Jimblaz Posted September 9, 2010 Share Posted September 9, 2010 Wooooo!!!! got it all wired up tonight after work. Loooooks BEAUTIFUL. Matches the display perfectly. i just gotta run the pressure tubing tomorrow and ill be set. :-) Link to comment Share on other sites More sharing options...
stocklgt Posted September 9, 2010 Share Posted September 9, 2010 I think that's why he has some to spare. Whoohoo! An appointment I had after work with a client has been cancelled. That means I've got 3 hours to work on my car. But first I'm going to put on the STi spoiler, and if I have time, this boost gauge will go in too. HAHA around the tail light...nothing wrong with adding a little slack, or having extra so you don't have to take a second trip! I was talking about having extra fuse taps left over, even though I do have extra vacuum hose as well. I bought 10 feet in case I accidentally split a line while running it from the engine bay to the wheel well or through the firewall. Link to comment Share on other sites More sharing options...
lossol Posted September 10, 2010 Author Share Posted September 10, 2010 A quick update for those who are interested in a RHD VBG1...I have ordered the pcb. It will look somthing like this: The display unit PCB main board stays the same, the mounting pcb board changes shape (reverses dimensionally only). The graphic overlay will also have to change. I still need to order the graphic overlay. VBG1 gauges available at www.gtboostgauge.com Link to comment Share on other sites More sharing options...
Pinky Posted September 10, 2010 Share Posted September 10, 2010 subscribe Link to comment Share on other sites More sharing options...
Jimblaz Posted September 11, 2010 Share Posted September 11, 2010 mine is working beautifully. only problem i have is every once in awhile i have a red led right in the middle that just stays on. Any ideas as to why?? Link to comment Share on other sites More sharing options...
lossol Posted September 11, 2010 Author Share Posted September 11, 2010 Hmmm, I have not seen this problem before. Can you tell which LED it is? is it always the same LED? If we cant fix it remotely then I will have you send it back and I will replace your display unit. VBG1 gauges available at www.gtboostgauge.com Link to comment Share on other sites More sharing options...
Jimblaz Posted September 11, 2010 Share Posted September 11, 2010 its one of the leds when im at the most vacuum. It has only done it twice. i believe its the same one both times tho. i will see if i can snap a picture or two of it if it happens again. Link to comment Share on other sites More sharing options...
jproy12 Posted September 13, 2010 Share Posted September 13, 2010 I'm still loving this gauge! The only downside I've seen is that while boosting, I hear this small wistle coming from the sending unit. Other than that great gauge! Stock car I'm boosting at 13,2-13,7psi peak! JP Link to comment Share on other sites More sharing options...
07DGMSpecB Posted September 13, 2010 Share Posted September 13, 2010 I'm still loving this gauge! The only downside I've seen is that while boosting, I hear this small wistle coming from the sending unit. Other than that great gauge! Stock car I'm boosting at 13,2-13,7psi peak! JP did you put a zip tie or something around the vacuum hose at the connection? And what size vacuum line are you using? I have a a zip tie around a 5/32 hose that i'm using and have no problems. By the way, finally got the gauge wired up this past weekend and Its awesome, all my friends are amazed. Its great to see gauges getting away from the conventional circular pod design! Link to comment Share on other sites More sharing options...
jproy12 Posted September 13, 2010 Share Posted September 13, 2010 did you put a zip tie or something around the vacuum hose at the connection? And what size vacuum line are you using? I have a a zip tie around a 5/32 hose that i'm using and have no problems. By the way, finally got the gauge wired up this past weekend and Its awesome, all my friends are amazed. Its great to see gauges getting away from the conventional circular pod design! Yea, fixed my leak... the tubing wasn't tight... put zip tie on it and all seems good! I also measured the hose.. its OD:0.25'' and its ID:0.17'' which is what Andy recommended! JP Link to comment Share on other sites More sharing options...
mattg Posted September 13, 2010 Share Posted September 13, 2010 I may have missed it, but when will these be back in stock? Link to comment Share on other sites More sharing options...
mclarenf3 Posted September 13, 2010 Share Posted September 13, 2010 Just gotta keep checking his site (not here). When they become available, you'll see it on the store page. Link to comment Share on other sites More sharing options...
mattg Posted September 13, 2010 Share Posted September 13, 2010 So there hasn't been a mention of a time frame? Link to comment Share on other sites More sharing options...
mclarenf3 Posted September 13, 2010 Share Posted September 13, 2010 Nope, just seems to be releasing a few every week or so. Link to comment Share on other sites More sharing options...
yogis wagon Posted September 14, 2010 Share Posted September 14, 2010 VGB1 are available now, I'm order 59 !! Link to comment Share on other sites More sharing options...
Silvercorona Posted September 14, 2010 Share Posted September 14, 2010 ARG!!! I missed it again I will get one of those damn unicorn gauges eventually. Link to comment Share on other sites More sharing options...
Corny357 Posted September 15, 2010 Share Posted September 15, 2010 Suggestions for those of us that do not have the area/space/room/tools required to do the install? I'm at college right now and I park outside in a residence hall parking lot...is there a set of instructions I can give to a good shop around here to install the thing without f-ing up the wiring/failing to make it neat? Link to comment Share on other sites More sharing options...
Jimblaz Posted September 15, 2010 Share Posted September 15, 2010 find a friend with some tools and a garage. Its not worth spending money to do. SOOOOOO easy to put this gauge in. Link to comment Share on other sites More sharing options...
Corny357 Posted September 15, 2010 Share Posted September 15, 2010 Okay, so if the install is so easy, then if I couldn't find someone willing to let me use their garage and tools, I should have no problem trusting a shop to do it properly/neatly, correct? Link to comment Share on other sites More sharing options...
DrSpeed Posted September 15, 2010 Share Posted September 15, 2010 geezus, 10 feet? Are you wrapping it around the tail light twice? Seriously...we're going from the the center of the engine, through the firewall via the fender, and into the fuse box outboard of the steering column. So, you guys using all of 10 feet for vac hose? BANNED FROM THE TIKI FORUM. Link to comment Share on other sites More sharing options...
Umass94 Posted September 15, 2010 Share Posted September 15, 2010 My car is at the shop (ESP in Serling, MA) right now getting this gauge installed. can't wait to pick it up. Here's proof: Just 1 minute after buying my OBXT, I had 7 phone calls from insanely hot women, and got 7 dates out of it. Coincidence? I think not. Link to comment Share on other sites More sharing options...
mclarenf3 Posted September 15, 2010 Share Posted September 15, 2010 I had to buy 10' too. They didn't sell any less. I've got the gauge installed with the wiring done. Just gotta do the vacuum hose part, and cutting into the BOV line. Which fuse were you guys using for the parking lights input? I couldn't really find any, and just put it to "Illumination" but that's not really dimming the gauge at all. Is that what that input is for? Or is it something else? Link to comment Share on other sites More sharing options...
jproy12 Posted September 15, 2010 Share Posted September 15, 2010 +1 to that, where does everyone tap-in for the wiring of the illumination? I have it setup for auto right now, but I'd like to get it done sooner than later! Loving this gauge and all aspects of it! The only thing left is to wire the illumination wire somewhere to dim the gauge while diming the cluster and all! JP Link to comment Share on other sites More sharing options...
mclarenf3 Posted September 16, 2010 Share Posted September 16, 2010 I just finished up the tube part of the install, and it all looks great. I ended up using about 6' from the 10' of tubing I bought, so it's actually not all a waste. Now I just gotta figure out what I'm reading on the boost gauge. Link to comment Share on other sites More sharing options...
DrSpeed Posted September 16, 2010 Share Posted September 16, 2010 Am I missing something, or where in the manual does it say we should find the best Key on 12v, ground, 0-5 v signal for the AFR part of the gauge, and 12V signal for lights? BANNED FROM THE TIKI FORUM. Link to comment Share on other sites More sharing options...
