09LegacySE Posted August 2, 2009 Author Share Posted August 2, 2009 I hear that same noise under the same conditions in my 09 LGT. I think it's probably normal if we're both hearing it. It did startle me a little the first time I heard it however upon hearing it a few more times it doesn't sound like anything is broken or needs replacing. I have come to think it is normal myself. It just drives me nuts not knowing exactly what it is. I say it could be sway bar since its when im turning. Way i look at it is i got warranty so i don't think much of it. Just like to know what and why. Link to comment Share on other sites More sharing options...
katalyst Posted August 2, 2009 Share Posted August 2, 2009 i believe i have the same thing, does it sound kind of like a "soft clatter" (is how i can best describe it)? i noticed it more after i swapped in my poly LCA bushings so i would believe that it is the lower control arm reverberating in some way over uneven surfaces while turning Link to comment Share on other sites More sharing options...
batonrouge Posted August 6, 2009 Share Posted August 6, 2009 Hey guys. I know exactly the noise you're talking about. I just took my '08 in for this noise (among other things) for the 2nd time. A rep from Subaru HQ came down and drove the car. They told me this is a known condition on these cars and it is normal. I guess that makes me feel a little better; but I owned an '06 of the exact same car and it never did this. Either I was lucky on the '06, or they changed something for '07 that caused it. My guess was bad rack/pinion. They seem to think it's the p/s hoses knocking around when turning; but said this is 'normal'. I've simulated the noise when parked by turning the wheel all the way to one side and and slightly bumping it at the limit. I hope this helps. I will post again after I pick up the car tomorrow if I have any new info on this. Link to comment Share on other sites More sharing options...
davey smalls Posted August 6, 2009 Share Posted August 6, 2009 This may be the noise my car is suffering from......my spec now goes clump clump clump when driving over bumps. Performs fine but REALLY annoying....could my passenger bilstein be blown? Link to comment Share on other sites More sharing options...
ShrinerMonkey Posted August 6, 2009 Share Posted August 6, 2009 I have heard this clunking noise when turning and going over bumps since my car was new. My in-laws 2007 Outback makes the same noise. I think it is normal. I have checked the suspension parts by pushing and pulling on them and everything seems pretty tight. Link to comment Share on other sites More sharing options...
batonrouge Posted August 6, 2009 Share Posted August 6, 2009 Well I do feel better hearing it from all of you as well as the Subaru Headquarters rep that it's normal; but I still think they should have looked further into by now, found a solution, and issued a bulletin to address those who are annoyed by it, because I sure am. I can't imagine an Accord, Camry or Altima that made this sort of noise right off the line. I dont think they would let that go for sake of their reputation. I'm a pretty loyal Subaru fan, but things of this sort make me wonder sometimes. I may just check those power-steering hoses myself and see if I can't come up with my own solution, if that is indeed the source of the noise. Link to comment Share on other sites More sharing options...
davey smalls Posted August 6, 2009 Share Posted August 6, 2009 funny gift after 40k trouble free stage II miles Link to comment Share on other sites More sharing options...
09LegacySE Posted August 7, 2009 Author Share Posted August 7, 2009 I have heard this clunking noise when turning and going over bumps since my car was new. My in-laws 2007 Outback makes the same noise. I think it is normal. I have checked the suspension parts by pushing and pulling on them and everything seems pretty tight. i bought my car with 30 miles on it and Ive heard that clunk since day one. car drives great in straight line but if i turn onto another road an hit a bump there the clunk is. when the dealer was putting my wing and fog lights on i had an 09 outback xt, i think, it was the fully loaded one and it made the same sound. i have come to terms with the clunk id just like to know what it is. Link to comment Share on other sites More sharing options...
batonrouge Posted August 10, 2009 Share Posted August 10, 2009 Results from Service visit: "Check and advise- customer states knock noise when turning on uneven pavement at very low speed." "Inspected suspension, struts links and arms for looseness or noise. No concerns found." "Road test with Ron Gxxxxxxx Subaru service rep. No concerns found. Did say possible fluid knock customer is hearing. This is a loud metallic noise when wheels hit uneven surface. This is a normal condition." __________________________________________ I am happy with the Subaru dealer's efforts to address this, but obviously not happy with Subaru's determination. I'll do my own checking when I get the chance and let you know if I am successful in finding this and correcting it. Link to comment Share on other sites More sharing options...
snow05gtRI Posted August 10, 2009 Share Posted August 10, 2009 swaybar endlink? one of my front end ones broke on me, but only enough to cause a clunking noise. could be reproduced by grabbing the sway near the endlink and pulling/pushing on the bar (give it a good amount of force) Link to comment Share on other sites More sharing options...
davey smalls Posted August 14, 2009 Share Posted August 14, 2009 I figured out my clunk issue....my strut has a bearing at the top that has worn. to test, place your hand on the top of the strut and have someone put downward pressure on the nose of the car. it the strut pokes at you, there you go. bad bearing. Link to comment Share on other sites More sharing options...
ehsnils Posted August 14, 2009 Share Posted August 14, 2009 That's an odd one. Those bearings aren't usually failing - at least not that early considering that you have a '07. But there has to be a first time for everything. Link to comment Share on other sites More sharing options...
Power4 Posted September 11, 2009 Share Posted September 11, 2009 I'll do my own checking when I get the chance and let you know if I am successful in finding this and correcting it. Did you ever check it out and see if you could determine what the cause of the noise was? Link to comment Share on other sites More sharing options...
batonrouge Posted September 11, 2009 Share Posted September 11, 2009 Did you ever check it out and see if you could determine what the cause of the noise was? No. Actually took the easy way out...sorta. I traded it in on a new '09 3.0R. But IT does THE SAME THING. Not quite as bad, but the same exact noise. It even has the same interior rattles in the same 2 out of 3 places. Have to give it to Subaru for consistency. lol I won't bring this up to the dealer since they have already found it to be normal on my '08; but I will still check it out for myself when I get under there. Link to comment Share on other sites More sharing options...
ebpda9 Posted September 12, 2009 Share Posted September 12, 2009 i have an 05 and it does the same thing. I looked for everyting underneath the car and i came to the conclusion that it is the dust boot hitting the lower spring perch, then again i am lowered on sti pinks. It seems that the noise accentuated after the drop. Link to comment Share on other sites More sharing options...
07miata Posted November 3, 2010 Share Posted November 3, 2010 looks like a dead subject, but it's annoying the crap out of me. i've got the clunking noise at low speeds. seems to come from both driver and passenger wheel wells. i'm on sti pinks, but first noticed it about a year ago before i put lowering springs on. It seems loudest after a long drive on roughish pavement (texas rural farm roads), and seems to go away after letting the car rest for a day or two. I took it to a dealer who replaced the front end links, and the noise went away but was back immediately after 2 days. the noise seems to go away right after lifting the nose of the car. I noticed that if i try to rock the front wheels laterally, i can reproduce the clunking and actually feel it (almost feels like a wheel bolt is loose) type of sensation. i figure if other non-spec b legacys have this problem, it probably has nothing to do with the bilstein setup. anyone with any further thoughts? Link to comment Share on other sites More sharing options...
snow05gtRI Posted November 4, 2010 Share Posted November 4, 2010 wheel bearing? i thought the test for wheel bearings was pulling on the wheels laterally (when the car is off the ground) to see if it makes a noise or something Link to comment Share on other sites More sharing options...
Pinter Posted November 4, 2010 Share Posted November 4, 2010 I have an 06 and when I turn, I hear a clunking. Dealer said it was normal and everything was fine in my car. Link to comment Share on other sites More sharing options...
joeblow Posted November 4, 2010 Share Posted November 4, 2010 I had this issue after I went to an aftermarket front swaybar in July, and it was just a loose endlink. It would clunk at low speeds over bumps especially on turns. The clunk came less often at higher speeds, but would still be there occasionally. I tightened the endlink down and the noise went away. I would just put the front end of the car up and take a couple wrenches and a torx key to the endlinks and see if it fixes the noise. FWIW I'm lowered on h-techs since April and haven't had any noises from that part area of the suspension. I had originally thought it might be strut clunk from a blown strut, but since it wasn't all the time, I tried other things first. It's cool; I'm with the band Link to comment Share on other sites More sharing options...
