spad Posted February 5, 2013 Share Posted February 5, 2013 hi all, hooray! finally finished changing stock radio in my baby (attached are couple of photos before/after) as i was installing wires for my subwoofer i noticed couple of wires behind the cover near the driver'sfoot. does anyone have any idea what these are? i understand its a long shot... i did not try to connect them, nor did i spend much time finding out where they go. but maybe its something factory-preinstalled? any ideas what could it be? thanks in advance! Link to comment Share on other sites More sharing options...
underground000 Posted February 5, 2013 Share Posted February 5, 2013 the green test connectors? yea those are not meant to be connected unless you need to.... flashing ecu... 5eat downshift rev match:) Powder coated wheels: completed:) Link to comment Share on other sites More sharing options...
Nolmers06LGT Posted February 5, 2013 Share Posted February 5, 2013 The 05's have an onboard code reader. If you get a CEL, connect the white plugs, turn the key to on without starting the car, and press the trip button. There's a thread on here about it- do a search. The green connectors on the passenger side are the ones for test/ecu flash. Link to comment Share on other sites More sharing options...
Nolmers06LGT Posted February 5, 2013 Share Posted February 5, 2013 PS... Is there really such thing as a 3.0R 05 SpecB? I'm pretty sure the OP has a 2.5 block like the rest of the 4th gens.. Link to comment Share on other sites More sharing options...
RabidWombat Posted February 5, 2013 Share Posted February 5, 2013 PS... Is there really such thing as a 3.0R 05 SpecB? I'm pretty sure the OP has a 2.5 block like the rest of the 4th gens.. European market has one. And since the first picture shows temperature in C, I suspect that's the case. Link to comment Share on other sites More sharing options...
Nolmers06LGT Posted February 5, 2013 Share Posted February 5, 2013 European market has one. And since the first picture shows temperature in C, I suspect that's the case. That makes sense- I looked it up after posting. I like the idea of the flat 6 in the 4th gen legacy.. I'm just kinda surprised by the low torque output. Link to comment Share on other sites More sharing options...
spad Posted February 6, 2013 Author Share Posted February 6, 2013 That makes sense- I looked it up after posting. I like the idea of the flat 6 in the 4th gen legacy.. I'm just kinda surprised by the low torque output. European it is I prefer not to deal with turbos... and this boxer runs very smoothly. Yes, more torque would be appreciated. Right now if I want any kind of proper response I have to keep revs over 5000. this is not a problem but mpg suffers tremendously in this case good thing is that gear ratios are quite close to each other. Sent from my GT-N7100 using Tapatalk 2 Link to comment Share on other sites More sharing options...
