Redstriker's LGT Journal
http://i182.photobucket.com/albums/x51/redstriker09/Car%20mods/IMG_20111231_153409.jpg
Tracking/diary of my ride's progress in mods/accessories/etc.
Engine/Power
K&N High-flow Air Filter
Cobb Accessport V2-003 (Stage 2 - McDowell Tunning)
Intake silencer delete
Complete 3" Invidia Turboback Exhaust w/ Downpipe
RacerX TMIC
RacerX Charge Pipe
Turbosmart Kompact Full Recircullating BOV
Suspension
Whiteline Rear Differential Inserts - KDT903
Whiteline Crossmember Mount in Cradle - KDT902
Whiteline Rear Differential Bushings - KDT906 (in possession, might not install them due to them being a PITA)
Whiteline Rear Lower Shock Mount Bushings - WHI W0505 (in possession, not installed)
Whiteline Rear Sway Bar 24mm - BSR49XXZ
Whiteline Roll Center & Bump Steer kit - KCA313 (in possession...)
Rallitek HD Rear Swaybar Endlinks
GTSPEC Rear Strut Brace - GTS-SUS-1425
GTSPEC Front Strut Brace - GTS-SUS-1387
GTWORX's Blistein setup
Cusco Rear Side Member Power Brace - SUS-RSM-CUS-LGT2
Cusco Front Member Power Brace - SUS-FMB-CUS-LGT2
Group N 02-07 WRX/STI Front Strut Mount
Transmission
TiC Crossmember Bushings
Group N Transmission mount - 5 Speed
Subaru STI Short Shifter
Perrin Shifter Bushing w/ STI washer
Brakes
Mach V Braided Brake Line Set
DBA 4000 rotor -fronts
Centric Premiun Rotors - rears (in possession, not installed)
Hawk HPS pads
ATE SuperBlue
Exterior
RallyArmor mudflaps
Subaru Puddle Lights
Subaru Foglights
25% tint
Plasta-dip front grill
Plasta-dip chrome window trim
Wheels
Stock LGT 18X7.5 with Michelin Pilot Super Sports 225/45-18 (maybe powdercoated in the future, still deciding)
Interior
Pilot Automotive Pedals - PM-211
Valentine V1 radar detector
All weather floor mats
Other
Fumuto Drain Valve
OEM Subaru Oil Filter
Rotella T6 5W-40
My philosophy on this on-going build - "What is the point of having power if it is not able to handle it? Make sure it handle the power in any circumstance."
I'll Keep on updating this as the mods continue to add on.
  • Replies 182
  • Created
  • Last Reply
Reserved
This slot is for future mods that I haven't bought yet. Got to keep everything in one place with easy access.
Exterior
Grimmspeed front plate mount
JDM rear spoiler
Tint headlights and tail lights
Primitive Skidplate 3/16"
Hella Supertone Horn Kit
Engine/Power
E85 conversion(including pumps/injectors)
Suspension
Whiteline Front Sway Bar 26mm - BSF41XZ
Whiteline Rear Camber Adjustment Bushings - KCA326
Whiteline Front Control Arm Bushings - W0506
Whiteline Rear Control Arm upper inner bushings - W63225
GTSPEC Front 4 point Ladder Subframe Reinforcement - GTS-SUS-1403
CUSCO Rear Trailing Arms - GTS-SUS-1408
Cusco Subaru Legacy BM9 Power Brace Rear Member
AVO Caster Adjustment Bushing System - S1B10M1GV001T
Transmission/Brakes
Exedy Racing Stage 2 Clutch Kit
Interior
Prosport Dead pedal
Cobb 6speed knob
Subaru Interior Illumination Kit
STI Manual Pedal Set
Carbon Fiber Trim
Nice ride BUT I must insist that you change your picture! You can't top your journal off with a picture of your sweet ride with a big bird crap on the hood!
:lol::cool:
I know, but it was the only good pic I had on my pb. I will try to put up a better pic tonight.
Updated things to buy and things installed. Just finished installing the Group N trans mount and TiC crossmember bushings. I can actually hear the engine now, and the shifting feels a bit more refined.
Trans mount and bushings causes increased cabin noise?
there's a lot of info that you can search for increased noise and vibration when installing these.
Most every mod is a trade on
Performance improvement v.s. increased vibration/noise transmitted to the engine compartment.
Tires, exhaust, intake, bushings, ....
A lot of people here can't seem to understand that concept.
WAIT YOU MEAN A SOLID BUSHING IS GOING TO MAKE NOISE?!?!
:lol:
Not sure for your car or not, the stage 2 exedy requires a wrx flywheel check into it more I recommend the infamous site
Sent from my Droid Incredible 2 using Tapatalk
StageIII Cryotune-Kinugawa STS TD06H-20GTX 9 blade turbine, ID1000, DW65c, 73mm MegaMAF , GS EWG up-pipe, Downpipe and EBCS, FMS FMIC, TGV Delete, Brembo swap
