Blue Posted July 18, 2015 Share Posted July 18, 2015 I recently had a few upgrades installed: GS Uppipe Cobb Downpipe Cobb Stage 2 Map I expected a bit of a different sound, but what I've got sounds rather odd. There is more turbo whistle audible, but there's a stammer/stutter to the whistle. Kind of like if you were whistling and vibrating your tongue simultaneously. The stutter is tied to engine RPM, not to road speed, and is only audible when the turbo whistle is audible. I hear it most clearly while accelerating gently in first and second gears. Seems to be audible only, power delivery is smooth. There doesn't seem to be any effect at higher boost levels - although it may still be happening, it's just harder to hear over other engine/exhaust/wind noises under higher load or higher speeds. Normal? Fluttering wastegate? Leaking vacuum connection? Link to comment Share on other sites More sharing options...
MoarBoost Posted July 21, 2015 Share Posted July 21, 2015 My first guesses are yours--wastegate flutter or loose/leaking vacuum line. Seem like easy things to pinch or only partially reassemble when installing up- and downpipe. Wish I had more advice other than it's probably not the turbo itself. I'd check the vacuum lines and then do the 'ol bubble test on them. Link to comment Share on other sites More sharing options...
Blue Posted July 22, 2015 Author Share Posted July 22, 2015 For anyone who's curious, I recorded an mp4 audio file. http://vocaroo.com/i/s1IXg8HkYnNn Link to comment Share on other sites More sharing options...
JmP6889928 Posted July 28, 2015 Share Posted July 28, 2015 Exhaust leak Link to comment Share on other sites More sharing options...
ras06LGT Posted July 28, 2015 Share Posted July 28, 2015 Video sounds like you are driving through a tunnel, but my turbo makes a similar sounding noise. It started when I swapped to a BNR16G from the stock turbo 3 years ago. I always assumed it was wastegate flutter. Maybe it's actually a small exhaust leak. I'll feel really dumb if that's the case, although I've never noticed any telltale signs of carbon build-up you usually get from exhaust leaks. JmP, where would the leak be most likely to cause this sort of noise? Link to comment Share on other sites More sharing options...
JmP6889928 Posted July 28, 2015 Share Posted July 28, 2015 Back side of the up pipe where it attaches to the turbo. Start the car, wet your hands, and then put them around all of the flanges on the up pipe-turbo end and manifold end, and I'll bet you'll find a leak. Wet hands feel the air immediately. Link to comment Share on other sites More sharing options...
Blue Posted July 31, 2015 Author Share Posted July 31, 2015 JmP - I tried wet hands around where the uppipe meets the turbo, but didn't feel any air. Could the leak be between the cylinder head and the exhaust manifold? Is what I'm hearing a "low pressure" exhaust pulse? Thanks! Link to comment Share on other sites More sharing options...
KevinA Posted July 31, 2015 Share Posted July 31, 2015 My car makes a very similar noise when i'm about 1/4 of a quart down on oil. Link to comment Share on other sites More sharing options...
JmP6889928 Posted August 1, 2015 Share Posted August 1, 2015 JmP - I tried wet hands around where the uppipe meets the turbo, but didn't feel any air. Could the leak be between the cylinder head and the exhaust manifold? Is what I'm hearing a "low pressure" exhaust pulse? Thanks! Certainly could be. Also where up pipe bolts to manifold and don't rule out front O2 sensor. It can be bad without setting a CEL and causes all kinds of driveability issues. Link to comment Share on other sites More sharing options...
