I Love Losing All My Presets Every Single Time I Turn My Car On
scoogan
If it is under 40 degrees, my radio will automatically shut off/reset itself when I crank the engine over. If the key was let in the accessory position and not cranked, the radio works fine.
I have been putting up with it everyday for the last three weeks but it's getting the best of me :spin:
battery may be on its way out.
+1, your battery is dead/dying
The colder it is, the more CCA (Cold Cranking Amps) the battery has to provide. If it has to use every last drop to get the car started, it uses those for the starter and not for keeping the radio presets, ecu, etc.
So, new battery is in order.
If I pass you on the right, I'm flipping you off.
