ruggerheist Posted May 29, 2011 Share Posted May 29, 2011 We are just finishing a turbo timer install, a wire on the harness had a slight nick in it, touched metal and the car died. no instrumentation illumination, no ignition, cant even put windows up. no fuses are blown and the manual doesnt indicate what relay does what, making our trouble shooting next to impossible. anyone have any advice? as of now were stuck... Link to comment Share on other sites More sharing options...
rao Posted May 29, 2011 Share Posted May 29, 2011 There is a main fuse in the fuse box under the hood. Rob IF YOU CARE ABOUT YOUR CAR YOU SHOULD NEVER DRIVE IT Link to comment Share on other sites More sharing options...
mwiener2 Posted May 29, 2011 Share Posted May 29, 2011 remove turbo timer (you don't need it ) replace blown fuse. Learn lesson. My Mods List (Updated 8/22/17) 2005 Outback FMT Running on Electrons Link to comment Share on other sites More sharing options...
ruggerheist Posted May 29, 2011 Author Share Posted May 29, 2011 There is a main fuse in the fuse box under the hood. checked both fuse boxes, every fuse is in working order. Link to comment Share on other sites More sharing options...
ruggerheist Posted May 29, 2011 Author Share Posted May 29, 2011 alarm and door chime still work... Link to comment Share on other sites More sharing options...
rao Posted May 29, 2011 Share Posted May 29, 2011 remove turbo timer (you don't need it ) replace blown fuse. Learn lesson. I thought you needed a turbo timer to prevent coking of the oil? checked both fuse boxes, every fuse is in working order. If every fuse is in working order, then there should be power to all of the components Rob IF YOU CARE ABOUT YOUR CAR YOU SHOULD NEVER DRIVE IT Link to comment Share on other sites More sharing options...
CasopoliS Posted May 29, 2011 Share Posted May 29, 2011 remove turbo timer (you don't need it ) replace blown fuse. Learn lesson. + 1 Link to comment Share on other sites More sharing options...
planelazy Posted May 30, 2011 Share Posted May 30, 2011 When you park your car just keep it running for 30-60 seconds. While you're waiting for the minute to pass, here's a few things you can do (got this from some car magazine) -Pick your nose -Fix your unibrow -Adjust your mirrors -Throw your trash in a bag -Remove any crud from your teeth -Look in your rearview mirror and pretend the guy behind the wheel is a stud -Look in your passenger seat and pretend your GF/BF/Wife/Husband is a model (or imagine one there -Look around to see if anyone is wondering why your in your car and your car is running but it's parked -Pretend you're on a steak out I'm sure there's more but I'm tired and judging by some of the stupid things I said is a clear indication I should stop posting for the night. Link to comment Share on other sites More sharing options...
ruggerheist Posted May 30, 2011 Author Share Posted May 30, 2011 When you park your car just keep it running for 30-60 seconds. While you're waiting for the minute to pass, here's a few things you can do (got this from some car magazine) -Pick your nose -Fix your unibrow -Adjust your mirrors -Throw your trash in a bag -Remove any crud from your teeth -Look in your rearview mirror and pretend the guy behind the wheel is a stud -Look in your passenger seat and pretend your GF/BF/Wife/Husband is a model (or imagine one there -Look around to see if anyone is wondering why your in your car and your car is running but it's parked -Pretend you're on a steak out I'm sure there's more but I'm tired and judging by some of the stupid things I said is a clear indication I should stop posting for the night. you make a good point. i could also go about my day as well ill have to go through all the fuses again tomorrow when i have light. as for now she is sitting outside with the windows down. bums are going to end up having an orgy in it Link to comment Share on other sites More sharing options...
ruggerheist Posted May 30, 2011 Author Share Posted May 30, 2011 If every fuse is in working order, then there should be power to all of the components ill recheck tomorrow, but as of now we think a relay is fried somewhere Link to comment Share on other sites More sharing options...
jagcars26 Posted May 30, 2011 Share Posted May 30, 2011 remove turbo timer (you don't need it ) replace blown fuse. Learn lesson. This/\ and let me repeat. YOU DON'T NEED IT! Link to comment Share on other sites More sharing options...
ruggerheist Posted May 30, 2011 Author Share Posted May 30, 2011 Thanks!!!!!!! i just went out and told the car she doesnt need a turbo timer and she turned right on. weird. you guys are brilliant Link to comment Share on other sites More sharing options...
car_cursed Posted May 30, 2011 Share Posted May 30, 2011 you don't need it because the turbos are oil and water cooled, and unless you are running the car hard and there is not cool down time from when you are mashing the LOL pedal and turning off the car a turbo timer is pointless. Link to comment Share on other sites More sharing options...
ruggerheist Posted May 30, 2011 Author Share Posted May 30, 2011 You contradicted yourself, oil cooled. If that oil is hot and there is no cool down, no matter how hard I drove it, there is a high probability of oil coking. With how much and far I drive, I want it to err on the side of caution Link to comment Share on other sites More sharing options...
mwiener2 Posted May 30, 2011 Share Posted May 30, 2011 Subaru designed the turbos to be self cooling when the engine is off. That is why we have a secondary coolant tank above the turbo. Don't floor the car into a parking space and it should never be an issue. Come to think about it, when was the last time you heard of a subaru coking the oil in a turbo with a stock location turbo? Never? My Mods List (Updated 8/22/17) 2005 Outback FMT Running on Electrons Link to comment Share on other sites More sharing options...
ruggerheist Posted May 30, 2011 Author Share Posted May 30, 2011 I've read the horrors of banjo filters clogging from coked oil Link to comment Share on other sites More sharing options...
06_legacygt Posted May 30, 2011 Share Posted May 30, 2011 the deposits are what clogs the banjo bolt, not the heat is the turbo cooking it 2006 Legacy GT 5EAT Perrin UP, SPT CAI, OBXR CBE, Catless DP, Perrin TMIC, Stage 2 AP tune Soon after BNR 16G, Infamous Tune Link to comment Share on other sites More sharing options...
ruggerheist Posted May 30, 2011 Author Share Posted May 30, 2011 the deposits are what clogs the banjo bolt, not the heat is the turbo cooking it what deposits? i thought chunked up oil is what those deposits are, if we are on the same page Link to comment Share on other sites More sharing options...
rao Posted May 30, 2011 Share Posted May 30, 2011 Thanks!!!!!!! i just went out and told the car she doesnt need a turbo timer and she turned right on. weird. you guys are brilliant Glad you got it sorted out Rob IF YOU CARE ABOUT YOUR CAR YOU SHOULD NEVER DRIVE IT Link to comment Share on other sites More sharing options...
jbrown Posted May 30, 2011 Share Posted May 30, 2011 There is 1 benefit to the turbo timer, when you take the key out the car is still running Link to comment Share on other sites More sharing options...
car_cursed Posted May 30, 2011 Share Posted May 30, 2011 you don't need it because the turbos are oil and water cooled, and unless you are running the car hard and there is not cool down time from when you are mashing the LOL pedal and turning off the car a turbo timer is pointless. Bolding what you aparently missed. You contradicted yourself, oil cooled. If that oil is hot and there is no cool down, no matter how hard I drove it, there is a high probability of oil coking. With how much and far I drive, I want it to err on the side of caution http://assets.sbnation.com/assets/562900/facepalm.jpg Link to comment Share on other sites More sharing options...
ruggerheist Posted May 31, 2011 Author Share Posted May 31, 2011 ^ thanks bud, because i wasnt concerned about the point that my car still doesnt start Link to comment Share on other sites More sharing options...
ruggerheist Posted May 31, 2011 Author Share Posted May 31, 2011 Glad you got it sorted out sometimes its the simplest fix Link to comment Share on other sites More sharing options...
TheBoostNazi Posted May 31, 2011 Share Posted May 31, 2011 this thread is great Link to comment Share on other sites More sharing options...
ruggerheist Posted May 31, 2011 Author Share Posted May 31, 2011 rao, it was a 50 amp fuse that blew, took out my boost gauge as well. Link to comment Share on other sites More sharing options...
