Crinaldi23 Posted March 6, 2010 Share Posted March 6, 2010 I just dropped my car and i got basically an inch and a half drop all around. I am picking out new summer wheels and i dont know if i should choose a 35mm offset or a 48mm offset. Would i have to roll my fenders if i am planning on running an 18" rim with 215/40/18 tires?? please help!! Link to comment Share on other sites More sharing options...
Xenonk Posted March 6, 2010 Share Posted March 6, 2010 offsets means nothing if you dont compare the rim width.. a 7" wide wheel with a +48mm offset is totally different than a 8" wide wheel with a +48mm offset. Check your widths first, then go read my FAQ/Sticky on the top of this wheel/tire forum. It will tell you all the ranges you need to look for offsets and what fits our car. Also if done right, you can run something like a 225/40/18 or even as wide as a 245/35/18 (which about the same sidewall height, but almost 1" wider tire) and you can put that on a 18x8.5 +45mm offset just fine. How did you lower your car? With coilovers or just replaced the springs and used an OEM style shock to go with the springs? Keefe Link to comment Share on other sites More sharing options...
Crinaldi23 Posted March 6, 2010 Author Share Posted March 6, 2010 I have lowering springs and new struts so i wouldnt be able to adjust it..and my new rims are going to be 8" wide..so do you suggest 35 or 48??...and i already have my tires 215/40/18 that came off of my old rims!! Link to comment Share on other sites More sharing options...
Scooby Fan Posted March 7, 2010 Share Posted March 7, 2010 http://www.rimsntires.com/rt_specs.jsp Link to comment Share on other sites More sharing options...
