sooby Posted August 20, 2011 Share Posted August 20, 2011 I have an 05 LGT 5 speed I bought it in Early June with 42k and the car is clean. Always synthetic oil changed at dealer every 5k with complete history. In late June I bought the cobb AP and uploaded the stage 1 MAP 93 octane. I always put 93 octane in the car and never had a problem. Last night I drove the car to a friends place with no problems. On the way back I got a check engine light and the cruise control light started flashing at me. I tried to engage the cruise control but that didnt work. I have no idea what caused this problem as my driving habits have been pretty consistent. These past 2 weeks, however, I have only been driving the car only every 2 or 3 days but I highly doubt that causing my problem. Thank you in advance for you all of your help. I am very appreciative. Link to comment Share on other sites More sharing options...
mdzowner Posted August 20, 2011 Share Posted August 20, 2011 part of the reason all those lights are on is because its in a sort of "safe mode". it happened to me the other day because i threw a code for low coolant temp. mutltiple lights come on and cruise is disabled to basically tell you to get it looked at asap by taking away some functionality. in some cars you can ignore a cel, but your less likely to do it if you cant use your cruise too. in my 07 i cant switch to si mode either. sorry for the long post. just get it looked at asap. Link to comment Share on other sites More sharing options...
AZP Installs Posted August 20, 2011 Share Posted August 20, 2011 You have an AP right? Use the diagnostics on it to pull the CEL code and let us know what it is, then we can help you better. -mike http://www.pbase.com/paisan/image/91072632.jpg http://www.pbase.com/paisan/image/133406601.jpg AIM: AZP Installs | E-mail: paisan@azpinstalls.com | 725 Fairfield Ave | Kenilworth, NJ 07033 | 908.248.AZP1 (2971) | T-1 Certified Amsoil Dealer "Race Tested, Enthusiast Approved!" Link to comment Share on other sites More sharing options...
sooby Posted August 20, 2011 Author Share Posted August 20, 2011 oh dang I am actually away from home and my AP for the next 2 weeks ( I go back labor day weekend) should I just not drive my car at ALL in the meantime? Can I go to autozone / advance for them to run a free diagnostic scan? Oh man now I am getting super worried. I guess I wont know how bad it is really though until I get the CEL CODE and post it up here. Thanks mdzowner and azp installs for your help !!! Link to comment Share on other sites More sharing options...
AZP Installs Posted August 20, 2011 Share Posted August 20, 2011 Where are you? Perhaps someone local has a code reader? Autozone should work too. -mike http://www.pbase.com/paisan/image/91072632.jpg http://www.pbase.com/paisan/image/133406601.jpg AIM: AZP Installs | E-mail: paisan@azpinstalls.com | 725 Fairfield Ave | Kenilworth, NJ 07033 | 908.248.AZP1 (2971) | T-1 Certified Amsoil Dealer "Race Tested, Enthusiast Approved!" Link to comment Share on other sites More sharing options...
sooby Posted August 20, 2011 Author Share Posted August 20, 2011 Ok i just got back from autozone and the code came back as p1518 on google it says starter switch circuit low input. what does that mean? Some other sites say that it is an idle air control IAC or could be Manf Cntrl Veh. Spd. Idle speed Control? Any idea on what the real problem is? I did a search and found these direction to alleviate the problem but this is way over my head: posted on: 09-05-2007 by member: rc0032 P1518 -> CR:dTC P1518 STARTER SWITCH CIRCUIT LOW INPUT Diagnostic Procedure with Diagnostic Trouble Code (DTC) Step Check Yes No 1 CHECK FOR ANY OTHER DTC ON DISPLAY. Is any other DTC displayed? Inspect the DTC using “List of Diagnostic Trouble Code (DTC)”. <Ref. to EN(H4DOTC)(diag )-69, List of Diagnostic Trouble Code (DTC).> Go to step 2. 2 CHECK HARNESS BETWEEN STARTER RELAY AND ECM. 1) Disconnect the connectors from starter relay and ECM. 2) Measure the resistance of harness between ECM and chassis ground. Connector & terminal (B135) No. 32 — Chassis ground: Is the resistance more than 1 MΩ? Repair the ground short circuit between starter motor and ECM. Repair the poor contact in ECM connector. Thanks again for your help. Link to comment Share on other sites More sharing options...
Max Capacity Posted August 21, 2011 Share Posted August 21, 2011 I would clean the battery terminals first. IMO corrosion will cause low voltage. How old is the battery ? Could be time for a new one. I replaced my oem battery at about 5 years. A good battery will last about 7 years. Most fail in the 5-6th year. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
AZP Installs Posted August 22, 2011 Share Posted August 22, 2011 I would clean the battery terminals first. IMO corrosion will cause low voltage. How old is the battery ? Could be time for a new one. I replaced my oem battery at about 5 years. A good battery will last about 7 years. Most fail in the 5-6th year. Great advice. Always start with the simple/inexpensive things and go from there. A dead battery will cause lots of "weird" issues. 5 years is the max these batteries will last. I usually go with the Walmart "MAX" battery as a replacement. Inexpensive and if you need a free replacement (3 or 5 years replacement warranty) you are never too far from a Walmart. -mike Link to comment Share on other sites More sharing options...
sooby Posted August 22, 2011 Author Share Posted August 22, 2011 I really wish it was the battery but I know the seller replaced the battery at the dealership right before I bought the car 3 months ago. The terminals are super clean too. Do I need a new starter or .. What exactly are the cables that connect the battery to the starter? If it is a low input to the starter I am thinking it could be because the cables/ connections is bad? Thank you guys sooo much for the help. Any other ideas of what this p1518 code could mean? Link to comment Share on other sites More sharing options...
AMZ Posted August 23, 2011 Share Posted August 23, 2011 I just had the same symptoms appear. It came up when I first started the engine after replacing the timing belt. I also had the radiator off, coolant drained, etc. The engine runs fine, but I'm looking for a way to identify and remedy the fault. Perhaps a coolant level alarm? Link to comment Share on other sites More sharing options...
sooby Posted August 25, 2011 Author Share Posted August 25, 2011 you had a cel with code p1518? Link to comment Share on other sites More sharing options...
AMZ Posted August 25, 2011 Share Posted August 25, 2011 After more digging, I found the problem to be that I had turned the ignition on while the MAS plug was disconnected. Cleared the alarm and she purrs like a kitten now. Link to comment Share on other sites More sharing options...
B-BGTLimited Posted August 25, 2011 Share Posted August 25, 2011 I would start with this if you haven't already. 2 CHECK HARNESS BETWEEN STARTER RELAY AND ECM. 1) Disconnect the connectors from starter relay and ECM. 2) Measure the resistance of harness between ECM and chassis ground. Connector & terminal (B135) No. 32 — Chassis ground: Is the resistance more than 1 MΩ? Repair the ground short circuit between starter motor and ECM. Repair the poor contact in ECM connector. Judging by that procedure it sounds like your bad connection issue could be at the starter itself. Link to comment Share on other sites More sharing options...
sooby Posted August 28, 2011 Author Share Posted August 28, 2011 sounds good thank you guys for your help Link to comment Share on other sites More sharing options...
