vanman281 Posted March 25, 2011 Share Posted March 25, 2011 I am having car troubles which I think may be due to the fuel system. While driving agressively the car sputters and will not continue to pull. It seems as if the car is not getting fuel. I pulled over and couldn't get the car to start. It turns over but that's all it'll do. The car has plent of battery life left and doesn't seem to be leading to anything else. If I drive the car carefully i.e. giving it a little gas it doesn't have a problem, only when I give it a lot. Any ideas would be much appreciated! Link to comment Share on other sites More sharing options...
Zues Marine Posted March 25, 2011 Share Posted March 25, 2011 i'd try cleaning your MAF first and foremost Link to comment Share on other sites More sharing options...
vanman281 Posted March 27, 2011 Author Share Posted March 27, 2011 I'll clean the maf tomorrow. The main problem with the car right now is it sputters at idle, prolly once every 5-10 seconds. The car didn't run bad until my dad and I installed my new clutch and everythign with the timing belt. I got it running after putting the cam sensor back in.. my mistake. As of now I am throwing 7 codes, Ill update the actual codes tomorrow. Two are o2 sensors front and rear.. I am also throwing a p1101 which is a Neutral Position Switch Circuit Malfunction and I am throwing a couple others. List will be updated! Oh and the check engine light is blinking.. Car is running fine otherwise Link to comment Share on other sites More sharing options...
babybaluga32 Posted March 27, 2011 Share Posted March 27, 2011 I threw an O2 sensor code because my maf was dirty (which threw a code too- MAF low voltage) and it made it run rich (hence the fouled plugs and O2's) Somebody is going to say your timing is off. Did you double check it? Link to comment Share on other sites More sharing options...
Lookatmyrust Posted March 27, 2011 Share Posted March 27, 2011 is your timing off? you should double check that. Link to comment Share on other sites More sharing options...
vanman281 Posted March 27, 2011 Author Share Posted March 27, 2011 I'm not positive if the timing is off. My dad was the one who put the belt on.. We have seen it done but not done it ourselves. I didn't double check the timing. That is one thing i'll check. If the timing was off would the car run good? It pulls hard while driving. It's only at idle. If the timing was off would that throw seven different codes? Link to comment Share on other sites More sharing options...
Lookatmyrust Posted March 27, 2011 Share Posted March 27, 2011 its hard to say. the timeing can be off in over 100 ways. each cam wheel can be off 2 teeth each directions. so whats 1x2x3x4x5x6x7x8. thats how many different ways the timing can be off. if you have it 2 teeth off ever time.. other wise its 1x2x3..x16. ways. hahaha. i think thats how my math teacher taught that. Link to comment Share on other sites More sharing options...
vanman281 Posted March 27, 2011 Author Share Posted March 27, 2011 If my timing was off, do you think the car would sputter at the same times? It also doesn't sputter while the motor is cold, only when it's warm. Thanks for the help by the way!! Link to comment Share on other sites More sharing options...
johnegg Posted March 27, 2011 Share Posted March 27, 2011 with 8 codes, i would re-check all the wire connectors on the engine, especially the ones on the passenger side rear. and all the wires on the trans, i know there aren't many. something is unplugged. did you pull the engine or the trans to do the clutch? Link to comment Share on other sites More sharing options...
vanman281 Posted March 28, 2011 Author Share Posted March 28, 2011 We pulled the engine. Ill be checking over all the wires. The car only sputters when it is warm.. Cat? 02? I am throwing both 02 sensors haha. This started happening after we pulled the motor though. Link to comment Share on other sites More sharing options...
Lojasmo Posted March 28, 2011 Share Posted March 28, 2011 Would look at the O2 sensor plugs. Link to comment Share on other sites More sharing options...
