natethomas2000 Posted June 14, 2005 Share Posted June 14, 2005 I would like to upgrade the wheels/tires on my XT. The stock wheels are 25 lbs and the tires are 26 lbs. I like the look of 18's, which would be 4lbs less than stock at each corner (21 lb rim and 26 lb tire). However, Going with 17's I could loose 11 lbs at each corner (17 lb rim and 23 lb tire). Would I be able to notice a difference in acceleration and braking? 18's would be 245/45/18 and 17's 225/55/17. Link to comment Share on other sites More sharing options...
praedet Posted June 14, 2005 Share Posted June 14, 2005 Only having what you gave me above to go by, I assumed a 7.5" width for both rims. I used the stock profile for both rims, a 3600 lb vehicle weight, and a 6.1s 0-60 stock. Your 0-60 would be 6.07s with the 18s (a roughly 20 lb reduction) whereas the 17s would pull a 5.99s. (70 lb reduction) The 17" rims would accelerate, brake, and handle better... Ted Link to comment Share on other sites More sharing options...
wukindada Posted June 14, 2005 Share Posted June 14, 2005 Every little bit adds up;) My new wheel/tire combo is about 5lbs lighter than stock @ each corner:) Toyota 6EATS .........SUCK!!!!!! Link to comment Share on other sites More sharing options...
praedet Posted June 14, 2005 Share Posted June 14, 2005 Every little bit adds up My new wheel/tire combo is about 5lbs lighter than stock @ each corner What size are the rims and tires, and what are their respective weights? Link to comment Share on other sites More sharing options...
wukindada Posted June 14, 2005 Share Posted June 14, 2005 21lb Wheel/25lb Tire Toyota 6EATS .........SUCK!!!!!! Link to comment Share on other sites More sharing options...
