InsertEnigmaHere Posted November 5, 2013 Share Posted November 5, 2013 Before you say anything, I've done my homework. I checked for vacuum leaks with a smoke test, tested the neutral safety switch which was OK, and cleaned the IACV. But on cold days I'm still having issues with stalling when coming to a stop before the engine has completely warmed up. It only stalls if the car's been sitting overnight and then is fine for the rest of day usually. It definitely seems to be cold weather related. What other things should I look into? Cleaning the throttle body? TPS? Thanks! Link to comment Share on other sites More sharing options...
