DogLeggGT Posted October 9, 2008 Share Posted October 9, 2008 Howdy. I have some adhesive from duct-tape backing that has worked its way in the carpet in my car. I've looked in forum for suggestions and dont' see anything that might help with such a tough cleaning problem. Any suggestions? Link to comment Share on other sites More sharing options...
bnguyenbb6 Posted October 9, 2008 Share Posted October 9, 2008 Maybe try an extractor? I know you cant get one of those steamers into the car but they make little ones that some detailers use for carpet. Link to comment Share on other sites More sharing options...
forestir Posted October 9, 2008 Share Posted October 9, 2008 You may want to search or ask over at autopia.org where there are a bunch of detailing fanatics. In theory, something like WD-40 would work at removing the duct tape adhesive, and then use regular carpet cleaner/shampoo to remove the WD-40. I haven't tried this, so would recommend you try out on some carpet scraps first. Link to comment Share on other sites More sharing options...
DogLeggGT Posted October 9, 2008 Author Share Posted October 9, 2008 Thanks for the ideas. Will look into them. Link to comment Share on other sites More sharing options...
sooberoo Posted October 9, 2008 Share Posted October 9, 2008 Try "Goo gone". Its a citrus based cleaner and should do the job. Just apply it to a clean cloth and rub it into the affected area and let it sit for a while while it dissolves the adhesive. After awhile dab away whatever residue you can and then follow up with a good quality carpet cleaner. I think the active ingredient in Goo gone is citronella oil, so unknown if residual oil will stain lighter color carpets. If this is the case, follow up the Goo gone application with"Spot Shot". I think that it contains a low concentration chlorinated solvent that may be just enough to remove the residual oils while not dissolving your carpet fibers. Good luck, I have my fingers crossed for yah! Link to comment Share on other sites More sharing options...
c-lo Posted October 9, 2008 Share Posted October 9, 2008 could also try a can of canned air. turn it upside down and spray. we used to use it in hotels to get gum off the carpets. it froze the gum making it easier to get out. 258k miles - Stock engine/minor suspension upgrades/original shocks/rear struts replaced at 222k/4 passenger side wheel bearings/3 clutches/1 radiator/3 turbos Link to comment Share on other sites More sharing options...
CzarDestructo Posted October 9, 2008 Share Posted October 9, 2008 Try "Goo gone". Its a citrus based cleaner and should do the job. Just apply it to a clean cloth and rub it into the affected area and let it sit for a while while it dissolves the adhesive. After awhile dab away whatever residue you can and then follow up with a good quality carpet cleaner. I think the active ingredient in Goo gone is citronella oil, so unknown if residual oil will stain lighter color carpets. If this is the case, follow up the Goo gone application with"Spot Shot". I think that it contains a low concentration chlorinated solvent that may be just enough to remove the residual oils while not dissolving your carpet fibers. Good luck, I have my fingers crossed for yah! Goo Gone is some pretty fantastic stuff. I was rolling around under a large truck doing some work and ended up getting a few globs of heavy machine grease on the hood of my jacket and never noticed. Got in my car and smeared it all over the head rest and upper back of the seat. Looked HORRIBLE. Goo Gone cleaned every last bit of it out and didn't leave any stains or marks. Needless to say I was very happy considering my car was only two months old at the time. edit: Very important. This was Charcoal leather, not cloth seats! Link to comment Share on other sites More sharing options...
DogLeggGT Posted October 10, 2008 Author Share Posted October 10, 2008 Nice. I knew about Goo Gone, but didn't have any experience with its efficacy. I'll probalby get around to trying out these suggestions in a week or so when more time frees-up. Probably try the carpet cleaner first and then the Goo Gone for residual (of course I'll test it on a small portion first for colorfastness ) Link to comment Share on other sites More sharing options...
