rayeve Posted December 9, 2014 Share Posted December 9, 2014 My wife has a O5 Legacy wagon. Recently the drivers door lock quit responding to the remote key, BUT ONLY the driver's door -- the others work okay. Is there a separate fuse for the drivers door, or it likely that the relay or rods that work the lock are the problem. Many thanks. Link to comment Share on other sites More sharing options...
HDZ32 Posted December 9, 2014 Share Posted December 9, 2014 Mine did the exact same thing, I have to lock/unlock the drivers door manually now. Kinda figured something went out. Link to comment Share on other sites More sharing options...
P-UNIT Posted December 15, 2014 Share Posted December 15, 2014 Also started having this issue recently. Haven't had time to troubleshoot, but if one of you solve the problem first please let me know what the fix was, I'll do the same. Thanks! Link to comment Share on other sites More sharing options...
rayeve Posted December 16, 2014 Author Share Posted December 16, 2014 Unfortunately, I'm away from the car in question for the next three weeks, but will try to let you know what I find out eventually. Link to comment Share on other sites More sharing options...
MrTris Posted December 17, 2014 Share Posted December 17, 2014 Im guessing it's an actuator issue. Get up close, put your ear to the lock if you have to while pressing the unlock button. Do you hear movement, or restricted or failure thereof? If so, I suggest lubrication with something like Fluid Film, and, if that doesn't work, replacement of either the actuator or the solenoid. Link to comment Share on other sites More sharing options...
Gasaraki Posted December 17, 2014 Share Posted December 17, 2014 I had both my rear doors unable to lock and unlock, even manually. The dealer replaced the actuator in the door locks. Link to comment Share on other sites More sharing options...
