Skiman Posted August 15, 2014 Share Posted August 15, 2014 Has anyone had an issue with the car not locking with the fob, but still unlocking with it? Just wondering if the lock buttons just wear out. I've checked all fuses and simply don't want to buy another fob. Link to comment Share on other sites More sharing options...
JmP6889928 Posted August 15, 2014 Share Posted August 15, 2014 I believe that MrTris is having that same problem right now. You might ask him if he's solved the issue. Link to comment Share on other sites More sharing options...
zactek Posted August 15, 2014 Share Posted August 15, 2014 Has anyone had an issue with the car not locking with the fob, but still unlocking with it? Just wondering if the lock buttons just wear out. I've checked all fuses and simply don't want to buy another fob. Yea, I was having the same problem, unlocking but not locking...Took the fob apart, the 4 contact points on the bottom of the "lock" button have all broken off. Those solder points are WAYY too small to solder yourself, I believe a machine makes up/solders the chip and all the buttons connected to it. Unless you have an ultra small soldering iron, a magnifying glass and a crazy-steady hand, I wouldn't bother. I broke down and bought the 3-in-1 key... Zack K. Link to comment Share on other sites More sharing options...
MrTris Posted August 15, 2014 Share Posted August 15, 2014 Has anyone had an issue with the car not locking with the fob, but still unlocking with it? Just wondering if the lock buttons just wear out. I've checked all fuses and simply don't want to buy another fob. I'm gonna have it hooked up to an SSM this weekend, I'll report if there's a fix. Although our symptoms are the same, we might not have the same problem. Yea, I was having the same problem, unlocking but not locking...Took the fob apart, the 4 contact points on the bottom of the "lock" button have all broken off. Those solder points are WAYY too small to solder yourself, I believe a machine makes up/solders the chip and all the buttons connected to it. Unless you have an ultra small soldering iron, a magnifying glass and a crazy-steady hand, I wouldn't bother. I broke down and bought the 3-in-1 key... Zack K. It's like $70 on Amazon, I should probably order a new one, just 'cause, but, with all the other bullshit it's nickel-and-diming me with, the fob has dropped down on the list. . Link to comment Share on other sites More sharing options...
