damascus Posted March 1, 2012 Share Posted March 1, 2012 after I had my tires rotated today (front to rear - rear to front) I immediately was presented with a HORRIBLE tire shake/vibration/thumping issue (and road noise too). what the heck?? has anyone else had this issue? I searched here and found a that a few of us have had some similar experiences but no real solutions. should I just put them back the way I had them? thanks! Link to comment Share on other sites More sharing options...
cseagle08 Posted March 1, 2012 Share Posted March 1, 2012 sounds like it was better like it was before, haha. Did the tire place accidentally knock a weight off somehow? Link to comment Share on other sites More sharing options...
underground000 Posted March 1, 2012 Share Posted March 1, 2012 same thing happened to another member linky - still working on it... 5eat downshift rev match:) Powder coated wheels: completed:) Link to comment Share on other sites More sharing options...
RShaw Posted March 1, 2012 Share Posted March 1, 2012 You probably have a bent rim, or they are out of balance. It happened to me, vibes arent as noticable when then are in the rear. Link to comment Share on other sites More sharing options...
underground000 Posted March 1, 2012 Share Posted March 1, 2012 shaking in steering wheel - front wheels shaking in seat - rear wheels 5eat downshift rev match:) Powder coated wheels: completed:) Link to comment Share on other sites More sharing options...
Justin case Posted March 1, 2012 Share Posted March 1, 2012 Usually when we do tires at work we watch how they spin. Most times if its a cheap tire they spin like crap so we try and put the best ones on the front. Or if they have a bent wheel and the customer doesn't want to replace it it goes on the rear. Thus whenever they are rotated the bent wheels/crappy spinning tires are now on the front and you tend to feel the vibration. Link to comment Share on other sites More sharing options...
Mega Users paintpollz Posted March 1, 2012 Mega Users Share Posted March 1, 2012 tires cole, tire's what wins the race "Remember Danny - Two wrongs don't make a right but three rights make a left." Link to comment Share on other sites More sharing options...
ClimberDHexMods Posted March 1, 2012 Share Posted March 1, 2012 Could be the wheel did not seat flat on the hub when they impact wrenched the lug nuts on. Only a possibility. Missing wheel weight can do it easy. [CENTER][B][I] Front Limited Slip Racing Differentials for the 5EAT now available for $1895 shipped, please inquire for details! [/I][/B][/CENTER] Link to comment Share on other sites More sharing options...
GTTuner Posted March 1, 2012 Share Posted March 1, 2012 Your noise description sounds like an irregular or choppy wear pattern. What tire are you running and how often do you rotate? Link to comment Share on other sites More sharing options...
TheOneDoubleN Posted March 1, 2012 Share Posted March 1, 2012 What tire are you running and how often do you rotate? Were you overdue for your rotation? When was the last time your alignment was checked? Did you inspect for irregular tire wear? Link to comment Share on other sites More sharing options...
Mega Users seabass07 Posted March 1, 2012 Mega Users Share Posted March 1, 2012 It happened to me, vibes arent as noticable when then are in the rear. Wut? Link to comment Share on other sites More sharing options...
damascus Posted March 2, 2012 Author Share Posted March 2, 2012 Your noise description sounds like an irregular or choppy wear pattern. What tire are you running and how often do you rotate? The tires look okay... they are Kuhmo Ecsta ASX tires. They have less than 20K on them. Were you overdue for your rotation? When was the last time your alignment was checked? Did you inspect for irregular tire wear? Yes, overdue for rotation... I have to have the car aligned for sure. Do I have to take it somewhere special to handle an AWD alignment? I think I'll get new (better) tires this summer at Costco and then take it for an immediate alignment. Thanks, everyone. I put the wheels/tires back the way I had them for now and all good. Link to comment Share on other sites More sharing options...
TheOneDoubleN Posted March 2, 2012 Share Posted March 2, 2012 The tires look okay... they are Kuhmo Ecsta ASX tires. They have less than 20K on them. Yes, overdue for rotation... I have to have the car aligned for sure. Do I have to take it somewhere special to handle an AWD alignment? I think I'll get new (better) tires this summer at Costco and then take it for an immediate alignment. Thanks, everyone. I put the wheels/tires back the way I had them for now and all good. If you're at nearly 20k that's beyond the point of help for a rotation IMO on these cars, and it sounds like you've got a tread wear problem. I would leave the tires where they are, but monitor the fronts compared to the rears. If there's a real noticeable difference between the tread wear front to rear, it's time to replace the whole set so you don't burn up your center differential. It's up to you how much you want that difference to be and for how many miles you want to put on an uneven set. If summer is a couple thousand miles away, I wouldn't worry about it. If it's 10-20k miles away, I would. The spec btw from Subaru is that the difference in overall circumfrence between front and rear tires cannot exceed 1/4in (works out to about 1-2/32nd"s). Your tires are probably at or beyond that limit, but if you're not way out of the limit and/or don't plan on driving very much between now and your next set of tires, I wouldn't worry about it. An AWD car does not need anything special for an alignment, you can take it anywhere alignments are done. Link to comment Share on other sites More sharing options...
AGR-LGT Posted March 13, 2012 Share Posted March 13, 2012 I see alot of elgacys come through the door with worn oem rear struts. See alot of cupping on the inside edge of the tires, even on perfect alignment. Once the strut wears it creates unequal amount of pressure on the tire causing it to cup. However, that still may not be your issues. THe vibration will come from an out of balance tire, thge noise, will be from uneven wear. The wear is not fixable, but the balance is. Link to comment Share on other sites More sharing options...
RShaw Posted March 17, 2012 Share Posted March 17, 2012 Wut? Sorry i posted from my phone. I meant a vibration from a misbalanced wheel isnt as noticeable when its in the rear of the car. Put the same wheel in the front and its a lot more obvious. Just like the other guy said. Link to comment Share on other sites More sharing options...
