BradyCat Posted April 16, 2009 Share Posted April 16, 2009 looks good! What wheels are those? Looks like 18" Prodrive Gt1's? Very nice. (I just ordered mine in gold:rolleyes:) 2013 Ford Taurus SHO 2009 Spec.B SWP Stg 2+ Airboy tuned 2010 Toyota Sequoia Platinum 5.7 Link to comment Share on other sites More sharing options...
fc3s86 Posted April 17, 2009 Share Posted April 17, 2009 Thanks, as for the wheels yeah, like he said. 18" Prodrive GT1's (gloss anthracite) Link to comment Share on other sites More sharing options...
Deadzep Posted April 17, 2009 Share Posted April 17, 2009 Bradycat: I did order different types of fronts than backs from EDO so that isn't an issue. Just as long as they have the ones you want... Link to comment Share on other sites More sharing options...
Al Thomson Posted April 18, 2009 Share Posted April 18, 2009 What was the Japanese price for the springs? Link to comment Share on other sites More sharing options...
brock sampson Posted April 18, 2009 Share Posted April 18, 2009 Finished installing the new STi Pinks on my '08 this morning. Just snapped a few pictures after getting back from testing out the new setup. I have to say that the improvement to handling is outstanding. This is the way the car should have been out of the factory. It did drop the height which is much welcomed so that now the car doesn't look or ride with an wheel gap that looks like it is from an outback. I have to totally recommend making the switch to Pinks over stockers. Would never go back. The part numbers I used are listed in a few posts back if anyone is interested. Been looking for something to help with all the roll/dive/squat issues I have with this car (cobb sways en route), those pics of your car (I have an 08 spec.b as well) just sealed the Pinks over the Ralliteks for me, now to come up with the extra dough.. Link to comment Share on other sites More sharing options...
katalyst Posted April 19, 2009 Share Posted April 19, 2009 did you guys do the bumpstop mod when you installed the pinks? Link to comment Share on other sites More sharing options...
EquinnoxX Posted April 19, 2009 Share Posted April 19, 2009 did you guys do the bumpstop mod when you installed the pinks? Link to bumpstop mod (cuz i had to look it up): http://legacygt.com/forums/showthread.php?t=99244&highlight=bumpstop+mod Link to comment Share on other sites More sharing options...
fc3s86 Posted April 20, 2009 Share Posted April 20, 2009 I paid 8,400yen for each spring when I picked them up in Japan. Total was 33,600yen. As for the bumpstop mod, yeah I did it. Was easy after following the above linked walk through. Link to comment Share on other sites More sharing options...
katalyst Posted April 24, 2009 Share Posted April 24, 2009 ^ any photos of the install? Link to comment Share on other sites More sharing options...
brock sampson Posted April 26, 2009 Share Posted April 26, 2009 (edited) Wondering this myself, I'll be putting a system in this weekend, asking if I would be better off getting GT sedan pinks up front and GT wagon pinks out back (ST2033021010+ ST2038021010) to offset the additional weight from the amps/sub/dynamat etc, instead of GT sedan (ST2033021010+ ST2038021000) all the way around. Also has anybody put these on without doing the bumpstop mod, hows the ride? Edited April 26, 2009 by brock sampson Link to comment Share on other sites More sharing options...
fc3s86 Posted April 27, 2009 Share Posted April 27, 2009 Sorry, the install was really straight forward and I didn't take any pics. I'm sure if you look around on the site you can find a general walkthrough for a spring install. Like I said it was straight forward and not difficult at all. The only hard point was busting some of the bolts loose. As for using the wagon springs in the back, I don't have anything extra in my trunk but I do know that the JDM wagon springs are set to handle the extra weight (around 50lbs) of the wagon rear end. So with that being said, if you think you got around 50lbs of extra weight in the back end it makes sense to use those I would think. Just my two cents, never seen anyone who has actually put the wagon rears on a sedan. Link to comment Share on other sites More sharing options...
kmfuse87 Posted April 27, 2009 Share Posted April 27, 2009 Finished installing the new STi Pinks on my '08 this morning. Just snapped a few pictures after getting back from testing out the new setup. I have to say that the improvement to handling is outstanding. This is the way the car should have been out of the factory. It did drop the height which is much welcomed so that now the car doesn't look or ride with an wheel gap that looks like it is from an outback. I have to totally recommend making the switch to Pinks over stockers. Would never go back. The part numbers I used are listed in a few posts back if anyone is interested. Are you still running the stock struts? or did you switch to JDM's? Also with the Prodrive's what tires do you have on them? Any rubbing? Link to comment Share on other sites More sharing options...
fc3s86 Posted April 28, 2009 Share Posted April 28, 2009 I am still running the stock USDM GT Spec. B Struts. The USDM Spec B struts are actually the exact same struts as the JDM GT Rev. C struts so they matched the JDM GT Pinks I got perfectly. Same fit as would be on a JDM GT. I am running 235/40/18 on the Prodrives with no problems rubbing at all. Link to comment Share on other sites More sharing options...
kmfuse87 Posted April 28, 2009 Share Posted April 28, 2009 I am still running the stock USDM GT Spec. B Struts. The USDM Spec B struts are actually the exact same struts as the JDM GT Rev. C struts so they matched the JDM GT Pinks I got perfectly. Same fit as would be on a JDM GT. I am running 235/40/18 on the Prodrives with no problems rubbing at all. I think i might have to steal your set-up, if that's ok. Looks amazing . Link to comment Share on other sites More sharing options...
atwood Posted August 3, 2009 Share Posted August 3, 2009 (edited) I purchased some pinks and USDM Bilstein Struts recently. The rear springs (ST2038021010) mounted to the struts perfectly. However, when I removed the front stock springs from the strut, the USDM spec B springs had a much larger free length than my STi Pinks (ST2033021020 for a GT-B Sedan Manual). I wanted the ST2033021020 springs to drop the front end more than the recommended spring (ST2038021010 - GT Wagon Auto and Manual.) on my '05 wagon, but the free length of the spring seems way too low. I was wondering how much the free length on the ST2038021010 spring compared to the ST2033021020 spring. I've included pics of the ST2033021020 next to the USDM Spec B spring for comparison. Should I continue with this spring or go with the ST2038021010 spring? Any help would be greatly appreciated http://i293.photobucket.com/albums/mm72/eorbeta/IMG_4194.jpg http://i293.photobucket.com/albums/mm72/eorbeta/IMG_4193.jpg Edited August 3, 2009 by atwood Link to comment Share on other sites More sharing options...
Al Thomson Posted August 4, 2009 Share Posted August 4, 2009 I dont know much but i am under the impression, from what i have read here, that the STi Spec B Springs are paired to different struts than our USDM ones. The standard Jap GT has struts like our USDM and we shoudl pick the front springs to match those. Link to comment Share on other sites More sharing options...
mad99 Posted August 4, 2009 Author Share Posted August 4, 2009 Actually, the USDM spec B uses the same exact shocks as the JDM Legacy GT (JDM GT Rev.C Bilsteins). So the USDM Bilsteins are intended to be used with certain pink springs. It's all explained much better here: http://legacygt.com/forums/showthread.php?t=61108 Link to comment Share on other sites More sharing options...
mad99 Posted August 4, 2009 Author Share Posted August 4, 2009 Regarding the spring lengths in the photos above, the difference is surprising. It's at least conceivable that the pink springs are that much shorter because they are somewhat stiffer and lower the ride height slightly. I ordered these for my spec B, but haven't installed them yet: Front P/N: ST2033021010 Free length: 9 3/16 inch Rear P/N: ST2038021010 Free length: 11 1/2 inch ANYONE know of a good suspension and alignment shop in Madison, WI? Link to comment Share on other sites More sharing options...
atwood Posted August 4, 2009 Share Posted August 4, 2009 Interesting, I was skeptical since the free length differences were huge between the pinks and the USDM spec B springs as shown. I was on a hunt for the ST2033021010, but it seems the free length is approx to the ST2033021020 spring. I'll move forward with the sprinGs I have, and keep the folks here updated on the outcome. Also, do I need JDM top hats to go with STi Pinks, or can I use the USDM Spec B top hats? Thanks! Link to comment Share on other sites More sharing options...
EquinnoxX Posted August 8, 2009 Share Posted August 8, 2009 (edited) I should prob chime in here. I'm going to preface this with the fact that a friend of mine went to Japan before I got my car and I told him to bring me back some parts long before I ever knew what I (really) wanted. My setup is: (Front Pinks) ST2033021010 (Rear Pinks) ST2038021000 Stock USDM Spec.B Bilsteins (Winter Setup) Stock Spec.B rim on Dunlop Winter Sport 3D's 225/40/18 (Summer Setup) Volk GT-V 18x8 +46 on Dunlop Z1 Star Spec 225/45/18 Albeit slightly, I do rub in the rear on both wheel setups, more on the Volks obviously. I've since banned passengers from sitting in the back and took out the spare. Pics for reference... Winter Setup: http://farm4.static.flickr.com/3308/3237641498_424b187643_b.jpg Parked On Pinks (Summer Setup): http://farm4.static.flickr.com/3564/3477879841_7445d7775b_o.jpg Rolling on Pinks (Summer Setup): http://farm4.static.flickr.com/3654/3548920449_08b1a7f2cc_o.jpg Edited August 8, 2009 by EquinnoxX 1 Link to comment Share on other sites More sharing options...
Paul1017 Posted April 11, 2011 Share Posted April 11, 2011 My pink springs arrived from Japanparts a week or so ago. Ordered the wagon MT springs front and back Front: ST2033021010 Rear: ST2038021010 Two orange paint dabs on each spring. I know they sometimes mess up orders for these, so can anyone confirm that the orange paint dabs match up with these part numbers? I'll be posting before and after pics, so it would be good to have accurate part numbers in the post for anyone interested in installing pink springs sometime in the future. Link to comment Share on other sites More sharing options...
Paul1017 Posted April 12, 2011 Share Posted April 12, 2011 Finished installing last night. Front fenders went from a 4 finger gap to 2 finger gap. Rear fenders weren't really affected. Something like 2 finger gap to just a bit less than 2, maybe 1.5 finger gap. Pretty happy with it! Getting an alignment today, then hopefully getting some pictures soon Link to comment Share on other sites More sharing options...
wizkerbizket Posted April 17, 2011 Share Posted April 17, 2011 ^ Any pics yet? Link to comment Share on other sites More sharing options...
Paul1017 Posted April 19, 2011 Share Posted April 19, 2011 I'll hopefully have time Thursday to get some pics taken and uploaded. Sorry for the wait Link to comment Share on other sites More sharing options...
Paul1017 Posted April 23, 2011 Share Posted April 23, 2011 (edited) Here are the before and after pictures: http://a3.sphotos.ak.fbcdn.net/hphotos-ak-ash1/165590_10100367942023155_12437060_61506737_3832362_n.jpg http://a2.sphotos.ak.fbcdn.net/hphotos-ak-ash4/217047_10100641985537755_12437060_63282356_7024018_n.jpg Edit: More pictures here: http://legacygt.com/forums/showpost.php?p=3360953&postcount=20 Edited April 23, 2011 by Paul1017 Link to comment Share on other sites More sharing options...
