Legacy Part Numbers.
  • Replies 329
Posted Images
  • 1 month later...
  • 3 weeks later...
Part number for Sedan rear passenger side door and wagon passenger side door?
Both 05's. I am wondering if the two doors are interchangeable. I know the glass is different, but what about the door?
Original part number 60409AG10A9P ('05-'07) was superceded by part number 60409AG10C9P ('08). No difference '05-'08, sedan or wagon.
Part number for the rear cupholder assembly (2005 LGT Sedan) on the bottom of the center console, also the piece it clips into...
#21: Center console - Rear cupholder
Original part number BLACK 66150AG01AJC ('05-'07) was superceded by part number 66150AG01BJC ('08). No difference '05-'08.
Original part number IVORY 66150AG01AWA ('05-'07) was superceded by part number 66150AG01BWA ('08). No difference '05-'08.
#19: Center console - Rear cover
BLACK 92113AG02AJC
IVORY 92113AG02AWA
I'm also missing one of the clips that holds the underside engine cover up in the front fender well. It's not the philips popit, it looks like you slip a flat head screw driver under the edge to pry it up and off.
OK, I finally got these poppits figured out. The one holding the underside cover up in the front fender well is part # 909140007 and is significantly larger than the philips poppits holding the engine cover/TMIC shroud on (part # 909130051).
Cheers!
http://i23.photobucket.com/albums/b380/TRS60586/Misc%20Legacy/parts957.jpg
http://i23.photobucket.com/albums/b380/TRS60586/Misc%20Legacy/parts958.jpg
http://i23.photobucket.com/albums/b380/TRS60586/Misc%20Legacy/parts959.jpg
http://i23.photobucket.com/albums/b380/TRS60586/Misc%20Legacy/parts960.jpg
http://i23.photobucket.com/albums/b380/TRS60586/Misc%20Legacy/parts961.jpg
http://i23.photobucket.com/albums/b380/TRS60586/Misc%20Legacy/parts962.jpg
http://i23.photobucket.com/albums/b380/TRS60586/Misc%20Legacy/parts963.jpg
http://i23.photobucket.com/albums/b380/TRS60586/Misc%20Legacy/parts964.jpg
http://i23.photobucket.com/albums/b380/TRS60586/Misc%20Legacy/parts965.jpg
http://i23.photobucket.com/albums/b380/TRS60586/Misc%20Legacy/parts966.jpg
http://i23.photobucket.com/albums/b380/TRS60586/Misc%20Legacy/parts967.jpg
http://i23.photobucket.com/albums/b380/TRS60586/Misc%20Legacy/parts968.jpg
http://i23.photobucket.com/albums/b380/TRS60586/Misc%20Legacy/parts969.jpg
http://i23.photobucket.com/albums/b380/TRS60586/Misc%20Legacy/parts970.jpg
http://i23.photobucket.com/albums/b380/TRS60586/Misc%20Legacy/parts971.jpg
http://i23.photobucket.com/albums/b380/TRS60586/Misc%20Legacy/parts972.jpg
http://i23.photobucket.com/albums/b380/TRS60586/Misc%20Legacy/parts973.jpg
http://i23.photobucket.com/albums/b380/TRS60586/Misc%20Legacy/parts974.jpg
http://i23.photobucket.com/albums/b380/TRS60586/Misc%20Legacy/parts975.jpg
http://i23.photobucket.com/albums/b380/TRS60586/Misc%20Legacy/parts976.jpg
http://i23.photobucket.com/albums/b380/TRS60586/Misc%20Legacy/parts977.jpg
http://i23.photobucket.com/albums/b380/TRS60586/Misc%20Legacy/parts978.jpg
http://i23.photobucket.com/albums/b380/TRS60586/Misc%20Legacy/parts979.jpg
http://i23.photobucket.com/albums/b380/TRS60586/Misc%20Legacy/parts980.jpg
http://i23.photobucket.com/albums/b380/TRS60586/Misc%20Legacy/parts981.jpg
http://i23.photobucket.com/albums/b380/TRS60586/Misc%20Legacy/parts982.jpg
http://i23.photobucket.com/albums/b380/TRS60586/Misc%20Legacy/parts983.jpg
http://i23.photobucket.com/albums/b380/TRS60586/Misc%20Legacy/parts984.jpg
Don't remember who it was, but a few years a member scanned the parts list and posted a link to the pdf which I saved back then for reference. I decided to make a jpg image of each page so I could post them up here (the original pdf is too big to make it an attachment). Now anybody can look up a part number on their own. I found that WorldPartsExpress.com usually has the lowest shipped price on parts and ships orders quickly.
  • 4 weeks later...
Hey, you have that document with 05 Manual Transmission stuff in there?
Found oil leaking out of my trans where the shift linkage goes in the transmission (on top, near the transmission mount). Curious to see if there's an seal ring or some type of gasket that's available.
Anyone know the part numbers for the "test mode" connectors? The ones in the passenger-side footwell that need to be connected to do a reflash... I want to run some wires from those connectors out to a switch somewhere near the steering wheel. It'd be nice to use another pair of connectors there, instreading cutting/splicing/tapping/etc.
I looked at all of the parts listings above (thanks again, TRS!) but didn't see them in there.
Thanks in advance if anyone can help me out with this...
  • 1 month later...
Hi Guys,
I'm looking for the 8 bolts that hold the Flywheel to the crankshaft, this is for a 2004 JDM Legacy 2.0 GT 5F Manual. I think the part number is 800410020, I'm not certain though. I can find the part numbers on different sites online, but I cannot confirm if that part number is actually the bolt I need. So I need help with 2 things;
1 - can anyone confirm part number 800410020 is indeed this bolt I'm looking for?
2 - does anyone in Trinidad know where I can source it locally, if not I can order based on confirmation from my 1st request.
I'll try to post some pics of it ASAP.
Here's some more details;
  • Bolts for securing Flywheel to Engine Crankshaft
  • 8 required
  • black in color
  • Grade 8 or higher in strength
  • 1 inch in length
  • 1.0 thread pitch (extra fine)
  • round head with HEX inside for tightening
  • I think the part number is 800410020, I'm not certain though
Much thanks in advance to anyone that can help with this......
Body shop did a number on an interior part that they had to take off in order to repair the outside. :(
THey did an awesome job on the body work and paint but as you know those interior parts can break easily.
Before I go in there to talk to thema bout it I thought I would find out what the part number was and how much it costs to replace.
THis part I realize is rarely replaced so I haven't found the part number anywhere.
Hoping OPIE or someone connected can get me a price.
RH Cover Lid
94053AG56AOR
I also might need the LH too but don't have part number.
Thanks!
OK so they are $32 bucks online.
Not the end of the world so I can sleep now.
What exactly do they mean by superseded.
Why the new part number?
Did the design change?
Also how do I know its going to be the right color?
Lastly I need to pick a web site.
Anyone have a favorite:
I found the part on the following sites:
subaruparts.com
1stsubaruparts.com
subarupartswarehouse.com
thanks
  • 1 month later...
For when things go really wrong :lol:
http://img241.imageshack.us/img241/7408/pic1oi2.jpg
Does anyone know what the part 21204A shown at the left above does? Like what flows through it. Random question I know, but I have a good reason for wanting to know.
Also, please respond if you know for sure because I could guess myself.
Anyone can help with part numbers of V-belts? There's two of them, one for air conditioner & one for power steering. Couldn't find them on the charts above. Seems like only timing belt is there.
  • 1 month later...
I was wondering if anyone had a Throttle Position Sensor part number and a TGV position sensor part number for an 05 LGT. I broke my TGV sensor and no one seems to be able to find one and it may be very possible that the TPS and the TGV sensor share the same part #'s. Thanks Edited by labeldzero
All Pop-Its not created equal... Hi Guys. I'm trying to identify the correct part number for the pop-its that hold the forward rear mudflap in place. These are not the flaps themselves, but the smaller "protector" for lack of a better word, that sit at the bottom front of each rear wheel well. They do not have a phillips head, and appear to be smaller than those used for the under engine cover... and various other areas.
This isn't it >> 909130051 - I believe these have a phillips head.
http://www.subarupartsforyou.com/cp_partdetail.php?partid=15982
This looks very possible >> 909140007
http://www.subarupartsforyou.com/cp_partdetail.php?partid=14165
I've dug around, looked through the vacation pics, etc... All help is appreciated.
