KyLegacy 2.5GT Posted July 5, 2010 Share Posted July 5, 2010 Has anybody else had problems with EcuFlash not working with Windows 7? I was able to get RomRaider to work properly, but EcuFlash just won't cooperate!!! Attached is a screenshot of what EcuFlash is telling me when I try to read or do anythings from the ECU... As you can see the program is recognizing the cable (all of the icons are in color). The green connectors are connected under the passenger side dash.. I have the baud rate tuned down on the COM PORT to 4800.. I have the drivers installed for the cable.. When I click 'Read from ECU', the box the choose the car type pops up. I click the 2005-2006 LGT/Baja model and I get the error 'Unable to connect to vehicle interface'!!! (see attachment again) WTF? Does anybody have any ideas? This all worked fine with Windows XP! Link to comment Share on other sites More sharing options...
Ridgeracer Posted July 5, 2010 Share Posted July 5, 2010 In for some help too. I just ordered a netbook with Win7 starter. Do you use a tactrix cable? "Gimme mines Balboa...Gimme mines".....Clubber Lang - Mr. T Link to comment Share on other sites More sharing options...
keithk831 Posted July 5, 2010 Share Posted July 5, 2010 Where it's identifying the cable on the bottom...does it look the same as before? Link to comment Share on other sites More sharing options...
KyLegacy 2.5GT Posted July 5, 2010 Author Share Posted July 5, 2010 I am using the VAG-COM cable... I never had problems with it on XP. I can log and read all of my parameters in RomRaider so I know the drivers are working. I can't remember how the screen looked before when it was identifying the cable. I even tried downloading the new beta version on EcuFlash and I still get the same problems. I worked on this for about 5 hours today and had no luck. I read online to install the 32bit Java and all sorts of different drivers, nothing worked. Link to comment Share on other sites More sharing options...
KyLegacy 2.5GT Posted July 6, 2010 Author Share Posted July 6, 2010 I had a check engine light and I wanted to reflash my tune with the code depressed. As I was working in RomRaider earlier I was able to reset the ECU with the VAG-COM cable. That, plus being able to log, tells me that the cable is working and so is RomRaider. Why not EcuFlash? Is there any other program that can be used to flash the ECU other than EcuFlash??? Link to comment Share on other sites More sharing options...
LGT Dave Posted July 6, 2010 Share Posted July 6, 2010 Have you tried running the program as an administrator? (Right-click icon > Run as Administrator) How about in WinXP Compatibility Mode? (Right-click icon > Properties > Compatibility Tab > Check Compatibility box and make sure Windows XP is selected in the drop-down menu) Note: I have Vista, not Win7, so I'm assuming those same options are still there. Those are some things that I've had to do to make some programs work after moving from WinXP. Link to comment Share on other sites More sharing options...
KyLegacy 2.5GT Posted July 6, 2010 Author Share Posted July 6, 2010 Yes, I did try running the program as an administrator and didn't have any luck. I even tried downloading the file outside of the "Programs" directory so I didn't have to be an admin to make any changes to the system. I just went to the properties tab and switched it to XP compatibility mode, I will try and run the program again tomorrow after work. Are there any other ideas to try as well? Link to comment Share on other sites More sharing options...
keithk831 Posted July 6, 2010 Share Posted July 6, 2010 I run all the logging/flashing programs on my laptop just fine, and i'm running Win7. But i'm also using an OP2 cable, which seems to connect better with hardware and software. Link to comment Share on other sites More sharing options...
KyLegacy 2.5GT Posted July 6, 2010 Author Share Posted July 6, 2010 I talked to some people at work today and they think it may be from having the 64bit operating system. Keith, which Windows 7 are you running? I am running the 64bit Professional. Is anybody else using Windows 64bit? Link to comment Share on other sites More sharing options...
keithk831 Posted July 6, 2010 Share Posted July 6, 2010 I talked to some people at work today and they think it may be from having the 64bit operating system. Keith, which Windows 7 are you running? I am running the 64bit Professional. Is anybody else using Windows 64bit? Win7 Home Premium, 64-bit. I actually tried using a VAG-COM cable, and never could get it to work. Ended up buying Tactrix. But I also tried that cable on an XP laptop and it still didn't work. Link to comment Share on other sites More sharing options...
I Wish Posted July 6, 2010 Share Posted July 6, 2010 What version of Ecuflash are you using? Link to comment Share on other sites More sharing options...
KyLegacy 2.5GT Posted July 7, 2010 Author Share Posted July 7, 2010 I tried both the 1.42 and 1.43 (beta) versions of EcuFlash. I just tried running the program in XP compatibility mode and still no luck! Link to comment Share on other sites More sharing options...
Ridgeracer Posted July 9, 2010 Share Posted July 9, 2010 Any luck fixing this problem?? You have me even more stumped. I just installed Romraider and EcuFlash on my Netbook running Win7 starter and everything seems to work fine. The only difference is the fact that I have a Tactrix Cable. I ran all the lastest drivers for the cable, the lastest version of RR and Learn Viewer. Do you have anyone in your area with the Tactrix cable you could use to test out to see if it works? "Gimme mines Balboa...Gimme mines".....Clubber Lang - Mr. T Link to comment Share on other sites More sharing options...
keithk831 Posted July 9, 2010 Share Posted July 9, 2010 Any luck fixing this problem?? You have me even more stumped. I just installed Romraider and EcuFlash on my Netbook running Win7 starter and everything seems to work fine. The only difference is the fact that I have a Tactrix Cable. I ran all the lastest drivers for the cable, the lastest version of RR and Learn Viewer. Do you have anyone in your area with the Tactrix cable you could use to test out to see if it works? You can never go wrong with Tactrix! Link to comment Share on other sites More sharing options...
KyLegacy 2.5GT Posted July 14, 2010 Author Share Posted July 14, 2010 I tried taking an older XP laptop and installed EcuFlash along with the proper drivers for the VAG/COM cable and it still didn't work! I am wondering if EcuFlash will only work with the Tactrix cable now???? The issue that I still don't understand is that I can use RomRaider with absolutely no problems at all! I really don't want to buy a $160 cable to reflash an existing program with a disabled check engine code. Are there any other programs to try? Link to comment Share on other sites More sharing options...
prb2 Posted January 7, 2011 Share Posted January 7, 2011 Any luck fixing this? I am having the same issue with Windows 7 on a netbook. I am also trying to use the VAG-COM cable. Link to comment Share on other sites More sharing options...
rock2534 Posted January 7, 2011 Share Posted January 7, 2011 Ecuflash gives me an issue every once in a while, what I found fixes it(for me), is just overwriting the definition xml file, clears it right up. Link to comment Share on other sites More sharing options...
almostinvincible119 Posted January 7, 2011 Share Posted January 7, 2011 Rock, how do you do that. When I purchased my cable from Infamous1, they sent a CD with all the ECU Defs on it. Where do I overwrite that at? I'm having the EXACT same problem as the OP but I'm running XP. Link to comment Share on other sites More sharing options...
rock2534 Posted January 8, 2011 Share Posted January 8, 2011 I was just referring to the ecu_defs.xml file, and the ecuflash definition subaru file. You just copy the subaru folder contents to the location where ecuflash is installed under "program files". The ecu_defs file is for romraider. THat is nice and convenient they sent that cd along. It took me a few times to get it working, I uninstalled/reinstalled ecuflash a few times before I got it going. Link to comment Share on other sites More sharing options...
almostinvincible119 Posted January 8, 2011 Share Posted January 8, 2011 Well I've uninstalled about 15 times. Seriously Link to comment Share on other sites More sharing options...
rock2534 Posted January 8, 2011 Share Posted January 8, 2011 When you uninstall, make sure you scroll down and uninstall anything that says tactrix, there are uusally some drivers down there somewhere. Once you do that and reinstall, just make sure you recopy the xml files into the directory where ecuflash is installed. It took me 2-3 days to get mine working, but I do notice that you are using that vag cable, I have a tactrix, so I can't really speak to that particular cable. Link to comment Share on other sites More sharing options...
almostinvincible119 Posted January 8, 2011 Share Posted January 8, 2011 I do uninstall the drivers for the cable, and it is a Tactrix driver that I'm using. I'm not sure what type cable they sold me, but they said it would work. It works for data logging, but not for flashing so far. I've order an eBay VagCom cable for 10 bucks to see what happens. Link to comment Share on other sites More sharing options...
rock2534 Posted January 8, 2011 Share Posted January 8, 2011 Sounds like a software issue with ecuflash then, if the cable works for datalogging with romraider, you know it works, so that is good. My initial issues were due to there not being a valid definition for my vehicle. Link to comment Share on other sites More sharing options...
almostinvincible119 Posted January 8, 2011 Share Posted January 8, 2011 I've uploaded the new Defs, and I do everytime I load ECUFlash back on the computer. Im lost man...I wish there was a way to test if the flashing thing worked or not before wasting 150 bucks on a tune. Link to comment Share on other sites More sharing options...
prb2 Posted January 14, 2011 Share Posted January 14, 2011 I fixed my issue with a new cable from Tactrix in this case after trying everything else. I may have been able to get it to work but was in a big time crunch. The Tactrix just worked right from the start. Link to comment Share on other sites More sharing options...
