quick4dr Posted December 13, 2011 Share Posted December 13, 2011 Anyone have instructions to remove the hood scoop I want to dip it. Link to comment Share on other sites More sharing options...
Max Capacity Posted December 13, 2011 Share Posted December 13, 2011 Open hood, lay big cushoin on top of engine, lay on your back and look up at the under side of the hood. You should be able to figure it out. Do you have the service manual ? 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
tbperry Posted December 13, 2011 Share Posted December 13, 2011 pop all the clips out that hold the liner on and take that off, then there are 4 screws that hold the scoop itself on, not the whole thing, just the scoop, take those off and you have one more pop-it to push up on the scoop and your good to go. i did it about a month ago, just going off memory... hopefully thats it, either way its super simple. Link to comment Share on other sites More sharing options...
Max Capacity Posted December 13, 2011 Share Posted December 13, 2011 You may want to swing by Harbor Fright and pick up the $5.00 plastic clip tool set. They come in handy when trying to remove the clips. http://www.harborfreight.com/5-piece-auto-trim-and-molding-tool-set-67021.html 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
quick4dr Posted December 13, 2011 Author Share Posted December 13, 2011 Got it thank you gentleman for the assistance. Scoop is officially plasti dipped. Link to comment Share on other sites More sharing options...
Moderators BarManBean Posted December 13, 2011 Moderators Share Posted December 13, 2011 no pics, didn't happen. OP is lying! "Bullet-proof" your OEM TMIC! <<Buy your kit here>> Not currently in stock Link to comment Share on other sites More sharing options...
xt2005bonbon Posted December 13, 2011 Share Posted December 13, 2011 no pics, didn't happen. OP is lying! Link to comment Share on other sites More sharing options...
quick4dr Posted December 14, 2011 Author Share Posted December 14, 2011 pics shortly, sorry for the delay. Link to comment Share on other sites More sharing options...
ssbtech Posted December 15, 2011 Share Posted December 15, 2011 Good idea. I should do mine too as the black finish has worn off the front edge of the plastic insert. Link to comment Share on other sites More sharing options...
quick4dr Posted December 15, 2011 Author Share Posted December 15, 2011 came out great. Link to comment Share on other sites More sharing options...
xt2005bonbon Posted December 16, 2011 Share Posted December 16, 2011 pictures of the whole car would be nice too. Link to comment Share on other sites More sharing options...
csbrown28 Posted December 16, 2011 Share Posted December 16, 2011 came out great. That desperately needs a hint of red somewhere. Just a little.... Link to comment Share on other sites More sharing options...
quick4dr Posted December 16, 2011 Author Share Posted December 16, 2011 My inspection sticker is red Link to comment Share on other sites More sharing options...
