PeterJMC Posted August 31, 2015 Share Posted August 31, 2015 Does anyone have a pair of 2008-2009 headlights with reflectors that I could borrow to use only for a state vehicle inspection? The vehicle that I'm bringing to MD does not have the side reflectors in the front headlights and the car may not pass MD state inspection. I depending on when I can pick them up, and schedule time off work/schedule inspection... I think that I would only need them for a week. They would only be used for one day inside of that week and only for a few hours. They headlights would only be used for the purpose of passing state inspection. LMK. Thanks! Link to comment Share on other sites More sharing options...
PeterJMC Posted September 1, 2015 Author Share Posted September 1, 2015 Bump Link to comment Share on other sites More sharing options...
PeterJMC Posted September 2, 2015 Author Share Posted September 2, 2015 I'm looking to borrow them sometime after the 20th of this month. Link to comment Share on other sites More sharing options...
xt2005bonbon Posted September 3, 2015 Share Posted September 3, 2015 fwiw, I had a car that passed without these here in MD. I even forgot they were missing. Previous owner took them out. YMMV though. Link to comment Share on other sites More sharing options...
PeterJMC Posted September 3, 2015 Author Share Posted September 3, 2015 fwiw, I had a car that passed without these here in MD. I even forgot they were missing. Previous owner took them out. YMMV though. Thanks! I'm crossing my fingers that it might get overlooked, we shall see in a few weeks. Link to comment Share on other sites More sharing options...
xt2005bonbon Posted September 3, 2015 Share Posted September 3, 2015 They'll probably still find some other issues though. They always do . Good luck! Link to comment Share on other sites More sharing options...
Imprezsing04 Posted September 3, 2015 Share Posted September 3, 2015 Wow I never visit Mid-A forum but i did today and I just so happen to have an extra oem set. It has eyebrows on it and it is a bit faded though....pretty sure it still lets enough light through to be able to pass inspection I tried using meguiars headlight restore kit but didnt work so I just got new ones instead. I have them laying around the house, you are more than welcome to borrow them. I live in Columbia, but I commute down to Arlington sometimes for work. http://i191.photobucket.com/albums/z314/imprezsing04/IMAG6036_zpsol78jedu.jpg Getting back into a Legacy?? Link to comment Share on other sites More sharing options...
I Donated thefultonhow Posted September 4, 2015 I Donated Share Posted September 4, 2015 Dude, did you buy CT08's Spec.B? Link to comment Share on other sites More sharing options...
xt2005bonbon Posted September 4, 2015 Share Posted September 4, 2015 ^ Oh you're here . How's the wrx behaving so far? Still no major or weird issues? Sorry OP. free bump! Link to comment Share on other sites More sharing options...
PeterJMC Posted September 4, 2015 Author Share Posted September 4, 2015 Wow I never visit Mid-A forum but i did today and I just so happen to have an extra oem set. It has eyebrows on it and it is a bit faded though....pretty sure it still lets enough light through to be able to pass inspection I tried using meguiars headlight restore kit but didnt work so I just got new ones instead. I have them laying around the house, you are more than welcome to borrow them. I live in Columbia, but I commute down to Arlington sometimes for work. http://i191.photobucket.com/albums/z314/imprezsing04/IMAG6036_zpsol78jedu.jpg Getting back into a Legacy?? Awesome! I'll shoot you a PM. Link to comment Share on other sites More sharing options...
I Donated thefultonhow Posted September 4, 2015 I Donated Share Posted September 4, 2015 ^ Oh you're here . How's the wrx behaving so far? Still no major or weird issues? A bit over 12,000 miles. Got a CEL a month or so ago when I turned the car off, realized I wanted to crack the window, and the engine restarted without me cranking when I moved the key back to "on." Wouldn't be a problem if Subaru got their act together and put in retained accessory power! Also had a few instances of hard starting (about 6 so far), and it sometimes bogs really badly if I don't give it enough throttle starting up from a stop. And the brake pads suck when you get them really heated up. Other than that, no problems. So far, I know it's faster than a 2015 STI, and significantly faster (no contest) than a 350Z and a newer Genesis Coupe 2.0T (the one with the power bump). All on my closed-course drag strip, of course. There is also significantly more interior room and trunk space than on the LGT, despite being 6" shorter. Power and handling are great -- better than my modded LGTs. It does get super hot inside right now. I need to get it tinted, upgrade the headunit, and get better brake pads, and I'm contemplating an AP once I get to 25,000 miles or so. Too bad my house is sucking up all my money! Link to comment Share on other sites More sharing options...
xt2005bonbon Posted September 4, 2015 Share Posted September 4, 2015 Thanks for the update. Faster than a 2015 sti? wow. not bad. How is the oil consumption? Man I think I should go test drive one. But at this point, if I can't pull LVs, monitor knocks and stuff, I'd be way paranoid. SOA, Bring the Levorg with a manual trans!!! Sorry PeterJMC for threadjacking.. Link to comment Share on other sites More sharing options...
I Donated thefultonhow Posted September 4, 2015 I Donated Share Posted September 4, 2015 Thanks for the update. Faster than a 2015 sti? wow. not bad. How is the oil consumption? Man I think I should go test drive one. But at this point, if I can't pull LVs, monitor knocks and stuff, I'd be way paranoid. Zero oil consumption at this point. Then again, my Spec.B didn't use oil either, except for a brief period before I replaced the PCV valve. And honestly, I didn't monitor my Spec.B basically at all either. With that said, you can monitor that kind of thing with an AP on a 15-16 WRX. The first test drive totally sold me on the car. The second one, 6 months later, was just to sell my wife on it. Link to comment Share on other sites More sharing options...
PeterJMC Posted September 9, 2015 Author Share Posted September 9, 2015 Dude, did you buy CT08's Spec.B? I intentionally didn't answer this because Spec didn't announce his purchase yet at the time. and yes I did buy it. Link to comment Share on other sites More sharing options...
PeterJMC Posted October 1, 2015 Author Share Posted October 1, 2015 No longer needed. I passed MD State inspection according to AndrewTech Link to comment Share on other sites More sharing options...
