07GTLEG Posted September 26, 2008 Share Posted September 26, 2008 my 07 legacy gt has the factory alarm.i saw an available shock sensor that subaru offers.has anyone installed or heard of this item? Link to comment Share on other sites More sharing options...
Whatisit Posted September 26, 2008 Share Posted September 26, 2008 i have the shock sensor. all it does is sets the alarm off if it detects a "shock". IMO, it should be standard, not optional. http://cgi.ebay.ca/06-07-Subaru-Impreza-Security-Upgrade-Shock-Sensor-OEM_W0QQitemZ220282537261QQihZ012QQcategoryZ33720QQssPageNameZWDVWQQrdZ1QQcmdZViewItem Link to comment Share on other sites More sharing options...
Grimace Posted September 26, 2008 Share Posted September 26, 2008 have it and it will certainley go off alright id be at practice and would start going off as cars pass by or a horn blows Link to comment Share on other sites More sharing options...
07GTLEG Posted September 27, 2008 Author Share Posted September 27, 2008 where does it get mounted at?and is the wiring already in place from the factory? Link to comment Share on other sites More sharing options...
LGT Dave Posted September 27, 2008 Share Posted September 27, 2008 where does it get mounted at?and is the wiring already in place from the factory? Here's a link to the install instructions: http://techinfo.subaru.com/html/downloadFree.jsp?doc_id=139274. It mounts under the front passenger seat and there is wiring taped up under there for it from the factory. If you install it yourself, you'll have to have to take the car to the dealer to have them activate it and they should also be able to adjust the sensitivity (I think...I don't have the perimeter alarm in my car). Link to comment Share on other sites More sharing options...
07GTLEG Posted September 27, 2008 Author Share Posted September 27, 2008 thanks for the link. Link to comment Share on other sites More sharing options...
07GTLEG Posted September 30, 2008 Author Share Posted September 30, 2008 can i still install the factory subwoofer if i install the shaock sensor?does it interfere with the subwoofer mounting? Link to comment Share on other sites More sharing options...
LGT Dave Posted October 1, 2008 Share Posted October 1, 2008 The subwoofer installs under the front driver seat, and the shock sensor installs under the front passenger seat. You can have both installed at the same time without any problems. Link to comment Share on other sites More sharing options...
scottmcphee Posted October 1, 2008 Share Posted October 1, 2008 The subwoofer installs under the front driver seat, and the shock sensor installs under the front passenger seat. You can have both installed at the same time without any problems. ..unless the sub sets off the shock sensor, but then you're rockin' Link to comment Share on other sites More sharing options...
07GTLEG Posted October 22, 2008 Author Share Posted October 22, 2008 i installed the shock sensor.it did not come with mounting nuts.so i reordered another kit from the dealer.waited 1 week.got the second kit.still no nuts.so i layed it on the studs until subaru gets the mounting nuts.i had the subaru dealer enable the sensor.but it still does not go off.how sensitive is this sensor suppose to be.what sets it off.i kicked the wheels and banged on the windows hard.still nothing.is something wrong? Link to comment Share on other sites More sharing options...
07GTLEG Posted October 23, 2008 Author Share Posted October 23, 2008 anybody?how sensitive is the alarm suppose to be? Link to comment Share on other sites More sharing options...
07GTLEG Posted October 23, 2008 Author Share Posted October 23, 2008 had it checked at the dealer today.they did not enable the sensor correctly the first time.now it works. Link to comment Share on other sites More sharing options...
rtbrjason Posted October 23, 2008 Share Posted October 23, 2008 Can you enable it yourself with the OEM Navi? Link to comment Share on other sites More sharing options...
Whatisit Posted October 24, 2008 Share Posted October 24, 2008 Can you enable it yourself with the OEM Navi? i was playing with the navi controls a few weeks back, and I did see a "shock sensor on/off" button. mine was already on, so I think its a yes. there wasnt a sensitivity adjustment though Link to comment Share on other sites More sharing options...
Mr. Sinister Posted October 24, 2008 Share Posted October 24, 2008 Can you enable it yourself with the OEM Navi? No. Dealer needs to do it with the Subaru Select Monitor. I installed a shock sensor a while back and haven't gotten around to getting it activated yet. Link to comment Share on other sites More sharing options...
07GTLEG Posted October 24, 2008 Author Share Posted October 24, 2008 they charged half hour labor to enable it.i installed it. Link to comment Share on other sites More sharing options...
Mr. Sinister Posted October 25, 2008 Share Posted October 25, 2008 they charged half hour labor to enable it.i installed it. Wow. It probably only took them like 2 minutes! Link to comment Share on other sites More sharing options...
07GTLEG Posted October 25, 2008 Author Share Posted October 25, 2008 this question is for you guys who have the sensor enabled.i noticed since i added this sensor that if i shut the doors and i dont turn the alarm on i get a beep sound like the one when you push the key fob to turn the alarm on.is this normal.its almost like it is self arming.i was changing the oil and had the hood open.when i shut the door after about 45 seconds it does a beep like you are turning on the alarm.does anybody else have this? Link to comment Share on other sites More sharing options...
03legacygt Posted October 25, 2008 Share Posted October 25, 2008 hey i have a 03 legacy 2.5 GT and the alarm on it used to make the lights flash every time i locked it and unlocked it but now it doesnt do that anymore and also i can open the doors with they key and the alarm doesnt go off Link to comment Share on other sites More sharing options...
07GTLEG Posted October 28, 2008 Author Share Posted October 28, 2008 anybody? Link to comment Share on other sites More sharing options...
g2redgsr Posted October 28, 2008 Share Posted October 28, 2008 How much is the shock sensor? Link to comment Share on other sites More sharing options...
g2redgsr Posted October 28, 2008 Share Posted October 28, 2008 How much is the shock sensor? + getting it activated? Link to comment Share on other sites More sharing options...
Mr. Sinister Posted October 28, 2008 Share Posted October 28, 2008 How much is the shock sensor? Depends on the year. I've seen the 05/06 go for as low as $25. 07+, no more than $75. Cost to get it activated will depend on the dealer. It could be anywhere from free to the already mentioned .5 hour labor. Link to comment Share on other sites More sharing options...
g2redgsr Posted October 28, 2008 Share Posted October 28, 2008 ah thanks. Link to comment Share on other sites More sharing options...
DesiSpecB Posted October 28, 2008 Share Posted October 28, 2008 I had it factory installed in my 07 spec b. It's just a extra little box under the passenger seat. With the navigation package you can adjust the sensitivity. It's nothing special, save your money. Link to comment Share on other sites More sharing options...
