beebs Posted March 17, 2013 Share Posted March 17, 2013 Owner said that there was a tiny hole on top of fuel tank, which is why i dont fill my gas up all the way. A family member of mine gave me fuel tank sealant from napa, i dont know if i should it though. I do want to buy a new fuel tank but i've been searching the web for it and i cant one. I dont know if i am typing something wrong, any help? 98 subaru legacy gt 2.5 thanks every body Link to comment Share on other sites More sharing options...
Hemingway Posted March 17, 2013 Share Posted March 17, 2013 Try car-part.com ... a quick search showed a fair number. Good luck! Link to comment Share on other sites More sharing options...
snederhiser Posted March 17, 2013 Share Posted March 17, 2013 Hello; You are correct, get a replacement tank. A junk yard in your area should have one. Steven. Link to comment Share on other sites More sharing options...
jp71ss Posted March 18, 2013 Share Posted March 18, 2013 Where are you located? Link to comment Share on other sites More sharing options...
travgag Posted March 18, 2013 Share Posted March 18, 2013 Depending where it's leaking but I would try sealing the hole, to drop the tank it's a big job, drop the exhaust the drive line and the rear sub frame I believe, I used seal all, it's a yellow tube, sealed the leak that's was on seam of the two halves Link to comment Share on other sites More sharing options...
beebs Posted March 20, 2013 Author Share Posted March 20, 2013 Depending where it's leaking but I would try sealing the hole, to drop the tank it's a big job, drop the exhaust the drive line and the rear sub frame I believe, I used seal all, it's a yellow tube, sealed the leak that's was on seam of the two halves so sealing it would also be good, its at the top of the fuel tank Link to comment Share on other sites More sharing options...
travgag Posted March 20, 2013 Share Posted March 20, 2013 Yea I would give it a shot, make sure you clean it up very good before applying the glue, I did a few coats, and even to get to the spot that was leaking I cut away the floor between the two access doors under the seat and siliconed it back together after lol Link to comment Share on other sites More sharing options...
beebs Posted April 3, 2013 Author Share Posted April 3, 2013 Try car-part.com ... a quick search showed a fair number. Good luck! Hello; You are correct, get a replacement tank. A junk yard in your area should have one. Steven. Depending where it's leaking but I would try sealing the hole, to drop the tank it's a big job, drop the exhaust the drive line and the rear sub frame I believe, I used seal all, it's a yellow tube, sealed the leak that's was on seam of the two halves Yea I would give it a shot, make sure you clean it up very good before applying the glue, I did a few coats, and even to get to the spot that was leaking I cut away the floor between the two access doors under the seat and siliconed it back together after lol Today I found out that my fuel pump and tank are completely screwed, so I need to buy a new one. My friend has an extra tank and pump from his 07 wrx, would that fit? Link to comment Share on other sites More sharing options...
Kiyo1990 Posted April 3, 2013 Share Posted April 3, 2013 Well man that blows. I don't know about the WRX tank, but it may. You cross reference numbers yet? Link to comment Share on other sites More sharing options...
beebs Posted April 4, 2013 Author Share Posted April 4, 2013 Well man that blows. I don't know about the WRX tank, but it may. You cross reference numbers yet? what do i need to do? Link to comment Share on other sites More sharing options...
