will620 Posted December 15, 2012 Share Posted December 15, 2012 So im selling my engine and tranny tomorrow on my totaled 05 LGT anybody got any tips on how to take them out? im trying to watch some vids on youtube but they aint much help. Link to comment Share on other sites More sharing options...
Aracheon Posted December 15, 2012 Share Posted December 15, 2012 Do you have the service manual? Link to comment Share on other sites More sharing options...
Sumbaru Posted December 15, 2012 Share Posted December 15, 2012 Get M8 Allen wrench to take out the cap on clutch fork, followed by inserting a 10mm bolt into the pivot pin and dislodge the clutch fork's pivot pin. You can't be able to separate the union of engine and transmission without it being taken out. Other than that drain the fluids to help yourself out pulling it out. It is possible to slide whole thing out of the engine bay. Dismount the transmission mount and motor monts and you will have to pull it out as one piece at an angle. Link to comment Share on other sites More sharing options...
EJ25subie05 Posted December 15, 2012 Share Posted December 15, 2012 take the radiator and condenser out first. unplug the main wire harness and the sensor plugs etc. unhook the power steering lines, ac lines, fuel lines, take off the tmic, take out your air box, disconnect your battery and all them little lines around there. there are a few other hoses and wires you'll have to disconnect after taking the tmic off. take your starter out, and then take out the two nuts and 7 bolts (i believe thats what it is, can't remember) holding your transmission and your motor together. take the 14mm nuts with washers out on your motor mounts (two of them). then get your engine and transmission separated and pull it out. for transmission your going to have to take out your axles, take your dp off and either drop or take off your catback completely off. take your drive shaft off unhook the plugs, and rest is self explanatory. sorry for the run on sentences and if its not in order. its getting late. Link to comment Share on other sites More sharing options...
EJ25subie05 Posted December 15, 2012 Share Posted December 15, 2012 or as stated above maybe pull it out in one piece??? i never done it like that and never will. Link to comment Share on other sites More sharing options...
FJuan Posted December 15, 2012 Share Posted December 15, 2012 Pull the tranny off first. Take out the radiator & hoses. Start pulling the wiring harnesses off the motor. Remove the turbo and exhaust pipes. Remove the intake manifold & fuel rail. Then pull the motor after you disconnect the engine mounts and grounding cables. My wife's balls are delicious. Link to comment Share on other sites More sharing options...
urfsin Posted December 15, 2012 Share Posted December 15, 2012 Get M8 Allen wrench to take out the cap on clutch fork, followed by inserting a 10mm bolt into the pivot pin and dislodge the clutch fork's pivot pin. You can't be able to separate the union of engine and transmission without it being taken out. Other than that drain the fluids to help yourself out pulling it out. It is possible to slide whole thing out of the engine bay. Dismount the transmission mount and motor monts and you will have to pull it out as one piece at an angle. I thought this was only for 2007 and older WRX's (and maybe STI's), but not on the 2005 and newer LGT and 2008 and newer WRX's. Can someone confirm this? Slide It Sideways Link to comment Share on other sites More sharing options...
Max Capacity Posted December 15, 2012 Share Posted December 15, 2012 Get M8 Allen wrench to take out the cap on clutch fork, followed by inserting a 10mm bolt into the pivot pin and dislodge the clutch fork's pivot pin. You can't be able to separate the union of engine and transmission without it being taken out. Other than that drain the fluids to help yourself out pulling it out. It is possible to slide whole thing out of the engine bay. Dismount the transmission mount and motor monts and you will have to pull it out as one piece at an angle. I thought this was only for 2007 and older WRX's (and maybe STI's), but not on the 2005 and newer LGT and 2008 and newer WRX's. Can someone confirm this? I pulled the tranny last year and the engine this year in the wagon and don't remember doing what he said. OP. this is a easy job if you have the proper tools. I think you could pull them as a unit if you can get the car high enough. Pull fuel pump fuse, start engine until it stalls. Drain fluids pull radiator disconnect fuel lines from the shock tower " electrical connectors. I'm not going to list everything, I don't have time for that... You'll need decent mechanical skills, ability to think through a problem, if you come up against a problem, step back take a deep breath have a bite to eat, get a drink. Look it over, you'll figure it out. BTW you can lay the PS and AC to the sides with pulling the lines. Here's my thread, it may help. http://legacygt.com/forums/showthread.php/got-some-new-stuff-engine-r-r-184106.html 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
will620 Posted December 15, 2012 Author Share Posted December 15, 2012 thanks alot imma try to see what i can do but the radiator and battery and some things in the front of the car were ripped off during the accident maybe it will make it easier? or a bitch.. ill see wat happens Link to comment Share on other sites More sharing options...
Max Capacity Posted December 15, 2012 Share Posted December 15, 2012 In theory, if you pull it as a unit, the axles should slide out as you pull the stuff forward after you remove the shifter and tranny mounts. Do you have someone that wants them ? this is a lot of work. Do you have a engine hoist ? 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
