jameshull Posted April 14, 2014 Share Posted April 14, 2014 hey guys, im kinda new to all this and planning to lower my 05 outback. i've got a set of legacy gt struts (wagon) and king low springs for the legacy wagon. after reading a few more threads i'm not sure if the low springs will be necessary, as they might give me more problems than i really want (rubbing, bottoming out, etc.). what are people's thoughts on this? i just really want to know how low is low enough, and how low is too low thanks! Link to comment Share on other sites More sharing options...
jameshull Posted April 14, 2014 Author Share Posted April 14, 2014 and will i have to cut/grind anything away inside the wheel wells? Link to comment Share on other sites More sharing options...
Rhitter Posted April 16, 2014 Share Posted April 16, 2014 How low do you want to go? All that is up to you. You will need to replace the rear bump stops with Legqcy ones though. Edit: read through this thread it will answer a lot of your questions http://legacygt.com/forums/showthread.php/lgt-wagon-suspension-swapped-into-outback-xt-140548.html My OBXT build Link to comment Share on other sites More sharing options...
Arsenic Posted June 8, 2014 Share Posted June 8, 2014 Just lowered my 06 OBXT with BC BR coilovers. I cut about an inch off of my outback bumpstops with a saws-all. Way cheaper than buying LGT bumpstops, which were about 100 bucks from Subaru. The only downside was the smell of burning rubber. Link to comment Share on other sites More sharing options...
Rester5350 Posted June 8, 2014 Share Posted June 8, 2014 I'm pretty sure it's not bump stops as much as it is the upper control arm. Lgt rear Uca Kca 399 Profit Link to comment Share on other sites More sharing options...
wobbegong Posted June 10, 2014 Share Posted June 10, 2014 Won't you have a Legacy then ?? Link to comment Share on other sites More sharing options...
kongzilla Posted July 2, 2014 Share Posted July 2, 2014 Most people forget that tire size plays a part when you want to be slammed. Having 55 series on a slammed outback is not ideal. Link to comment Share on other sites More sharing options...
