My Betty :) Pic heavy
Nightmaresmk
Update 7/17/15 FIxed my exhaust leak and got the tune adjusted. Added a few pieces to deal with the issues i was running into with the fmic.
http://imageshack.com/a/img909/5779/FfYgT0.jpg
Update 6/12/15 Tuned by TurboTekRay out of Quantum's Dyno In NY
335WHP/377Wtq
Teaser Update
http://imagizer.imageshack.us/v2/1280x1024q90/537/CE5uY9.jpg
Current setup Perrin 25mm FSB, AVO 0 Caster cab, Whitline front cab
Cusco 21mm RSB, AVO rsbb
04 KYB struts
05 Legacy GT brakes F+R DBA T3 Front rotor and Cyro's in the rear with Stoptech pads
Infamous performance oil line
Moroso Oil pan
Forge Bypass
Reinforced stock inter cooler
DW65
Grimmspeed Crankpully, Ceramic UpPipe, Turbo heat-shield, and gaskets.
Invidia Down pipe with magnaflow cat, egt and extra 02 bung welded in.
PTP lavablanket
Lava wrap on down and up.
SMFW with exedy replacement clutch
Center console gauge with Innovate wideband and boost gauges.
Led Dome and door lights. :)
BrenTuned stage 2. :)
Summer tires 255/50R17 on 17x8 et 35 Rota Torques
Winter tires 225/55R17 Continental Extreme winter contacts
http://imageshack.us/a/img833/7991/1vqe.png
http://imageshack.us/a/img547/5051/img20130502111645326.jpg
http://img577.imageshack.us/img577/9435/ws1s.jpg
http://imageshack.us/a/img836/4061/img20130506124358739.jpg
http://imageshack.us/a/img716/5460/img20130427131216318.jpg
http://imageshack.us/a/img716/2505/img20130427125221933.jpg
http://imageshack.us/a/img843/4606/img20130501161850066.jpg
I will add more from the summer later. No track pics.
Edited by Nightmaresmk
  • Replies 92
  • Created
  • Last Reply
Top Posters In This Topic
Engine pull from the summer.
http://imageshack.us/a/img89/2192/y2x3.jpg
http://imageshack.us/a/img62/1663/en7o.jpg
http://imageshack.us/a/img23/6449/8uh3.jpg
Toasted the clutch
http://imageshack.us/a/img22/1859/2ss6.jpg
New parts on waiting to go in. The Grimspeed Up i put on after i broke this one.
http://imageshack.us/a/img62/1323/ehdv.jpg
http://imageshack.us/a/img829/9692/9laq.jpg
This is why u get a TSK kit
http://imageshack.us/a/img41/7472/61pf.jpg
Gauges in
http://img22.imageshack.us/img22/442/cky5.jpg
http://imageshack.us/photo/my-images/22/cky5.jpg/
it reminds me of how the Volvo XC70's look. I like.
258k miles - Stock engine/minor suspension upgrades/original shocks/rear struts replaced at 222k/4 passenger side wheel bearings/3 clutches/1 radiator/3 turbos
  • 2 months later...
Update added perrin front endlinks and got rid of the stop tech brake pads. the Stoptech pads do not like call they dust bad and i managed to glaze them.
http://imageshack.com/a/img534/5118/pn37.jpg
http://imagizer.imageshack.us/v2/1280x1024q90/706/p4mg.jpghttp://imagizer.imageshack.us/v2/1280x1024q90/845/0gdd.jpg
  • 1 month later...
  • 1 month later...
Update
Perrin Transmission mount and pitch added
Torque rear end bushings
Grimmspeed MBC brace
Hawk HPS+ front pads
07 spec B 6spd and R180
http://imagizer.imageshack.us/v2/1280x1024q90/834/uxr6c.jpg
http://imagizer.imageshack.us/v2/1280x1024q90/850/lb8u.jpg
http://imagizer.imageshack.us/v2/1280x1024q90/822/ibx6.jpg
Right now i'm on 04 KYB's come tax time it's Blisteins with outback springs. :)
6spd is so nice. unfortunately I'm so use to the sound at 3500rpms with the 6 I'm hovering 90-95 mph. 82mph is 3krpms I need to get use to it quick.
Slightly higher ride height and they act like stiffer springs. I'm trying to lower my outback only 1" -1.25" without spending $2500 and improving contro and also leaving more clearance for my tire choice..
Might do a modified koni setup instead though i haven't fully decided yet.
  • 1 month later...
I spent around $3500 with the extras like Perrin mount rear bushings etc.
Tires are Hankook 255/50R17 they are all season sport truck tires. I love them. U need at least a 8" wide wheel and 35 offset to run them. Wet,dry are awesome. gravel idk as i never go off road. they are rated for snow but i have Continental extreme winters for snow and ice.
  • 2 weeks later...
  • 3 weeks later...
