NSFW Posted December 1, 2006 Share Posted December 1, 2006 What's included in this service? What should I expect to pay? Should I got to the dealership? Should I go to an independent shop? Opinions welcome. Link to comment Share on other sites More sharing options...
rjundi Posted December 1, 2006 Share Posted December 1, 2006 What should be included is clearly stated in your manual. If you don't own it look on my.subaru.com and its all in there in a PDF. Don't get talked into more service. Dealership or independant is what you prefer and want to pay. I would get a price quote for required services (in manual) from both and go from there, it varies. Link to comment Share on other sites More sharing options...
ilh Posted December 1, 2006 Share Posted December 1, 2006 According to the factory service manual: replace: oil and oil filter inspect: clutch, brake lines, brakes pads and rotors, parking break, suspension, axle boots and joints, rotate tires, power steering Thus, it is basically an oil change, tire rotation, and general inspection. I did it myself. What are dealers charging for this? I can't see how that could cost more than $80-$100. Link to comment Share on other sites More sharing options...
iMouseGT Posted December 1, 2006 Share Posted December 1, 2006 I was just at mine for an oil change. I think I read something like $270 for 15000 service. Save yourself a ton of money and do the rotation yourself. Link to comment Share on other sites More sharing options...
planigan Posted December 1, 2006 Share Posted December 1, 2006 I just stopped by a local dealership to pick up some oil filters. My 15,000 is coming up at the next service interval so I checked on the price... 299.99 That was the price listed on their little maintenance board. Not sure if it included any "extras". I'm in PA by the way, and this was at Cochran out in Monroeville. Link to comment Share on other sites More sharing options...
smoss Posted December 1, 2006 Share Posted December 1, 2006 My dealer asked me if I wanted to do the 15k serivce. I said no, I just had them change the oil. He did say that I should at least change the air filter. It seem early to me to change the air filter at 15k. Anyone have the dealer change the air filter as part of thsi serivice? No, I haven't looked in the manual as of yet........ Link to comment Share on other sites More sharing options...
Opie Posted December 1, 2006 Share Posted December 1, 2006 Our 15k runs $225.00 and includes all the recomended services on Subaru's severe duty service schedule: Oil & Filter Change Tire Rotation Replace Brake Fluid Replace Transmission Fluid Replace Front & Rear Differential Fluid Clean & Adjust Parking Brake Scan On-Board Computer Inspect tires, hoses, belts, battery, steering, suspension, brake linings & components, fuel system & lines, axle shafts & boots, wipers, lights, horn, door locks & air filter. Link to comment Share on other sites More sharing options...
VTGT Posted December 1, 2006 Share Posted December 1, 2006 Our 15k runs $225.00 and includes all the recomended services on Subaru's severe duty service schedule: Oil & Filter Change Tire Rotation Replace Brake Fluid Replace Transmission Fluid Replace Front & Rear Differential Fluid Clean & Adjust Parking Brake Scan On-Board Computer Inspect tires, hoses, belts, battery, steering, suspension, brake linings & components, fuel system & lines, axle shafts & boots, wipers, lights, horn, door locks & air filter. Why do they scan the on-board computer? Link to comment Share on other sites More sharing options...
GeeTee Posted December 1, 2006 Share Posted December 1, 2006 You may want to just "visually" check the air filter...very easy to do. I checked mine at 15K- 11/06, and it had a ton of leaves on the surface, and it was very dirty. I did the oil change and air filter replacement myself, plus the tranny fluid and rear dif with redline. Link to comment Share on other sites More sharing options...
smoss Posted December 1, 2006 Share Posted December 1, 2006 You may want to just "visually" check the air filter...very easy to do. I checked mine at 15K- 11/06, and it had a ton of leaves on the surface, and it was very dirty. I did the oil change and air filter replacement myself, plus the tranny fluid and rear dif with redline. That's what I was thinking... It's not rocket science... Link to comment Share on other sites More sharing options...
whitetiger Posted December 1, 2006 Share Posted December 1, 2006 change your oil and air filter. Done. Link to comment Share on other sites More sharing options...
dplacen Posted December 3, 2006 Share Posted December 3, 2006 Our 15k runs $225.00 and includes all the recomended services on Subaru's severe duty service schedule: Oil & Filter Change Tire Rotation Replace Brake Fluid Replace Transmission Fluid Replace Front & Rear Differential Fluid Clean & Adjust Parking Brake Scan On-Board Computer Inspect tires, hoses, belts, battery, steering, suspension, brake linings & components, fuel system & lines, axle shafts & boots, wipers, lights, horn, door locks & air filter. Thats not a 15k thats more like a 30k dude. I would just change the oil and rotate the tires. At that milelage the air filter and pcv valve is still chean. !5k at my job is oil change, rotate, adjust rear brakes and inspect and inspect everything. Link to comment Share on other sites More sharing options...
tantal Posted December 3, 2006 Share Posted December 3, 2006 Thats not a 15k thatsmore like a 30k dude. I would just change the oil and rotate the tires. At that milelage the air filter and pcv valve is still chean. !5k at my job is oil change, rotate, adjust rear brakes and inspect and inspect everything. At 12 k mi, my air filter was in terrible condition - I cleared it by tapping out the dirt and got it replaced as soon as I could - but I was driving the car in a dusty climate. Link to comment Share on other sites More sharing options...
Guest Posted December 3, 2006 Share Posted December 3, 2006 +1 My filter was shot at 12k Lotsa bugs and crap in it Link to comment Share on other sites More sharing options...
kenchan Posted December 3, 2006 Share Posted December 3, 2006 those 15k service is a rip-off imho. Link to comment Share on other sites More sharing options...
gianspi Posted December 3, 2006 Share Posted December 3, 2006 +1 ^ enough zip ties and duct tape will fix anything. Link to comment Share on other sites More sharing options...
TCL28 Posted December 3, 2006 Share Posted December 3, 2006 Our 15k runs $225.00 and includes all the recomended services on Subaru's severe duty service schedule: Oil & Filter Change Tire Rotation Replace Brake Fluid Replace Transmission Fluid Replace Front & Rear Differential Fluid Clean & Adjust Parking Brake Scan On-Board Computer Inspect tires, hoses, belts, battery, steering, suspension, brake linings & components, fuel system & lines, axle shafts & boots, wipers, lights, horn, door locks & air filter. Replace the brake, transmission, and differential fluid? What? Link to comment Share on other sites More sharing options...
gianspi Posted December 3, 2006 Share Posted December 3, 2006 Yea I think that is the 30k service. Here is the 15k service straigt from mysubaru.com: MAINTENANCE DETAILS Vehicle: 2005 LEGACY 2.5 GT SEDAN Interval: 15000miles / 15 month service Action Description Replace: Engine oil Replace: Engine oil filter Inspect: Disc brake pads and discs, front and rear axle boots and axle shaft joint portions Perform: Inspect brake lines and check operation of parking and service brake system Inspect: Clutch operation Inspect: Steering and suspension Perform: Rotate and Inspect Tires enough zip ties and duct tape will fix anything. Link to comment Share on other sites More sharing options...
smoss Posted December 3, 2006 Share Posted December 3, 2006 Just took out my air filter. Not as easy as I would have thought, but I got it. Anyway, it had dirt in it of course, some leaves, but it was still white and looked ok. Anyway, I now have 21k on my car at this point. I think I'll wait to the 30k for the air filter. I tapped out all the debris I could. It's time to put on the snow tires so the tire rotation isn't an issue. Thanks for the responses guys. Link to comment Share on other sites More sharing options...
kenchan Posted December 3, 2006 Share Posted December 3, 2006 i have an extra legacy air filter but i dont plan on changing it until 30k per manuf. interval. mine was pretty clean as well at 12k. Link to comment Share on other sites More sharing options...
itsme Posted December 3, 2006 Share Posted December 3, 2006 at Renick the do: all the inspection oil + filter rotate tires 4 wheel alignment for $234 Racer X FMIC for '05-'09 LGTs, '08+ WRX and '10+ LGT,'14+ FXT, and '15+ WRX TMIC Racerxengineering.com Link to comment Share on other sites More sharing options...
VTGT Posted December 3, 2006 Share Posted December 3, 2006 change your oil and air filter. Done. Coming from a former subaru tech, i'll take the advice and keep my money Link to comment Share on other sites More sharing options...
tantal Posted December 4, 2006 Share Posted December 4, 2006 I asked my service writer about an alignment at the 15k service, and he looked at me like I was green. "Are you having a problem, tire wear or pulling, something like that?" "No," I said. "Then why do you want an alignment?" So I felt stupid but good because he could have had my money right there but doesnt think you need an alignment unless you're having problems. Good to go. Link to comment Share on other sites More sharing options...
TCL28 Posted December 4, 2006 Share Posted December 4, 2006 Hmm, there's some food for thought. Link to comment Share on other sites More sharing options...
itsme Posted December 4, 2006 Share Posted December 4, 2006 Well I'm going to do it. I'm have Superpro LCR fulcrum bushings on the way so I will need alignment anyway. Racer X FMIC for '05-'09 LGTs, '08+ WRX and '10+ LGT,'14+ FXT, and '15+ WRX TMIC Racerxengineering.com Link to comment Share on other sites More sharing options...
