CharlesC Posted July 1, 2012 Share Posted July 1, 2012 When I turn off the car I hear a weird clicking or almost bubbling sound behind the dash. I have no clue what it could be. Anyone have any ideas? I will post up a video later on today. Link to comment Share on other sites More sharing options...
Max Capacity Posted July 1, 2012 Share Posted July 1, 2012 bubbling is air in the coolant system, burp the system. Jack up the right front corner of the car, open the cap on the turbo coolant tank. Squeeze the coolant hoses. Top off the system. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
m sprank Posted July 1, 2012 Share Posted July 1, 2012 Or it is the HVAC system moving the dampers. Link to comment Share on other sites More sharing options...
Leviman Posted July 1, 2012 Share Posted July 1, 2012 Or it's a stuck window switch making the circuit breaker click on and off. But that's definitely more click, not bubling. Link to comment Share on other sites More sharing options...
rapture Posted July 1, 2012 Share Posted July 1, 2012 uh i have noticed the same damn noise.... i thought i was going crazy and its only happening after i shut off the car..for maybe 15 seconds..sounds like a bunch of random clicks and stuff right? Link to comment Share on other sites More sharing options...
kosugesan Posted September 19, 2012 Share Posted September 19, 2012 is it coming from the driver side? i get this random bubbly sound sometimes when i'm accelerating or when i close the door when the car is completely off... Link to comment Share on other sites More sharing options...
m sprank Posted September 20, 2012 Share Posted September 20, 2012 How would fuel pressure try to build before inserting the key? That would be amazing and scary at the same time. OP said the sound was after shutting the car down. Air in the cooling system should eventually get caught in the heater core and cause an overheat or rising t-stat condition as well. Which might just cause a "bubbling" behind the dash sound when shutting down. Op never got back to the thread, so we do not know if he found his problem. Link to comment Share on other sites More sharing options...
gear_monkey Posted September 20, 2012 Share Posted September 20, 2012 This is the common sound of the a/c servo that moves your directional venting doors. Mine does it as well..sounds like a small electric motor mixed with blower doors flopping around. There is an extensive thread here about it. Someone has even isolated the part that is causing it and also uploaded a diagram. Link to comment Share on other sites More sharing options...
rallispec Posted September 20, 2012 Share Posted September 20, 2012 This is the common sound of the a/c servo that moves your directional venting doors. Mine does it as well..sounds like a small electric motor mixed with blower doors flopping around. There is an extensive thread here about it. Someone has even isolated the part that is causing it and also uploaded a diagram. agreed, common,and annoying problem. mine only started doing this in the past year, doesn't seem to be s major cause of concern yet, just annoying (like the sticky window switch) Link to comment Share on other sites More sharing options...
m sprank Posted September 20, 2012 Share Posted September 20, 2012 Or it is the HVAC system moving the dampers. My first post in the thread. Lol. Link to comment Share on other sites More sharing options...
RMOBXT Posted July 25, 2013 Share Posted July 25, 2013 Hello- I've been hearing this random click noise under my dash for a while now. It happens on when the car is on, and its totally random, sometimes more frequent, other less nothing at all. It most usuall happens for a few seconds right when I turn the car on, and then quits, but sometimes it just keeps going for the whole drive. My commute is 40 min and it gets so annoying. I swear I can feel it if my knee is resting on the center console area. I've looked around for info or DIYs on the a/c servo for the vent door, but I can't seem to find anything. Can anybody point me in the right direction? Thanks! Link to comment Share on other sites More sharing options...
m sprank Posted July 25, 2013 Share Posted July 25, 2013 search vacation pix. Link to comment Share on other sites More sharing options...
Max Capacity Posted July 25, 2013 Share Posted July 25, 2013 In the "general Chat" forum there is a link to vacation pic's. or here, http://people.csail.mit.edu/ilh/vacation/ 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
rob-2 Posted July 25, 2013 Share Posted July 25, 2013 Since it's been really hot I think I hear the A/C unit warming up or cooling down, after the car is off. Sounds like bubbles every now and again. Link to comment Share on other sites More sharing options...
sodium303 Posted July 25, 2013 Share Posted July 25, 2013 I have this problem too, it could be the temp or fan actuator getting stuck making that noise. At least its what it sounds like. Link to comment Share on other sites More sharing options...
RMOBXT Posted July 26, 2013 Share Posted July 26, 2013 I think this could be the fix for me. Here's a link for the part. I'll post back when I have a chance to work on it. Link to comment Share on other sites More sharing options...
WaspGT Posted July 28, 2013 Share Posted July 28, 2013 Every LGT ive been in, does it. Its a raspy gurgling sound. Same sound my GF made last night. Link to comment Share on other sites More sharing options...
Acil Posted July 16, 2014 Share Posted July 16, 2014 How would fuel pressure try to build before inserting the key? That would be amazing and scary at the same time. OP said the sound was after shutting the car down. Air in the cooling system should eventually get caught in the heater core and cause an overheat or rising t-stat condition as well. Which might just cause a "bubbling" behind the dash sound when shutting down. Op never got back to the thread, so we do not know if he found his problem. I've been poking around on here today looking into common overheating issues, as my 06 Spec B started overheating today for the first time in its life. I've definitely had this ticking noise coming from the engine area after shutting down the motor for a while... Is burping the system as stated above the generally accepted solution to this issue? SELECT * FROM users WHERE clue > 0; 0 rows returned Link to comment Share on other sites More sharing options...
m sprank Posted July 16, 2014 Share Posted July 16, 2014 There should only be air in the system if you put it there. It is a closed loop. If there is air and you did not introduce it then there is leak and the air is what remains in the absense of coolant. Otherwise you could simply hear the coolant vaporizing from the turbo and rising into the coolant res during shutdown. This is normal and is how the turbo cools after the car has been shut down (see why Subarus dont need turbo timers). Link to comment Share on other sites More sharing options...
zisforzachary Posted September 29, 2014 Share Posted September 29, 2014 any word? I think this could be the fix for me. Here's a link for the part. I'll post back when I have a chance to work on it. Link to comment Share on other sites More sharing options...
