need bb Posted March 21, 2013 Share Posted March 21, 2013 Are there are springs that work with the stock non-SpecB top hats that don't lower the car much? I drive my wagon a lot in the city and I really can't afford to lower the car more than .75" without scraping on all the speed bumps. I am planning on getting some Koni's and I want a stiffer spring than the OEM's. All the springs I am seen lower the car at least 1" in front. Thanks Link to comment Share on other sites More sharing options...
MyWifezLEGi Posted March 21, 2013 Share Posted March 21, 2013 U wont find any spring. U could always offset the height with bigger rims Ninja edit Check Sti spring Link to comment Share on other sites More sharing options...
coldsubycz Posted March 21, 2013 Share Posted March 21, 2013 King Springs out of Australia makes springs that can roughly maintain stock height and stiffen it up a bit, but only for the rear. Their front springs for the 4th gen's only lower. Oh, Legacy is called Liberty in Australia if you didn't know. King Springs website: http://www.kingsprings.com.au/ -Go to "Catalogue" -Click on link "King Springs 2013 Coil Spring Catalogue" PDF link - http://www.kingsprings.com.au/catalogue/kings_master_catalogue.pdf KSRL-29 should keep you close to stock KSRS-29 would jack up the rear. I purchased the KSRL-29's a few months ago for my LGT sedan, but went with coilovers so I haven't used them. They're still in the box wrapped in plastic. Might try to sell them. E-mail from King Springs I got back: "Hello, The KSRL-29's do raise the GT 5-10mm plus have an increase in spring rate of 15-20%. The KSRS-29's are a further 25mm higher than the KSRL-29's and I feel would be to high Regards , Kris Tarrant Sales and Technical Services IT Manager KING SPRINGWORKS PTY LTD" Who sells them in the USA: Primitive Enterprises, Inc 9460 SW Tigard St Suite 104 Tigard, OR 97223 503-624-2139 http://www.get-primitive.com/ Link to comment Share on other sites More sharing options...
mbcracken Posted March 21, 2013 Share Posted March 21, 2013 I wonder how those springs would be with bilHD? Link to comment Share on other sites More sharing options...
coldsubycz Posted March 21, 2013 Share Posted March 21, 2013 Both King Springs and Primitive suggest KYB, but I'm sure that's to keep close to an OEM ride feel. I'm sure the Bilsteins would be fine. I was going to use the King Springs in the rear and stock springs in the front and use Konis all around. Link to comment Share on other sites More sharing options...
Kelvrick Posted March 21, 2013 Share Posted March 21, 2013 Well, there would also be a top hat difference, wouldn't there? I don't know much, so let me know if I'm wrong, but sticking the bilstein top hats on the kyb type springs would add height? My Outback Link to comment Share on other sites More sharing options...
need bb Posted March 22, 2013 Author Share Posted March 22, 2013 Bummer? What are the spring with the least drop? Link to comment Share on other sites More sharing options...
sactojesse Posted March 22, 2013 Share Posted March 22, 2013 Bummer? What are the spring with the least drop? STI pinks with Bilsteins result in a .6 in (15 mm) drop. You'll need Bilstein HDs and Spec B top hats though. That's what I'm running. It will save you the trouble of hacksawing through your stock front struts to fit the Konis. Link to comment Share on other sites More sharing options...
LosAngelesLGT Posted March 22, 2013 Share Posted March 22, 2013 Both King Springs and Primitive suggest KYB, but I'm sure that's to keep close to an OEM ride feel. I'm sure the Bilsteins would be fine. I was going to use the King Springs in the rear and stock springs in the front and use Konis all around. This likely to give you some rotation off throttle and under braking, FYI. Not my idea of fun in incliment weather. Link to comment Share on other sites More sharing options...
dan04103 Posted March 22, 2013 Share Posted March 22, 2013 I run konis oem legacy front with king rear and no problems of this sort. Fine combo for dd and no issues in ice, snow, and rain. I do wish that king made a stiffer front oem spring but I'm happy. Link to comment Share on other sites More sharing options...
LosAngelesLGT Posted March 22, 2013 Share Posted March 22, 2013 Thanks for the heads up Dan! That makes me more confident about putting it in the rear of the wife's OBXT to help handle loads without having it surprise oversteer on her. Link to comment Share on other sites More sharing options...
dan04103 Posted March 22, 2013 Share Posted March 22, 2013 Thanks for the heads up Dan! That makes me more confident about putting it in the rear of the wife's OBXT to help handle loads without having it surprise oversteer on her. Anytime... and to add... when I was at outback height I ran OEM outback front with king rear and enjoyed the combo... although I need to note that I used the 04 rear kyb struts. Really nailed down the boaty feel in the rear. Let me know if you have any other questions LA. Link to comment Share on other sites More sharing options...
coldsubycz Posted March 22, 2013 Share Posted March 22, 2013 I run konis oem legacy front with king rear and no problems of this sort. Fine combo for dd and no issues in ice, snow, and rain. I do wish that king made a stiffer front oem spring but I'm happy. Anytime... and to add... when I was at outback height I ran OEM outback front with king rear and enjoyed the combo... although I need to note that I used the 04 rear kyb struts. Really nailed down the boaty feel in the rear. Let me know if you have any other questions LA. Dan is the guy I learned about King Springs from in the Lowered Outback thread! I have the rear King Springs in my garage, which I need to sell, since I went with Bilstein PSS coils (which by they way are so awesome even at close to stock height). Wish I would have tried the Kings though to see how they felt. Link to comment Share on other sites More sharing options...
need bb Posted April 4, 2013 Author Share Posted April 4, 2013 So it looks like there are no front and rear springs that work with the Koni's that offer a minimal drop. From what I am hearing only the STI pink springs with the Bilstein HD struts are the only option. Is it possible to run some of the saggy shims in the front and the rear to add a little lift? Thanks Link to comment Share on other sites More sharing options...
RabidWombat Posted April 5, 2013 Share Posted April 5, 2013 Shorter springs + shims should give you the effect you're looking for. I don't know that anyone has tried it though. Link to comment Share on other sites More sharing options...
need bb Posted April 16, 2013 Author Share Posted April 16, 2013 Well it looks like a 1/4" front spacer is made for the LGT. I wonder if this would go well with a 1/2" rear spacer with Epic springs?? http://www.subtle-solutions.com/product_info.php?cPath=21_25_64_92&products_id=210 Link to comment Share on other sites More sharing options...
JmP6889928 Posted April 17, 2013 Share Posted April 17, 2013 How about something like this? http://www.elephantracing.com/suspension/coilover/911coiloversleeve.htm http://www.ground-control-store.com/products/description.php/II=901/CA=7 Order a stiffer spring with some adjustability in the adaptation. Just an idea. http://www.ground-control-store.com/products/category.php/CA=90 Subaru page for Ground Control Link to comment Share on other sites More sharing options...
Kelvrick Posted April 18, 2013 Share Posted April 18, 2013 So it looks like there are no front and rear springs that work with the Koni's that offer a minimal drop. From what I am hearing only the STI pink springs with the Bilstein HD struts are the only option. Is it possible to run some of the saggy shims in the front and the rear to add a little lift? Thanks Some outback guys have added over 1" of shims front and back to bilsteins to get height. You should check out some of those threads in the outback section. Example here (but there are more): http://legacygt.com/forums/showthread.php/obxt-bilstein-xt-167299.html Also some info can be found in the lowered outback thread. Since us lowered usually equals your normal. http://legacygt.com/forums/showthread.php/official-lowered-outback-thread-180375.html My Outback Link to comment Share on other sites More sharing options...
The Woo Posted April 19, 2013 Share Posted April 19, 2013 So it looks like there are no front and rear springs that work with the Koni's that offer a minimal drop. From what I am hearing only the STI pink springs with the Bilstein HD struts are the only option. Is it possible to run some of the saggy shims in the front and the rear to add a little lift? Thanks What do you mean? Pinks do work with Konis. And that's what I intend to to also this year. I ran the sti pink wagon springs on my 05 LGT wagon and oiled with konis they were phenomenal for road racing. With the konis I could dial it in for mother in law duty or track duty. -mike http://www.pbase.com/paisan/image/91072632.jpghttp://www.pbase.com/paisan/image/141039922.jpg http://www.pbase.com/paisan/image/133406601.jpg http://upload.pbase.com/image/137566671.jpg 11+ Years Maintaining, Modifying and Educating TriState Subaru Enthusiasts. Call directly as We carry almost every manufacturer now, so before you buy parts call us. AIM: AZP Installs | E-mail: sales@azpinstalls.com | 725 Fairfield Ave | Kenilworth, NJ 07033 | 908.248.2971 | T-1 Certified Amsoil Direct Jobber "Race Tested, Enthusiast Approved!" Link to comment Share on other sites More sharing options...
GEE-OTTO Posted April 19, 2013 Share Posted April 19, 2013 KYB + Htechs + 1/4 inch rear spacers = DONE! Link to comment Share on other sites More sharing options...
